[QGIS-Developer] Qgis 3.34.4 LTR ?
Nick Bearman
nick at geospatialtrainingsolutions.co.uk
Tue Feb 27 01:20:04 PST 2024
Hi Régis, Luca, list,
I think some of the confusion might be over the term of "Release". I
read this as release of the binaries, i.e. something we can download and
install from the QGIS website as a user. From what you said Luca, it
seems you view "Release" as release of the source code before packaging
into binaries. Do I understand this correctly?
I've always found the Road Map page slightly confusing. Is there space
on the website for a "simpler" explanation of this process somewhere?
Yes, I am happy to have a go at writing a first draft!
Also - I think the release process is complicated by OSGeo4W Network
installer. I used this to install both LTR and current versions of QGIS
yesterday (26th Feb) and got 3.36.0 (branded as Release Candidate) and
3.34.3 (branded at LTR) which I think is a bit ahead of the game.
I think Kurt's post on LinkedIn
(https://www.linkedin.com/feed/update/urn:li:activity:7167793362815717376/)
may have also made some people this 3.36 is available when it is not.
Hope this is useful!
Best wishes,
Nick.
On 27/02/2024 08:58, Régis Haubourg via QGIS-Developer wrote:
> Hi Luca, as always, there is a delay between source code releases
> events, and the packaging can only start, as per
> https://www.qgis.org/en/site/getinvolved/development/roadmap.html#release
> QGIS website indicates that packaging is on its way.
> Official communication including the changelog and binaries are on
> their way.
> How do you think we could improve our communication to clarify this ?
> You are not the only one asking, so I think we still have work to
> improve.
> Le mar. 27 févr. 2024 à 09:40, Luca Manganelli via QGIS-Developer
> <qgis-developer at lists.osgeo.org> a écrit :
> Good morning,
> according to the QGIS roadmap, I see that the 3.34 LTR release is
> on 23th february, but on the site I see that the latest LTR is
> still 3.28
> Comune di Trento
> via Belenzani, 19 - 38122 Trento | C.F e P. IVA: 00355870221
> tel. +39 0461.884111 | www.comune.trento.it
> <http://www.comune.trento.it>
> *Informativa privacy*
> I dati contenuti nella presente e-mail sono raccolti e trattati
> nel rispetto del Regolamento UE 2016/679 (GDPR). Gli interessati
> possono rivolgersi in qualsiasi momento al Titolare del
> trattamento, Comune di Trento, per esercitare i diritti previsti
> dal GDPR. I dati di contatto del RPD e del Titolare oltre che
> l’informativa completa sono disponibili al link
> https://www.comune.trento.it/ sotto la voce “Privacy”.
> Si precisa inoltre che le informazioni contenute nel presente
> messaggio, e negli eventuali allegati, sono riservate e per uso
> esclusivo del destinatario. In caso di ricezione dello stesso per
> errore, siete pregati di informare immediatamente il mittente e di
> cancellarlo dal vostro archivio, in conformità con quanto disposto
> dall'art. 17 del GDPR. Ogni trattamento della presente mail che
> non sia quello del destinatario reale è inteso come non
> autorizzato dal mittente. Inoltre, in quanto non destinatari
> reali, Vi informiamo che il mittente si oppone alla copia, la
> diffusione e la rivelazione anche parziale dei dati in esso
> contenuti alle persone non autorizzate dal medesimo, in virtù di
> quanto disposto dall'art. 21 del GDPR.
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-developer
Nick Bearman
+44 (0) 7717745715
Please let me know if I can make any adjustments related to disability or neurodivergence to improve how we interact.
Due to my own life/work balance, you may get emails from me outside of normal working hours. Please do not feel any pressure to respond outside of your own working pattern.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20240227/7bd461b7/attachment-0001.htm>
