[QGIS-Developer] Running unit tests without "make install"
Thomas Larsen Wessel mrvelle at gmail.com
Mon Jan 15 15:14:21 PST 2024
I mistakenly forgot to post the corresponding log (LastTest.log) before,
but here it is:
https://gist.github.com/velle/023e0cc6c3b5f134cdab3219cb9a8863
Its running the test with the verbose flag now, but that will take an hour
or so. And as far as I can tell it does not contain more information than
the above, though it may be formatted in a more helpful way.
On Mon, Jan 15, 2024 at 10:31 PM Nyall Dawson <nyall.dawson at gmail.com>
wrote:
> On Tue, 16 Jan 2024, 7:28 am Thomas Larsen Wessel, <mrvelle at gmail.com>
> wrote:
>> Thanks for having a look at it :) I ran a complete test and saved the
>> test output to this gist. Is that what you were looking for? Please tell me
>> what other info you need.
>> https://gist.github.com/velle/b195bee9a5d63e95ea7aa600b7833be1
> Try with "ctest -v" to get the full log of the tests
> Nyall
>> On Mon, Jan 15, 2024 at 7:54 AM Nyall Dawson <nyall.dawson at gmail.com>
>> wrote:
>>> On Mon, 15 Jan 2024, 3:42 pm Thomas Larsen Wessel, <mrvelle at gmail.com>
>>> wrote:
>>>> When you guys run these tests locally, do they all pass?
>>>> After some fiddling I have removed some errors, caused by incorrect
>>>> build setup. But I still have  19 failing tests.
>>>> 2 - checkGitStatus (Failed)
>>>> 22 - ProcessingGrass7AlgorithmsRasterTestPt2 (Failed)
>>>> 24 - ProcessingOtbAlgorithmsTest (Failed)
>>>> 46 - test_core_compositionconverter (Failed)
>>>> 108 - test_core_layoutpicture (Failed)
>>>> 177 - test_core_settingsentry (Failed)
>>>> 280 - test_gui_filedownloader (Subprocess aborted)
>>>> 288 - test_gui_featurelistcombobox (Subprocess aborted)
>>>> 298 - test_gui_queryresultwidget (Subprocess aborted)
>>>> 302 - test_3d_3drendering (Failed)
>>>> 309 - test_3d_mesh3drendering (Failed)
>>>> 332 - test_provider_wcsprovider (Failed)
>>>> 413 - PyQgsAnnotation (Failed)
>>>> 489 - PyQgsExternalStorageWebDav (Failed)
>>>> 490 - PyQgsExternalStorageAwsS3 (Failed)
>>>> 600 - PyQgsMapCanvas (Failed)
>>>> 601 - PyQgsMapCanvasAnnotationItem (Failed)
>>>> 672 - PyQgsProcessExecutablePt1 (Failed)
>>>> 673 - PyQgsProcessExecutablePt2 (Failed)
>>>> I think I understand checkGitStatus and can safely ignore that one. But
>>>> what about the rest? Is it "normal" that so many tests fail when running
>>>> tests locally?
>>> That's more than I'd expect to fail on 22.04 -- at least, the main qgis
>>> ci workflow uses 22.04 and most of these are passing !
>>> (See https://github.com/qgis/QGIS/blob/master/.ci/test_flaky.txt and
>>> https://github.com/qgis/QGIS/blob/master/.ci/test_blocklist_qt5.txt for
>>> lists of the tests skipped on the GitHub workflows)
>>>> Would any of these tests give a different result if I first ran "make
>>>> install"?
>>> Unlikely.
>>> I'd be interested to see a full log of the failures if you want to
>>> upload it to a gist/Pastebin/ somewhere.
>>> Nyall
>>>> Im running Ubuntu 22.04, and installed all dependencies via APT as
>>>> advised in the qgis build docs. I built QGIS release-3_34 from source and
>>>> am now trying to test that build, by running "ctest".
>>>> On Mon, Jan 1, 2024 at 12:34 AM Thomas Larsen Wessel <mrvelle at gmail.com>
>>>> wrote:
>>>>> Thanks both of you :) And happy new year.
>>>>> On Sun, Dec 31, 2023 at 11:38 PM Nyall Dawson <nyall.dawson at gmail.com>
>>>>> wrote:
>>>>>> On Mon, 1 Jan 2024, 6:36 am Thomas Larsen Wessel via QGIS-Developer, <
>>>>>> qgis-developer at lists.osgeo.org> wrote:
>>>>>>> The docs (
>>>>>>> https://docs.qgis.org/3.28/en/docs/developers_guide/unittesting.html#run-your-tests)
>>>>>>> specify: *make && make install && make test*.
>>>>>>> I would rather not run make install, since I have another instance
>>>>>>> of QGIS installed via APT, and I worry running make install will somehow
>>>>>>> make a mess and leave me without a working instance.
>>>>>>> But is it really necessary to run make install before make run? In
>>>>>>> fact it seems more natural to me to test before installing!
>>>>>> Try running "ctest" from your build directory. There's no need to
>>>>>> install if doing it this way. (It's how I do all of my development)
>>>>>> Nyall
>>>>>>> Sincerely
>>>>>>> _______________________________________________
>>>>>>> QGIS-Developer mailing list
>>>>>>> QGIS-Developer at lists.osgeo.org
>>>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20240116/913edcfd/attachment.htm>
More information about the QGIS-Developer mailing list
