[QGIS-Developer] Strange Mysql (spatial) behaviour: no points visible
Even Rouault
even.rouault at spatialys.com
Sun Jan 28 13:14:23 PST 2024
Update: actually, instead of completely disabling server side spatial
filtering with geographic SRS, I just found a hack... One can use
ST_SRID() to hack a "random" projected CRS, and then things work
So now the OGR mySQL driver will do things like:
select MBRIntersects(ST_GeomFromText('POLYGON((-179 -89, 179 -89, 179
89, -179 89, -179 -89))', 32631), ST_SRID(geometry_column, 32631));
Not pretty but probably a bit better than just client side filtering.
On reflection, I suspect that in MySQL the geometry in geographic SRS
are actually what is called a geography in PostGIS, that is a shape on
the ellipsoid/sphere, where the smallest polygon is selected. And thus
the following request actually returns true:
89, -179 89, -179 -89))', 4326, 'axis-order=long-lat'),
ST_GeomFromText('POINT(-179.5 0)', 4326, 'axis-order=long-lat'));
Le 28/01/2024 à 19:04, Even Rouault via QGIS-Developer a écrit :
> Richard,
> what I don't understand is how you manage to create with ogr2ogr a
> table without explicit SRS with features whose coordinates are not
> compatible of geographic coordinates. As mentioned previously, I do
> get a hard error from ogr2ogr when trying that. Which GDAL version do
> you use?
> The reason for which QGIS doesn't display features is likely it calls
> OGR with SetSpatialFilter() , which the mySQL driver turns into a
> WHERE MBRIntersects(ST_GeomFromText('POLYGON((.....))',
> 'axis-order=long-lat'), `geom_colum_name`) filter. The
> 'axis-order=long-lat' qualifier is because OGR (perhaps mistakenly?)
> identifies the layer as with a geographic SRS, and if the extents of
> the layer aren't compatible of geographic coordinates, that probably
> causes the filter to fail.
> Actually trying the following on a layer without explicit CRS, which
> then causes a undefined geographic CRS to be assigned to the layer
> $ ogrinfo
> "mysql:test,user=root,password=passwd,port=33060,host=127.0.0.1" test
> -spat -180 -90 180 90
> I do get:
> ERROR 1: MySQL error message:Longitude -180.000000 is out of range in
> function st_geomfromtext. It must be within (-180.000000, 180.000000].
> Description: SELECT `OGR_FID`, `SHAPE` `SHAPE`, `id` FROM `test` WHERE
> MBRIntersects(ST_GeomFromText('POLYGON((-180 -90, 180 -90, 180 90,
> -180 90, -180 -90))', 32767, 'axis-order=long-lat'), `SHAPE`)
> So MySQL is super picky on the range of values for spatial filters.
> OK, fair enough, easy to fix by clamping values on the driver side.
> But!!! I also discovered what is to me a MySQL non-sense. It seems
> spatial predicates are totally broken when using geographic SRS.
> select MBRIntersects(ST_GeomFromText('POLYGON((-90 -90, 90 -90, 90 90,
> -90 90, -90 -90))', 4326), ST_GeomFromText('POINT(0 0)', 4326));
> returns true as expected
> But enlarging that extent to almost the whole world with
> or (to test if winding order has some importance)
> select MBRIntersects(ST_GeomFromText('POLYGON((-179 -89, -179 89, 179
> 89, 179 -89, -179 -89))', 4326, 'axis-order=long-lat'),
> returns false !!!! (I've also verified with mysql:8.3.0 image)
> And
> 89, -179 89, -179 -89))', 32631), ST_GeomFromText('POINT(0 0)', 32631));
> Consequence, it seems safer to disable spatial filtering on layers
> with geographic coordinates with MySQL...
> That's just what I've done in https://github.com/OSGeo/gdal/pull/9152
> . Hopefully that will fix those issues with geometries not appearing.
> Obviously performance will not be optimal as spatial filtering will be
> done on OGR client side...
> Even
> Le 28/01/2024 à 14:52, Richard Duivenvoorde a écrit :
>> On 1/23/24 23:21, Even Rouault wrote:
>>> So all in all, no issues on my side...
>> You were off course right :-)
>> I found out how to fix the missing crs in mysql and wrote some info
>> (for future reference) in a comment:
>> https://github.com/qgis/QGIS/issues/55463#issuecomment-1913602140
>> One thing I'm curious for, is why QGIS even after setting the right
>> crs, is not able to show the geom (but IS able to show the
>> attributes). Apparently the features are retrieved. If you receive
>> features from a shp file without crs, after setting it on the layer,
>> all is fine. So myql is different?
>> Did a short try to debug this, but this is above my c++ skills :-)
>> Anyway thanks! And I hope the comment is helpful to mysql peeps
>> Regards,
http://www.spatialys.com
