[QGIS-Developer] Official PSC call on pull request policies
Julien Cabieces
julien.cabieces at oslandia.com
Tue Feb 27 23:26:00 PST 2024
Hi all,
> [[PGP Signed Part:Undecided]]
> Thanks Nyall for raising this thread!
> On Mon, Feb 26, 2024 at 09:21:05AM +1000, Nyall Dawson wrote:
>> Policy #1: https://github.com/qgis/QGIS/pull/56062
>> In short, Sandro proposes that the pull request queue be an open queue
>> of ALL work happening everywhere, in any state of completeness. Pull
>> requests are permitted for semi-complete work, and for long-term
>> (including multi-year) projects which are not yet ready for review or
>> merge. The justification here is that having this work open in the
>> queue makes it widely visible and so that other developers are aware
>> of ongoing work across the community.
> I would add that allowing long-term PRs also serves the purpose of making
> it easy for contributors to check the state of their work against CI as
> running tests locally is so hard that I dubt anyone is doing that.
It's completely possible to trigger the GH CI without creating a PR
directly from your fork, you
just have to:
- create a branch
- add your branch name here [0] in a special commit that you will remove
once your work is ready to create a PR
- Push, the CI result appear in https://github.com/<your_gh_login>/QGIS/actions
Prior to that you will have to "Allow all actions and reusable workflows"
from https://github.com/<your_gh_login>/QGIS/settings/actions
It's pretty straightforward, and I use it everytime I want to check on CI.
Regards,
Julien
[0] https://github.com/qgis/QGIS/blob/release-3_28/.github/workflows/run-tests.yml#L6
>> Policy #2: https://github.com/qgis/QGIS/pull/56523
>> When the queue includes work which is not ready for review, then it
>> becomes very tricky to work out the actual status of pull requests and
>> which ones should be focused on during review time.
> I think this is a limitation of the software used to get the list
> of pull requests needing focus, and should be threated as such.
> If github makes it hard to filter on "PR state" we could use a label
> to do that.
> --strk;
> [[End of PGP Signed Part]]
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Julien Cabieces
Senior Developer at Oslandia
