[QGIS-Developer] Strange Mysql (spatial) behaviour: no points visible
Even Rouault even.rouault at spatialys.com
Tue Jan 23 04:40:22 PST 2024
Richard,
I've failed to reproduce. Here's my testing procedure:
docker run --name gdal-mysql1 -e MYSQL_ROOT_PASSWORD=passwd -e
"MYSQL_ROOT_HOST=%" -p 33060:3306 -d mysql:8.0.34 mysqld
--default-authentication-plugin=mysql_native_password
docker exec gdal-mysql1 sh -c "echo 'CREATE DATABASE test; SELECT
Version()' | mysql -uroot -ppasswd"
printf 'id,WKT\n1,"POINT(168937.186906043 175180.302889316)"\n' > test.csv
ogr2ogr -update
"mysql:test,user=root,password=passwd,port=33060,host=127.0.0.1"
test.csv -select id -nlt point -a_srs EPSG:31370
then opening it with QGIS displays the point on the canvas and the
attribute table. I can also add other points.
Even
Le 16/01/2024 à 20:07, Richard Duivenvoorde via QGIS-Developer a écrit :
> No hints :-) ?
> I now have a live connection to the db, and can reproduce the issue
> here in master on Linux too.
> It's really strange: have a local db, I can even copy features from
> the attribute table to my local table, and THEN they show up
> ogrinfo shows exactly the same information of the db ( using -so).
> coordinates are fine too:
> select coord, ST_AsWKT(coord) from tblQgisProjecten tqp limit 1
> coord |ST_AsWKT(coord)                         |
> POINT (168937.186906043 175180.302889316)|POINT(168937.186906043
> 175180.302889316)|
> could it be in char encoding, or in a strange attribute value? We
> already tried to create a simple view with only coord and ID, but that
> did not show something either.
> As I cannot share the connection info, I'm happy to share my screen or
> so to show this.
> SELECT version();
> version()|
> 8.0.34-26|
> but is an upgraded db, not sure where it came from
> Regards,
> On 1/12/24 15:06, Richard Duivenvoorde via QGIS-Developer wrote:
>> Hi Devs,
>> I was contacted by a company who after upgrading their db and QGIS
>> did NOT see the points anymore.
>> Note that 'all worked' when they used QGIS 3.10 (and an older mysql db)
>> After a MySQL database upgrade, QGIS 3.10 was not able to connect
>> anymore (apparently TLS issues), so they have to use 3.28 or higher.
>> A small export loaded in my local db was OK in QGIS.
>> So in a online meeting, sharing their screen I tried:
>> - opening the db with ogrinfo: all data is visible (POINT(.....))
>> showing correct coords and attributes
>> - loading the table (25000 records) in QGIS: data: EPSG:31370 project
>> EPSG:31370 :
>>      - attribute table shows all records
>>      - mapcanvas empty!
>>      - able to 'zoom to' records (Belgium), but NO points
>> visible/selectable
>> - creating a tiny table with only id and geom column of 3 records:
>> mapcanvas emtpy
>> - export the loaded (but invisible) layer to a geopackage: points AND
>> attributes VISIBLE!
>> - loading the data in dbeaver: all data is shown in the spatial tab
>> There was an encoding issue when exporting to gpkg, but we tried to
>> create a smaller table (very few columns): nothing.
>> Anybody familiar with QGIS and Mysql has an idea what this not
>> showing of any point/geom could be?
>> Any hint appreciated, I plan to try to get a connection to the db
>> myself, but hoping I just miss something obvious...
>> Regards,
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
http://www.spatialys.com
More information about the QGIS-Developer mailing list
