[QGIS-Developer] Running unit tests without "make install"
    Nyall Dawson
    nyall.dawson at gmail.com
    Sun Jan 14 22:53:59 PST 2024
On Mon, 15 Jan 2024, 3:42 pm Thomas Larsen Wessel, <mrvelle at gmail.com>
wrote:
> When you guys run these tests locally, do they all pass?
> After some fiddling I have removed some errors, caused by incorrect build
> setup. But I still have  19 failing tests.
> 2 - checkGitStatus (Failed)
> 22 - ProcessingGrass7AlgorithmsRasterTestPt2 (Failed)
> 24 - ProcessingOtbAlgorithmsTest (Failed)
> 46 - test_core_compositionconverter (Failed)
> 108 - test_core_layoutpicture (Failed)
> 177 - test_core_settingsentry (Failed)
> 280 - test_gui_filedownloader (Subprocess aborted)
> 288 - test_gui_featurelistcombobox (Subprocess aborted)
> 298 - test_gui_queryresultwidget (Subprocess aborted)
> 302 - test_3d_3drendering (Failed)
> 309 - test_3d_mesh3drendering (Failed)
> 332 - test_provider_wcsprovider (Failed)
> 413 - PyQgsAnnotation (Failed)
> 489 - PyQgsExternalStorageWebDav (Failed)
> 490 - PyQgsExternalStorageAwsS3 (Failed)
> 600 - PyQgsMapCanvas (Failed)
> 601 - PyQgsMapCanvasAnnotationItem (Failed)
> 672 - PyQgsProcessExecutablePt1 (Failed)
> 673 - PyQgsProcessExecutablePt2 (Failed)
> I think I understand checkGitStatus and can safely ignore that one. But
> what about the rest? Is it "normal" that so many tests fail when running
> tests locally?
That's more than I'd expect to fail on 22.04 -- at least, the main qgis ci
workflow uses 22.04 and most of these are passing !
(See https://github.com/qgis/QGIS/blob/master/.ci/test_flaky.txt and
https://github.com/qgis/QGIS/blob/master/.ci/test_blocklist_qt5.txt for
lists of the tests skipped on the GitHub workflows)
> Would any of these tests give a different result if I first ran "make
> install"?
Unlikely.
I'd be interested to see a full log of the failures if you want to upload
it to a gist/Pastebin/ somewhere.
Nyall
> Im running Ubuntu 22.04, and installed all dependencies via APT as advised
> in the qgis build docs. I built QGIS release-3_34 from source and am now
> trying to test that build, by running "ctest".
> On Mon, Jan 1, 2024 at 12:34 AM Thomas Larsen Wessel <mrvelle at gmail.com>
> wrote:
>> Thanks both of you :) And happy new year.
>> On Sun, Dec 31, 2023 at 11:38 PM Nyall Dawson <nyall.dawson at gmail.com>
>> wrote:
>>> On Mon, 1 Jan 2024, 6:36 am Thomas Larsen Wessel via QGIS-Developer, <
>>> qgis-developer at lists.osgeo.org> wrote:
>>>> The docs (
>>>> https://docs.qgis.org/3.28/en/docs/developers_guide/unittesting.html#run-your-tests)
>>>> specify: *make && make install && make test*.
>>>> I would rather not run make install, since I have another instance of
>>>> QGIS installed via APT, and I worry running make install will somehow make
>>>> a mess and leave me without a working instance.
>>>> But is it really necessary to run make install before make run? In fact
>>>> it seems more natural to me to test before installing!
>>> Try running "ctest" from your build directory. There's no need to
>>> install if doing it this way. (It's how I do all of my development)
>>> Nyall
>>>> Sincerely
>>>> _______________________________________________
>>>> QGIS-Developer mailing list
>>>> QGIS-Developer at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20240115/b3b49137/attachment.htm>
