[QGIS-Developer] GDAL processing algorithms issues due the default output layer extensions weirdly changed
Johannes Kröger (WhereGroup)
johannes.kroeger at wheregroup.com
Mon Feb 26 08:20:09 PST 2024
I am 99% that I have not uninstalled any plugins in two profiles where
this occured and in one of them there is only the GeoCat Bridge plugin
and in the other the QuickWKT plugin, in addition to the core plugins.
So I would consider it unlikely to be caused by plugins.
On 26.02.24 08:05, Andrea Giudiceandrea via QGIS-Developer wrote:
> Hi all,
> Il 26/02/2024 00:23, Nyall Dawson ha scritto:
> > Hmm, I wonder if it's a plugin changing this setting. I've definitely
> > seen plugins before doing unfriendly things like this...
> I also suspected that a plugin may be involved, but I was unable to
> find a common plugin in all the reports.
> Now it seems to me more likely that it may be the management of the
> settings, after seeing https://github.com/qgis/QGIS/issues/53204 and
> https://github.com/qgis/QGIS/pull/53458 precisely relating to the
> DefaultOutputRasterLayerExt and the DefaultOutputVectorLayerExt
> settings and the -1 index.
> Il 26/02/2024 01:38, Even Rouault ha scritto:
> > For example when using the ".xml" extension as a vector output, you'll
> > probably be surprised that the obscure PDS4 vector driver (tabular data
> > for planetary datasets) is used!
>> ==> Those settings should actually be deprecated and replaced by
>> others that save a GDAL driver name ... plus an extension, because
>> the "MapInfo File" driver produces quite different output if you
>> chose ".tab" or ".mif" (or the GeoJSONSeq driver that will use
>> different separators if you select the ".geojsonl" or ".geojsons"
>> extensions)
> The problem occurs also when saving the algorithm output to a file,
> instead of a temporary output, and choosing an extension.
> Best regards.
> Andrea
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Johannes Kröger / GIS-Entwickler/-Berater
FOSSGIS Konferenz
20.-23. März 2024 in Hamburg
https://www.fossgis-konferenz.de/2024/
WhereGroup-Beiträge auf der FOSSGIS
https://wheregroup.com/unternehmen/aktuelles/
WhereGroup GmbH
c/o KK03 GmbH
Lange Reihe 29
20099 Hamburg
Germany
Tel: +49 (0)228 / 90 90 38 - 36
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
