[QGIS-Developer] Running unit tests without "make install"
Nyall Dawson
nyall.dawson at gmail.com
Mon Jan 15 13:31:29 PST 2024
On Tue, 16 Jan 2024, 7:28 am Thomas Larsen Wessel, <mrvelle at gmail.com>
wrote:
> Thanks for having a look at it :) I ran a complete test and saved the test
> output to this gist. Is that what you were looking for? Please tell me what
> other info you need.
> https://gist.github.com/velle/b195bee9a5d63e95ea7aa600b7833be1
Try with "ctest -v" to get the full log of the tests
Nyall
> On Mon, Jan 15, 2024 at 7:54 AM Nyall Dawson <nyall.dawson at gmail.com>
> wrote:
>> On Mon, 15 Jan 2024, 3:42 pm Thomas Larsen Wessel, <mrvelle at gmail.com>
>> wrote:
>>> When you guys run these tests locally, do they all pass?
>>> After some fiddling I have removed some errors, caused by incorrect
>>> build setup. But I still have 19 failing tests.
>>> 2 - checkGitStatus (Failed)
>>> 22 - ProcessingGrass7AlgorithmsRasterTestPt2 (Failed)
>>> 24 - ProcessingOtbAlgorithmsTest (Failed)
>>> 46 - test_core_compositionconverter (Failed)
>>> 108 - test_core_layoutpicture (Failed)
>>> 177 - test_core_settingsentry (Failed)
>>> 280 - test_gui_filedownloader (Subprocess aborted)
>>> 288 - test_gui_featurelistcombobox (Subprocess aborted)
>>> 298 - test_gui_queryresultwidget (Subprocess aborted)
>>> 302 - test_3d_3drendering (Failed)
>>> 309 - test_3d_mesh3drendering (Failed)
>>> 332 - test_provider_wcsprovider (Failed)
>>> 413 - PyQgsAnnotation (Failed)
>>> 489 - PyQgsExternalStorageWebDav (Failed)
>>> 490 - PyQgsExternalStorageAwsS3 (Failed)
>>> 600 - PyQgsMapCanvas (Failed)
>>> 601 - PyQgsMapCanvasAnnotationItem (Failed)
>>> 672 - PyQgsProcessExecutablePt1 (Failed)
>>> 673 - PyQgsProcessExecutablePt2 (Failed)
>>> I think I understand checkGitStatus and can safely ignore that one. But
>>> what about the rest? Is it "normal" that so many tests fail when running
>>> tests locally?
>> That's more than I'd expect to fail on 22.04 -- at least, the main qgis
>> ci workflow uses 22.04 and most of these are passing !
>> (See https://github.com/qgis/QGIS/blob/master/.ci/test_flaky.txt and
>> https://github.com/qgis/QGIS/blob/master/.ci/test_blocklist_qt5.txt for
>> lists of the tests skipped on the GitHub workflows)
>>> Would any of these tests give a different result if I first ran "make
>>> install"?
>> Unlikely.
>> I'd be interested to see a full log of the failures if you want to upload
>> it to a gist/Pastebin/ somewhere.
>> Nyall
>>> Im running Ubuntu 22.04, and installed all dependencies via APT as
>>> advised in the qgis build docs. I built QGIS release-3_34 from source and
>>> am now trying to test that build, by running "ctest".
>>> On Mon, Jan 1, 2024 at 12:34 AM Thomas Larsen Wessel <mrvelle at gmail.com>
>>> wrote:
>>>> Thanks both of you :) And happy new year.
>>>> On Sun, Dec 31, 2023 at 11:38 PM Nyall Dawson <nyall.dawson at gmail.com>
>>>> wrote:
>>>>> On Mon, 1 Jan 2024, 6:36 am Thomas Larsen Wessel via QGIS-Developer, <
>>>>> qgis-developer at lists.osgeo.org> wrote:
>>>>>> The docs (
>>>>>> https://docs.qgis.org/3.28/en/docs/developers_guide/unittesting.html#run-your-tests)
>>>>>> specify: *make && make install && make test*.
>>>>>> I would rather not run make install, since I have another instance of
>>>>>> QGIS installed via APT, and I worry running make install will somehow make
>>>>>> a mess and leave me without a working instance.
>>>>>> But is it really necessary to run make install before make run? In
>>>>>> fact it seems more natural to me to test before installing!
>>>>> Try running "ctest" from your build directory. There's no need to
>>>>> install if doing it this way. (It's how I do all of my development)
>>>>> Nyall
>>>>>> Sincerely
>>>>>> _______________________________________________
>>>>>> QGIS-Developer mailing list
>>>>>> QGIS-Developer at lists.osgeo.org
>>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20240116/3dd2d179/attachment-0001.htm>
