[QGIS-Developer] Code repository link not updated in Plugin manager and plugin website
Matthias Kuhn
matthias at opengis.ch
Sun Jan 28 23:53:51 PST 2024
Hi Raymond
Lova is doing some excellent work on the plugin repository recently.
Maybe he will find the time to look into this?
In any case, I think it would be worth opening an issue with your research
on https://github.com/qgis/QGIS-Django/issues to not forget about it and
have a contextualized discussion.
Kind regards
Matthias
On Mon, Jan 29, 2024 at 8:45 AM Raymond Nijssen via QGIS-Developer <
qgis-developer at lists.osgeo.org> wrote:
> Diving in the code I found a few suspicious lines.
> 1. In the Django code, there's no mention of "repository" in this list:
> https://github.com/qgis/QGIS-Django/blob/6d03c8428abe9df7634bbf810bbcb63709b11d45/qgis-app/plugins/views.py#L908
> 2. In the QGIS code, the PluginManager seems to look for
> "code_repository" and not "repository".
> https://github.com/qgis/QGIS/blob/4293d4f1c57614e0a4d3835b7d9f18b3a78bcbd1/src/app/pluginmanager/qgspluginmanager.cpp#L991
> Hope this helps fixing it. I currently don't have time to setup the
> Django environment and and try fixing it myself.
> Raymond
> On 26-01-2024 10:03, Raymond Nijssen via QGIS-Developer wrote:
> > Dear developers,
> > I found some unexpected behaviour in the plugin management.
> > I changed the the plugin source code to another github repository and
> > wanted to update the links in the plugin metadata.
> > 1. When updating the metadata localy, and running the plugin from local
> > code, the metadata changelog is updated (so I know QGIS has read the
> > metadata.txt) but the links to the code, homepage and tracker are still
> > pointing to the old repository.
> > 2. After uploading the new version of the plugin to the QGIS plugin
> > repository, the links to homepage and tracker are updated but the link
> > to the code keeps pointing to the old location. (See screenshot)
> > Is this a bug? If so, where should I file it?
> > Kind regards and happy QGIS Open Day! :)
> > Raymond
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20240129/c6d4d904/attachment.htm>
