[QGIS-Developer] Qgis 3.34.4 LTR ?
Régis Haubourg regis.haubourg at gmail.com
Tue Feb 27 05:05:55 PST 2024
We are in the process of building a new website, I think you're right we
should simplify the roadmap page and communicate more on the binary release
date than on source code in our phrasing.
As for external communication, indeed many posts are launched individually
when source code is branched. I hope this is not a race to be the first to
communicate and gather traffic.  I'll raise the issue to the PSC.
Thanks a lot!
Le mar. 27 févr. 2024 à 10:20, Nick Bearman via QGIS-Developer <
qgis-developer at lists.osgeo.org> a écrit :
> Hi Régis, Luca, list,
> I think some of the confusion might be over the term of "Release". I read
> this as release of the binaries, i.e. something we can download and install
> from the QGIS website as a user. From what you said Luca, it seems you view
> "Release" as release of the source code before packaging into binaries. Do
> I understand this correctly?
> I've always found the Road Map page slightly confusing. Is there space on
> the website for a "simpler" explanation of this process somewhere? Yes, I
> am happy to have a go at writing a first draft!
> Also - I think the release process is complicated by OSGeo4W Network
> installer. I used this to install both LTR and current versions of QGIS
> yesterday (26th Feb) and got 3.36.0 (branded as Release Candidate) and
> 3.34.3 (branded at LTR) which I think is a bit ahead of the game.
> I think Kurt's post on LinkedIn (
> https://www.linkedin.com/feed/update/urn:li:activity:7167793362815717376/)
> may have also made some people this 3.36 is available when it is not.
> Hope this is useful!
> Best wishes,
> Nick.
> On 27/02/2024 08:58, Régis Haubourg via QGIS-Developer wrote:
> Hi Luca, as always, there is a delay between source code releases events,
> and the packaging can only start, as per
> https://www.qgis.org/en/site/getinvolved/development/roadmap.html#release
> QGIS website indicates that packaging is on its way.
> Official communication including the changelog and binaries are on their
> way.
> How do you think we could improve our communication to clarify this ? You
> are not the only one asking, so I think we still have work to improve.
> Le mar. 27 févr. 2024 à 09:40, Luca Manganelli via QGIS-Developer <
>> Good morning,
>> according to the QGIS roadmap, I see that the 3.34 LTR release is on 23th
>> february, but on the site I see that the latest LTR is still 3.28
>> Comune di Trento
>> via Belenzani, 19 - 38122 Trento | C.F e P. IVA: 00355870221
>> tel. +39 0461.884111 | www.comune.trento.it
>> *Informativa privacy*
>> I dati contenuti nella presente e-mail sono raccolti e trattati nel
>> rispetto del Regolamento UE 2016/679 (GDPR). Gli interessati possono
>> rivolgersi in qualsiasi momento al Titolare del trattamento, Comune di
>> Trento, per esercitare i diritti previsti dal GDPR. I dati di contatto del
>> RPD e del Titolare oltre che l’informativa completa sono disponibili al
>> link https://www.comune.trento.it/ sotto la voce “Privacy”.
>> Si precisa inoltre che le informazioni contenute nel presente messaggio,
>> e negli eventuali allegati, sono riservate e per uso esclusivo del
>> destinatario. In caso di ricezione dello stesso per errore, siete pregati
>> di informare immediatamente il mittente e di cancellarlo dal vostro
>> archivio, in conformità con quanto disposto dall'art. 17 del GDPR. Ogni
>> trattamento della presente mail che non sia quello del destinatario reale è
>> inteso come non autorizzato dal mittente. Inoltre, in quanto non
>> destinatari reali, Vi informiamo che il mittente si oppone alla copia, la
>> diffusione e la rivelazione anche parziale dei dati in esso contenuti alle
>> persone non autorizzate dal medesimo, in virtù di quanto disposto dall'art.
>> 21 del GDPR.
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> QGIS-Developer mailing listQGIS-Developer at lists.osgeo.org
> Nick Bearman
> +44 (0) 7717745715nick at geospatialtrainingsolutions.co.uk
> Please let me know if I can make any adjustments related to disability or neurodivergence to improve how we interact.
> Due to my own life/work balance, you may get emails from me outside of normal working hours. Please do not feel any pressure to respond outside of your own working pattern.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20240227/1c81ef3f/attachment.htm>
More information about the QGIS-Developer mailing list
