[QGIS-Developer] Code repository link not updated in Plugin manager and plugin website
Raymond Nijssen
r.nijssen at terglobo.nl
Mon Jan 29 00:16:53 PST 2024
Thanks for replying Matthias. Done:
https://github.com/qgis/QGIS-Django/issues/350
Lova, let me know if I can help you with testing or something else.
This is the plugin that should get updated:
https://plugins.qgis.org/plugins/wfs_styler/#plugin-versions
Raymond
On 29-01-2024 08:53, Matthias Kuhn wrote:
> Hi Raymond
> Lova is doing some excellent work on the plugin repository recently.
> Maybe he will find the time to look into this?
> In any case, I think it would be worth opening an issue with your
> research on https://github.com/qgis/QGIS-Django/issues
> <https://github.com/qgis/QGIS-Django/issues> to not forget about it and
> have a contextualized discussion.
> Kind regards
> Matthias
> On Mon, Jan 29, 2024 at 8:45 AM Raymond Nijssen via QGIS-Developer
> <qgis-developer at lists.osgeo.org <mailto:qgis-developer at lists.osgeo.org>>
> wrote:
> Diving in the code I found a few suspicious lines.
> 1. In the Django code, there's no mention of "repository" in this list:
> https://github.com/qgis/QGIS-Django/blob/6d03c8428abe9df7634bbf810bbcb63709b11d45/qgis-app/plugins/views.py#L908 <https://github.com/qgis/QGIS-Django/blob/6d03c8428abe9df7634bbf810bbcb63709b11d45/qgis-app/plugins/views.py#L908>
> 2. In the QGIS code, the PluginManager seems to look for
> "code_repository" and not "repository".
> https://github.com/qgis/QGIS/blob/4293d4f1c57614e0a4d3835b7d9f18b3a78bcbd1/src/app/pluginmanager/qgspluginmanager.cpp#L991 <https://github.com/qgis/QGIS/blob/4293d4f1c57614e0a4d3835b7d9f18b3a78bcbd1/src/app/pluginmanager/qgspluginmanager.cpp#L991>
> Hope this helps fixing it. I currently don't have time to setup the
> Django environment and and try fixing it myself.
> Raymond
> On 26-01-2024 10:03, Raymond Nijssen via QGIS-Developer wrote:
> > Dear developers,
> > I found some unexpected behaviour in the plugin management.
> > I changed the the plugin source code to another github repository
> and
> > wanted to update the links in the plugin metadata.
> > 1. When updating the metadata localy, and running the plugin from
> local
> > code, the metadata changelog is updated (so I know QGIS has read the
> > metadata.txt) but the links to the code, homepage and tracker are
> still
> > pointing to the old repository.
> > 2. After uploading the new version of the plugin to the QGIS plugin
> > repository, the links to homepage and tracker are updated but the
> link
> > to the code keeps pointing to the old location. (See screenshot)
> > Is this a bug? If so, where should I file it?
> > Kind regards and happy QGIS Open Day! :)
> > Raymond
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> <mailto:QGIS-Developer at lists.osgeo.org>
> > List info:
> https://lists.osgeo.org/mailman/listinfo/qgis-developer
> <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
> > Unsubscribe:
> QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
