[QGIS-Developer] Code repository link not updated in Plugin manager and plugin website
Raymond Nijssen
r.nijssen at terglobo.nl
Sun Jan 28 23:45:22 PST 2024
Diving in the code I found a few suspicious lines.
1. In the Django code, there's no mention of "repository" in this list:
https://github.com/qgis/QGIS-Django/blob/6d03c8428abe9df7634bbf810bbcb63709b11d45/qgis-app/plugins/views.py#L908
2. In the QGIS code, the PluginManager seems to look for
"code_repository" and not "repository".
https://github.com/qgis/QGIS/blob/4293d4f1c57614e0a4d3835b7d9f18b3a78bcbd1/src/app/pluginmanager/qgspluginmanager.cpp#L991
Hope this helps fixing it. I currently don't have time to setup the
Django environment and and try fixing it myself.
Raymond
On 26-01-2024 10:03, Raymond Nijssen via QGIS-Developer wrote:
> Dear developers,
> I found some unexpected behaviour in the plugin management.
> I changed the the plugin source code to another github repository and
> wanted to update the links in the plugin metadata.
> 1. When updating the metadata localy, and running the plugin from local
> code, the metadata changelog is updated (so I know QGIS has read the
> metadata.txt) but the links to the code, homepage and tracker are still
> pointing to the old repository.
> 2. After uploading the new version of the plugin to the QGIS plugin
> repository, the links to homepage and tracker are updated but the link
> to the code keeps pointing to the old location. (See screenshot)
> Is this a bug? If so, where should I file it?
> Kind regards and happy QGIS Open Day! :)
> Raymond
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
