[QGIS-Developer] Get current QDockWidget in specific location
Germán Carrillo
carrillo.german at gmail.com
Thu Jun 13 19:56:25 PDT 2024
BTW, note that you can omit the 3rd parameter in addTabifiedDockWidget()
and your dock widget will be tabified in that location, no matter which
dock widget is already placed there.
iface.addTabifiedDockWidget(Qt.RightDockWidgetArea, my_own_dock_widget)
On the other hand, if you really need to get existent dock widgets in a
given location, this function will do it:
def dockWidgetsInArea(area):
dwa = []
for dw in iface.mainWindow().findChildren(QDockWidget):
if dw.isVisible() and iface.mainWindow().dockWidgetArea(dw) == area:
dwa.append(dw)
return dwa
Use it in this way:
dws = dockWidgetsInArea(Qt.RightDockWidgetArea)
Regards,
Germán
El jue, 13 jun 2024 a las 21:25, Germán Carrillo (<carrillo.german at gmail.com>)
escribió:
> Hi Luke,
> you can get a list of all QDockWidget objects in this way:
> From there you could get objectNames, whether the dock widget is visible
> or not, its allowed areas and window title, among other properties.
> The objectName is relevant, because you can pass it as the 3rd parameter
> to addTabifiedDockWidget(), in this way:
> iface.addTabifiedDockWidget(Qt.RightDockWidgetArea, my_own_dock_widget,
> ["ProcessingToolbox"])
> In that way, your dock widget will be tabified taking the
> ProcessingToolbox dock widget as a reference. If you want your dock widget
> on top, pass an extra parameter raiseTab as True.
> I hope this helps.
> Regards,
> Germán
> El mié, 12 jun 2024 a las 20:22, Catania, Luke A ERDC-RDE-GRL-VA CIV via
> QGIS-Developer (<qgis-developer at lists.osgeo.org>) escribió:
>> How can I get the reference to a QDockWidget that is already docked. I
>> want to call tabifyDockWidget so I can add a new QDockWidget to the same
>> location. The first is already in place from exsiting code and I know I
>> can probably create a getter method on the code that adds the first doc
>> widget but I was hoping not add anything to that code and use some existing
>> built in method that would allow be to specify a dock widget location and
>> return a reference to what is currently docked at that location.
>> Thanks,
>> Luke
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> |\__
> (:>__)(
> Soluciones Geoinformáticas Libres
> http://geotux.tuxfamily.org/
> https://twitter.com/GeoTux2
> <http://twitter.com/GeoTux2>
|\__
(:>__)(
https://twitter.com/GeoTux2 <http://twitter.com/GeoTux2>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20240613/9c4d87fa/attachment.htm>
