[QGIS-Developer] Build problems using install instructions
Tony Bazeley tonyb at tonyb.id.au
Fri May 3 06:40:44 PDT 2024
Not having much luck I'm afraid
I've done a completely new reinstall and followed the instructions down to
git fetch /qgis/master
at this point
*~/dev/cpp/QGIS/release-3_36*$ git remote -v
origin  https://github.com/qgis/QGIS.git (fetch)
origin  https://github.com/qgis/QGIS.git (push)
and git status
On branch release-3_36
nothing to commit, working tree clean
then
git fetch qgis/master
git fetch qgis
git fetch QGIS
git fetch qgis/QGIS
git fetch master
all return:
fatal:  does not appear to be a git repository
fatal: Could not read from remote repository.
Please make sure you have the correct access rights
and the repository exists
git fetch https://github.com/qgis/QGIS.git
From https://github.com/qgis/QGIS
* branch                    HEAD       -> FETCH_HEAD
I think this means get all the changes that have occurred prior to doing the next step,and
given this is a fresh install no changes have occurred - but I may well be wrong.
then
git rebase -i  https://github.com/qgis/QGIS.git and
git rebase -i qgis/master
both yield: fatal: invalid upstream 'https://github.com/qgis/QGIS.git'
and at this point
git status
I've worked through some of the likely problems at https://thelinuxcode.com/git-push-error-repository-not-found-fixed/[1] and all seems to be OK except for permission errors,
although none of those raised are working with branches.
Regards
Tony
gitOn Thursday 2 May 2024 5:19:28 PM ACST Julien Cabieces via QGIS-Developer wrote:
> > fatal: 'qgis/master' does not appear to be a git repository
> probably this would be better
> git fetch qgis
> Hoping that qgis is the remote that target your QGIS git repository. You
> can check this with
> git remote -v
> Regards,
> Julien
> > Thanks Julien and Richard
> > I gave it another shot on the weekend with a clean build which was
> > successful.
> > But I'm now thinking I'd be better suited to using the latest stable
> > version, 3_36 in this case.
> > My interpretation of the instructions,
> > git commit
> > git worktree add ../my_new_functionality
> > cd ../my_new_functionality
> > # only keep the commits to be pushed
> > git push -u my_own_repo my_new_functionality
> > is:
> > git commit
> > git worktree add ../release-3_36
> > cd ../release-3_36
> > git push -u QGIS release-3_36
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20240503/6d64d0bb/attachment-0001.htm>
More information about the QGIS-Developer mailing list
