[QGIS-Developer] Compiling QGIS 3.38 on windows 11 with MSVC2019.
Paul N surveykshak at gmail.com
Wed Jul 17 01:55:56 PDT 2024
I am trying to compile QGIS 3.38 on windows 11 with MSVC2019 and getting
the following error at first level.
Selecting Windows SDK version 10.0.22621.0 to target Windows 10.0.22631.
QGIS version: 3.38.0 Grenoble (33800)
Found OpenCL C++ headers: C:/OSGeo4W/include
Could not find GRASS 7
Found GRASS 8: C:/OSGeo4W/apps/grass/grass83 (8.3.2, off_t size = 8)
CMake Warning at cmake/FindProj.cmake:21 (find_package):
* Could not find a configuration file for package "PROJ" that is compatible
with requested version "".*
The following configuration files were considered but not accepted:
C:/OSGeo4W/lib/cmake/proj/proj-config.cmake, version: 9.4.0
(MSVC_TOOLSET_VERSION = 143)
Call Stack (most recent call first):
CMakeLists.txt:361 (find_package)
Found Proj: C:/OSGeo4W/lib/proj.lib version 9 (9.4.0)
Found Proj: PROJ_DIR-NOTFOUND
Found Geos: 3.12.2 C:/OSGeo4W/lib/cmake/GEOS
Found GDAL: 3.9.1 C:/OSGeo4W/apps/gdal/lib/cmake/gdal
Found Spatialindex: C:/OSGeo4W/lib/spatialindex-64.lib
Found libzip: C:/OSGeo4W/lib/zip.lib
Found Sqlite3: C:/OSGeo4W/lib/sqlite3_i.lib
Found Protobuf: C:/OSGeo4W/lib/libprotobuf.lib
Found zlib: C:/OSGeo4W/lib/zlib.lib
Found exiv2: C:/OSGeo4W/lib/exiv2.lib
Checking for one of the modules 'spatialite'
Found SpatiaLite: C:/OSGeo4W/lib/spatialite_i.lib
Qt WebKit support enabled
Using embedded laz-perf
Found ZSTD: C:/OSGeo4W/lib/zstd.lib
Found PDAL: pdalcpp (2.6.3)
Found Draco: C:/OSGeo4W/lib/draco.lib (1.5.7)
PDF4Qt disabled
QtWebEngine support DISABLED.
Found Qt version: 5.15.13
Found QScintilla2: C:/OSGeo4W/apps/Qt5/lib/qscintilla2_qt5.lib (2.14.1)
Found Qwt: C:/OSGeo4W/apps/Qt5/lib/qwt.lib (6.2.0)
Found QCA: C:/OSGeo4W/apps/Qt5/lib/qca-qt5.lib (2.3.8)
Pedantic compiler settings enabled
-- Found Python executable: C:/OSGeo4W/bin/python3.exe (version 3.12.4)
-- Python library: C:/OSGeo4W/apps/Python312/libs/python312.lib
-- Python site-packages: C:\OSGeo4W\apps\Python312\Lib\site-packages
Found SIP version: 6.8.3
Found PyQt5 version: 5.15.10
Found QScintilla2 PyQt module: 2.14.1
Using PROJ >= 6 srs database.
QtGamepad not enabled - disabling bindings for derived classes
Ctest Binary Directory set to: C:/repo/QGIS_3.38/build2019/output/bin
Configuring done (19.2s)
*Unable to find the PROJ directory.*
Any help?
Regards
Paul N
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20240717/cae5ed68/attachment.htm>
More information about the QGIS-Developer mailing list
