[QGIS-Developer] Qgis 3.34.4 LTR ?
Luca Manganelli
luca.manganelli at comune.trento.it
Tue Feb 27 01:19:10 PST 2024
Thank you for your response. Yes, I suggest you to indicate that the date
are only suggested.
See this example for LibreOffice:
https://wiki.documentfoundation.org/ReleasePlan
there's a column for the Freeze and one for Publishing, with a range of
dates and not a fixed day.
Il giorno mar 27 feb 2024 alle ore 09:59 Régis Haubourg <
regis.haubourg at gmail.com> ha scritto:
> Hi Luca, as always, there is a delay between source code releases events,
> and the packaging can only start, as per
> https://www.qgis.org/en/site/getinvolved/development/roadmap.html#release
> QGIS website indicates that packaging is on its way.
> Official communication including the changelog and binaries are on their
> way.
> How do you think we could improve our communication to clarify this ? You
> are not the only one asking, so I think we still have work to improve.
> Le mar. 27 févr. 2024 à 09:40, Luca Manganelli via QGIS-Developer <
> qgis-developer at lists.osgeo.org> a écrit :
>> Good morning,
>> according to the QGIS roadmap, I see that the 3.34 LTR release is on 23th
>> february, but on the site I see that the latest LTR is still 3.28
>> Comune di Trento
>> via Belenzani, 19 - 38122 Trento | C.F e P. IVA: 00355870221
>> tel. +39 0461.884111 | www.comune.trento.it
>> *Informativa privacy*
>> I dati contenuti nella presente e-mail sono raccolti e trattati nel
>> rispetto del Regolamento UE 2016/679 (GDPR). Gli interessati possono
>> rivolgersi in qualsiasi momento al Titolare del trattamento, Comune di
>> Trento, per esercitare i diritti previsti dal GDPR. I dati di contatto del
>> RPD e del Titolare oltre che l’informativa completa sono disponibili al
>> link https://www.comune.trento.it/ sotto la voce “Privacy”.
>> Si precisa inoltre che le informazioni contenute nel presente messaggio,
>> e negli eventuali allegati, sono riservate e per uso esclusivo del
>> destinatario. In caso di ricezione dello stesso per errore, siete pregati
>> di informare immediatamente il mittente e di cancellarlo dal vostro
>> archivio, in conformità con quanto disposto dall'art. 17 del GDPR. Ogni
>> trattamento della presente mail che non sia quello del destinatario reale è
>> inteso come non autorizzato dal mittente. Inoltre, in quanto non
>> destinatari reali, Vi informiamo che il mittente si oppone alla copia, la
>> diffusione e la rivelazione anche parziale dei dati in esso contenuti alle
>> persone non autorizzate dal medesimo, in virtù di quanto disposto dall'art.
>> 21 del GDPR.
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Luca Manganelli
Assistente informatico
Servizio Innovazione e Sistemi digitali
Via Ezio Maccani 148
38121 Trento (TN)
Comune di Trento
00355870221
<http://www.comune.trento.it>
presente e-mail sono raccolti e trattati nel rispetto del Regolamento UE
2016/679 (GDPR). Gli interessati possono rivolgersi in qualsiasi momento al
Titolare del trattamento, Comune di Trento, per esercitare i diritti
previsti dal GDPR. I dati di contatto del RPD e del Titolare oltre che
l’informativa completa sono disponibili al link
https://www.comune.trento.it/ <https://www.comune.trento.it/> sotto la voce
“Privacy”.
messaggio, e negli eventuali allegati, sono riservate e per uso esclusivo
del destinatario. In caso di ricezione dello stesso per errore, siete
pregati di informare immediatamente il mittente e di cancellarlo dal vostro
21 del GDPR.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20240227/9d4d389f/attachment.htm>
