[QGIS-Developer] Build problems using install instructions
Greg Troxel
gdt at lexort.com
Fri May 3 07:41:41 PDT 2024
Tony Bazeley via QGIS-Developer <qgis-developer at lists.osgeo.org> writes:
> Not having much luck I'm afraid
> I've done a completely new reinstall and followed the instructions down to
> git fetch /qgis/master
Can you point to the instructions? This all seems very strange.
I would just expect to clone the repo and checkout the branch you want.
(I also don't follow what you are rebasing if you are just trying to
build from git.)
you left out os/version/etc. and didn't show the clone command.
Also, are you already quite familiar with git, and have you successfully
cloned, made changes on a branch, pushed it, with sometthing else?
