[QGIS-Developer] Running unit tests without "make install"
Thomas Larsen Wessel
mrvelle at gmail.com
Mon Jan 15 13:28:19 PST 2024
Thanks for having a look at it :) I ran a complete test and saved the test
output to this gist. Is that what you were looking for? Please tell me what
other info you need.
https://gist.github.com/velle/b195bee9a5d63e95ea7aa600b7833be1
On Mon, Jan 15, 2024 at 7:54 AM Nyall Dawson <nyall.dawson at gmail.com> wrote:
> On Mon, 15 Jan 2024, 3:42 pm Thomas Larsen Wessel, <mrvelle at gmail.com>
> wrote:
>> When you guys run these tests locally, do they all pass?
>> After some fiddling I have removed some errors, caused by incorrect build
>> setup. But I still have 19 failing tests.
>> 2 - checkGitStatus (Failed)
>> 22 - ProcessingGrass7AlgorithmsRasterTestPt2 (Failed)
>> 24 - ProcessingOtbAlgorithmsTest (Failed)
>> 46 - test_core_compositionconverter (Failed)
>> 108 - test_core_layoutpicture (Failed)
>> 177 - test_core_settingsentry (Failed)
>> 280 - test_gui_filedownloader (Subprocess aborted)
>> 288 - test_gui_featurelistcombobox (Subprocess aborted)
>> 298 - test_gui_queryresultwidget (Subprocess aborted)
>> 302 - test_3d_3drendering (Failed)
>> 309 - test_3d_mesh3drendering (Failed)
>> 332 - test_provider_wcsprovider (Failed)
>> 413 - PyQgsAnnotation (Failed)
>> 489 - PyQgsExternalStorageWebDav (Failed)
>> 490 - PyQgsExternalStorageAwsS3 (Failed)
>> 600 - PyQgsMapCanvas (Failed)
>> 601 - PyQgsMapCanvasAnnotationItem (Failed)
>> 672 - PyQgsProcessExecutablePt1 (Failed)
>> 673 - PyQgsProcessExecutablePt2 (Failed)
>> I think I understand checkGitStatus and can safely ignore that one. But
>> what about the rest? Is it "normal" that so many tests fail when running
>> tests locally?
> That's more than I'd expect to fail on 22.04 -- at least, the main qgis ci
> workflow uses 22.04 and most of these are passing !
> (See https://github.com/qgis/QGIS/blob/master/.ci/test_flaky.txt and
> https://github.com/qgis/QGIS/blob/master/.ci/test_blocklist_qt5.txt for
> lists of the tests skipped on the GitHub workflows)
>> Would any of these tests give a different result if I first ran "make
>> install"?
> Unlikely.
> I'd be interested to see a full log of the failures if you want to upload
> it to a gist/Pastebin/ somewhere.
> Nyall
>> Im running Ubuntu 22.04, and installed all dependencies via APT as
>> advised in the qgis build docs. I built QGIS release-3_34 from source and
>> am now trying to test that build, by running "ctest".
>> On Mon, Jan 1, 2024 at 12:34 AM Thomas Larsen Wessel <mrvelle at gmail.com>
>> wrote:
>>> Thanks both of you :) And happy new year.
>>> On Sun, Dec 31, 2023 at 11:38 PM Nyall Dawson <nyall.dawson at gmail.com>
>>> wrote:
>>>> On Mon, 1 Jan 2024, 6:36 am Thomas Larsen Wessel via QGIS-Developer, <
>>>> qgis-developer at lists.osgeo.org> wrote:
>>>>> The docs (
>>>>> https://docs.qgis.org/3.28/en/docs/developers_guide/unittesting.html#run-your-tests)
>>>>> specify: *make && make install && make test*.
>>>>> I would rather not run make install, since I have another instance of
>>>>> QGIS installed via APT, and I worry running make install will somehow make
>>>>> a mess and leave me without a working instance.
>>>>> But is it really necessary to run make install before make run? In
>>>>> fact it seems more natural to me to test before installing!
>>>> Try running "ctest" from your build directory. There's no need to
>>>> install if doing it this way. (It's how I do all of my development)
>>>> Nyall
>>>>> Sincerely
>>>>> _______________________________________________
>>>>> QGIS-Developer mailing list
>>>>> QGIS-Developer at lists.osgeo.org
>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20240115/26df9e0c/attachment.htm>
