[QGIS-Developer] Request for Initial Feedback on Layer Atlas Plugin
Jean-Baptiste Peter
jbpeter at outlook.com
Tue Jul 9 06:19:37 PDT 2024
Did you install PyQtWebEngine “manually” using pip install? If that is the case, it will not be bundled with qgis and needs to be imported from Pyqt directly:
‘from qgis.PyQt.QtWebEngineWidgets import QWebEngineView’
needs to be replaced by :
‘from PyQt5.QtWebEngineWidgets import QWebEngineView’
As of now, the only way to get this working out of the box is to install qgis with Osgeo4W installer.
Best,
Jean-Baptiste Peter
Sent: Tuesday, July 9, 2024 3:01 PM
To: jbpeter at outlook.com
Cc: qgis-developer at lists.osgeo.org
Subject: RE: Re:[QGIS-Developer] Request for Initial Feedback on Layer Atlas Plugin
OSGeo4W Shell:
C:\Program Files\QGIS 3.38.0>pip list
PyQtWebEngine 5.15.6
PyQtWebEngine-Qt5 5.15.2
I've PyQtWebEngine dependancy
Before release make sure it can work.
Andrea Ordonselli
OpenGIS.it
Da "Jean-Baptiste Peter" jbpeter at outlook.com<mailto:jbpeter at outlook.com>
A "info at opengis.it<mailto:info at opengis.it>" info at opengis.it<mailto:info at opengis.it>
Cc "qgis-developer at lists.osgeo.org<mailto:qgis-developer at lists.osgeo.org>" qgis-developer at lists.osgeo.org<mailto:qgis-developer at lists.osgeo.org>
Data Tue, 9 Jul 2024 12:51:12 +0000
Oggetto RE: Re:[QGIS-Developer] Request for Initial Feedback on Layer Atlas Plugin
I don’t think this will work with qgis installed using .msi as the installer does not include PyQtWebEngine.
It should work out of the box using qgis osgeo4W installer which includes the latest version of PyQtWebEngine (5.15.6) which is required for the plugin to work. There should not be any other dependencies.
Best,
Jean-Baptiste Peter
From: info at opengis.it<mailto:info at opengis.it> <info at opengis.it<mailto:info at opengis.it>>
Sent: Tuesday, July 9, 2024 2:41 PM
To: jbpeter at outlook.com<mailto:jbpeter at outlook.com>
Cc: qgis-developer at lists.osgeo.org<mailto:qgis-developer at lists.osgeo.org>
Subject: Re:[QGIS-Developer] Request for Initial Feedback on Layer Atlas Plugin
In a clean install of QGIS 3.38.0, installing the package via the zip downloaded from github, the plugin does not work. The icon is not visible and if I close and reopen QGIS it does not start.
No message in python console.
What additional dependencies does it need?
I use win10 and I installed QGIS via .msi
Andrea Ordonselli
OpenGIS.it
Da "QGIS-Developer" qgis-developer-bounces at lists.osgeo.org<mailto:qgis-developer-bounces at lists.osgeo.org>
A "qgis-developer at lists.osgeo.org<mailto:qgis-developer at lists.osgeo.org>" qgis-developer at lists.osgeo.org<mailto:qgis-developer at lists.osgeo.org>
Cc
Data Tue, 9 Jul 2024 09:16:22 +0000
Oggetto [QGIS-Developer] Request for Initial Feedback on Layer Atlas Plugin
Dear Developers,
I have been experimenting for a while with QWebEngineView which opens a lot of possibilities for plugin development and started to implement a new plugin to explore and share layers directly from QGIS by simply dragging and dropping them from the layer panel.
Here is a short screen recording to see how it works:
https://www.youtube.com/watch?v=k5k74faBJKo
As there are a few things remaining to do, the plugin not yet uploaded to the plugin repo but it is mostly functional. Initial feedback from interested testers would be very useful!
Here is the GitHub repository to try it out:
https://github.com/jbp35/layer-atlas-plugin/
Thank you for your time and assistance!
Best regards,
Jean-Baptiste Peter
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20240709/3d96275e/attachment-0001.htm>
