[QGIS-Developer] QGIS plugin depends on pypi package
Matthias Kuhn matthias at opengis.ch
Sat Jan 20 21:59:01 PST 2024
Hi John,
It is still listed under "experimental" plugins, so you have to enable
support for experimental plugins in the plugin manager.
If you can give feedback if it works for you, this will help to move
forward with this concept.
Kind regards
Matthias
On Fri, Jan 19, 2024, 18:46 John Lindsay <jlindsay at uoguelph.ca> wrote:
> Hello Matthias,
> This is very interesting and I'll certainly take a closer look at it as an
> option. Do you know if the plugin is stable yet? I can find it listed in
> the online QGIS plugin repository, but not yet from the search inside QGIS
> itself. Thanks.
> Regards,
> John
> Prof. John Lindsay
> Dept. of Geography, Environment & Geomatics,
> The University of Guelph,
> Room 122, Hutt Building,
> E-mail: jlindsay at uoguelph.ca
> Phone: (519) 824-4120 ext. 56074
> Web: https://geg.uoguelph.ca/faculty/lindsay-john
> Research page: https://jblindsay.github.io/ghrg/index.html
> WhiteboxTools GIS project: https://www.whiteboxgeo.com/
> Twitter: https://twitter.com/whiteboxgeo
> *From:* QGIS-Developer <qgis-developer-bounces at lists.osgeo.org> on behalf
> of Matthias Kuhn via QGIS-Developer <qgis-developer at lists.osgeo.org>
> *Sent:* Friday, January 19, 2024 12:20 PM
> *To:* Greg Troxel <gdt at lexort.com>
> *Cc:* John Lindsay via QGIS-Developer <qgis-developer at lists.osgeo.org>
> *Subject:* Re: [QGIS-Developer] QGIS plugin depends on pypi package
> CAUTION: This email originated from outside of the University of Guelph.
> Do not click links or open attachments unless you recognize the sender and
> know the content is safe. If in doubt, forward suspicious emails to
> IThelp at uoguelph.ca.
> Hi John,
> A former colleague of mine developed "qpip".
> This is meant as a pip dependency manager for plugins and will install any
> additional dependencies from a supplied requirements.txt in a controlled
> way into the user profile folder.
> There has never been any big announcement done regarding this plugin, but
> it's the best "pip"-like integration into QGIS which I am aware of.
> https://github.com/opengisch/qpip
> Kind regards
> Matthias
> On Fri, Jan 19, 2024 at 6:13 PM Greg Troxel via QGIS-Developer <
> qgis-developer at lists.osgeo.org> wrote:
> John Lindsay via QGIS-Developer <qgis-developer at lists.osgeo.org> writes:
> > Besides, a better solution would be for the plugin to install this
> > package via pip when it is itself first installed and launched. I
> > tried to accomplish this with the following code:
> https://github.com/jblindsay/whitebox_workflows_for_qgis/blob/4e463262f6cfd1987afa2f3f7e0e79656eb8d27e/whitebox_workflows_for_qgis_provider.py#L56
> > This code, which runs whenever the plugin is launched, first checks to
> > see if whitebox_workflows can be imported and if not, it runs pip from
> > the Python script to install it. Unfortunately, some users have
> > reported issues with this not working correctly:
> (Writing from the UNIX perspective.)
> Perhaps biased by my packaing background, I view any code that downloads
> other code at runtime (without an explicit user request) as a security
> bug.   This is especially true if it isn't getting sources pinned to a
> version and validated by checksum.
> That said, there's a lot of interesting questions about how to deal with
> dependencies of plugins.   For qgis itself, dependencies are properly
> dealt with by a packaging system and that seems ok.
> For plugins, I could see treating them as python modules and packaging
> them, but qgis wants to have its own package management system.
> qgis is usually installed, via packaging, globally (/usr or /usr/pkg, or
> similar).  The immediate question is where plugins go.  I'd expect them
> to be in the user's file area vs system, unless installing them in some
> administrator role.  The next question is, if they depend on something,
> what prefixes and install methods are expected for those things, both
> regular packages (programs and shlibs) and python modules.  Which is
> partly/mostly about what the search paths are in the plugin execution
> environment.
> Overall, I'd rather see plugins fail with a message and leave
> installation as a manual decision than have plugins run pip install.
> But I get it that most people probably don't see it that way.
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20240121/d1dc0d66/attachment.htm>
More information about the QGIS-Developer mailing list
