[QGIS-Developer] Strange Mysql (spatial) behaviour: no points visible
Alessandro Pasotti
apasotti at gmail.com
Tue Jan 16 12:14:50 PST 2024
Hi Richard,
sorry, no hints except to check the logs and the QGIS dev tools query
logger: is there anything suspicious?
On Tue, Jan 16, 2024 at 8:08 PM Richard Duivenvoorde via
QGIS-Developer <qgis-developer at lists.osgeo.org> wrote:
> No hints :-) ?
> I now have a live connection to the db, and can reproduce the issue here in master on Linux too.
> It's really strange: have a local db, I can even copy features from the attribute table to my local table, and THEN they show up
> ogrinfo shows exactly the same information of the db ( using -so).
> coordinates are fine too:
> select coord, ST_AsWKT(coord) from tblQgisProjecten tqp limit 1
> coord |ST_AsWKT(coord) |
> POINT (168937.186906043 175180.302889316)|POINT(168937.186906043 175180.302889316)|
> could it be in char encoding, or in a strange attribute value? We already tried to create a simple view with only coord and ID, but that did not show something either.
> As I cannot share the connection info, I'm happy to share my screen or so to show this.
> SELECT version();
> version()|
> 8.0.34-26|
> but is an upgraded db, not sure where it came from
> Regards,
> On 1/12/24 15:06, Richard Duivenvoorde via QGIS-Developer wrote:
> > Hi Devs,
> > I was contacted by a company who after upgrading their db and QGIS did NOT see the points anymore.
> > Note that 'all worked' when they used QGIS 3.10 (and an older mysql db)
> > After a MySQL database upgrade, QGIS 3.10 was not able to connect anymore (apparently TLS issues), so they have to use 3.28 or higher.
> > A small export loaded in my local db was OK in QGIS.
> > So in a online meeting, sharing their screen I tried:
> > - opening the db with ogrinfo: all data is visible (POINT(.....)) showing correct coords and attributes
> > - loading the table (25000 records) in QGIS: data: EPSG:31370 project EPSG:31370 :
> > - attribute table shows all records
> > - mapcanvas empty!
> > - able to 'zoom to' records (Belgium), but NO points visible/selectable
> > - creating a tiny table with only id and geom column of 3 records: mapcanvas emtpy
> > - export the loaded (but invisible) layer to a geopackage: points AND attributes VISIBLE!
> > - loading the data in dbeaver: all data is shown in the spatial tab
> > There was an encoding issue when exporting to gpkg, but we tried to create a smaller table (very few columns): nothing.
> > Anybody familiar with QGIS and Mysql has an idea what this not showing of any point/geom could be?
> > Any hint appreciated, I plan to try to get a connection to the db myself, but hoping I just miss something obvious...
> > Regards,
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Alessandro Pasotti
QCooperative: www.qcooperative.net
ItOpen: www.itopen.it
