[QGIS-Developer] Code repository link not updated in Plugin manager and plugin website
Lova Andriarimalala
lova at kartoza.com
Mon Jan 29 00:24:54 PST 2024
Dear Raymond and Matthias,
Thank you, Raymond, for the help in fixing the issue.
Thank you also Matthias for the compliment.
I will add the issue to my work planning, take a look at it and let you know.
For now, if it helps, the plugin repo URL can be updated manually from the Edit page in the plugin Manage tab.
Best regards,
Lova
[Image]
Lova Andriarimalala
QGIS Full Stack Developer
Visit http://kartoza.com<http://kartoza.com/> to find out about open source:
* Desktop GIS programming services
* Geospatial web development
* GIS Training
* Consulting Services
Office: +261(0)34 09 524 73<tel:+261340952473>
Date: Monday, 29 January 2024 at 11:16 AM
To: Matthias Kuhn <matthias at opengis.ch>
Cc: qgis-developer at lists.osgeo.org <qgis-developer at lists.osgeo.org>, Lova Andriarimalala <lova at kartoza.com>
Subject: Re: [QGIS-Developer] Code repository link not updated in Plugin manager and plugin website
Thanks for replying Matthias. Done:
https://github.com/qgis/QGIS-Django/issues/350
Lova, let me know if I can help you with testing or something else.
This is the plugin that should get updated:
https://plugins.qgis.org/plugins/wfs_styler/#plugin-versions
Raymond
On 29-01-2024 08:53, Matthias Kuhn wrote:
> Hi Raymond
> Lova is doing some excellent work on the plugin repository recently.
> Maybe he will find the time to look into this?
> In any case, I think it would be worth opening an issue with your
> research on https://github.com/qgis/QGIS-Django/issues
> <https://github.com/qgis/QGIS-Django/issues> to not forget about it and
> have a contextualized discussion.
> Kind regards
> Matthias
> On Mon, Jan 29, 2024 at 8:45 AM Raymond Nijssen via QGIS-Developer
> <qgis-developer at lists.osgeo.org <mailto:qgis-developer at lists.osgeo.org>>
> wrote:
> Diving in the code I found a few suspicious lines.
> 1. In the Django code, there's no mention of "repository" in this list:
> https://github.com/qgis/QGIS-Django/blob/6d03c8428abe9df7634bbf810bbcb63709b11d45/qgis-app/plugins/views.py#L908 <https://github.com/qgis/QGIS-Django/blob/6d03c8428abe9df7634bbf810bbcb63709b11d45/qgis-app/plugins/views.py#L908>
> 2. In the QGIS code, the PluginManager seems to look for
> "code_repository" and not "repository".
> https://github.com/qgis/QGIS/blob/4293d4f1c57614e0a4d3835b7d9f18b3a78bcbd1/src/app/pluginmanager/qgspluginmanager.cpp#L991 <https://github.com/qgis/QGIS/blob/4293d4f1c57614e0a4d3835b7d9f18b3a78bcbd1/src/app/pluginmanager/qgspluginmanager.cpp#L991>
> Hope this helps fixing it. I currently don't have time to setup the
> Django environment and and try fixing it myself.
> Raymond
> On 26-01-2024 10:03, Raymond Nijssen via QGIS-Developer wrote:
> > Dear developers,
> > I found some unexpected behaviour in the plugin management.
> > I changed the the plugin source code to another github repository
> and
> > wanted to update the links in the plugin metadata.
> > 1. When updating the metadata localy, and running the plugin from
> local
> > code, the metadata changelog is updated (so I know QGIS has read the
> > metadata.txt) but the links to the code, homepage and tracker are
> still
> > pointing to the old repository.
> > 2. After uploading the new version of the plugin to the QGIS plugin
> > repository, the links to homepage and tracker are updated but the
> link
> > to the code keeps pointing to the old location. (See screenshot)
> > Is this a bug? If so, where should I file it?
> > Kind regards and happy QGIS Open Day! :)
> > Raymond
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> <mailto:QGIS-Developer at lists.osgeo.org>
> > List info:
> https://lists.osgeo.org/mailman/listinfo/qgis-developer
> <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
> > Unsubscribe:
> QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20240129/b7d3e302/attachment-0001.htm>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20240129/b7d3e302/attachment-0001.jpg>
