[QGIS-Developer] Build problems using install instructions -building branches
Even Rouault
even.rouault at spatialys.com
Mon May 20 16:43:20 PDT 2024
The procedure at
https://github.com/qgis/QGIS/blob/master/INSTALL.md#39-building-different-branches
is more for developers to create feature branches and submit pull requests
To just built the release-3_36 branch,
Assuming that "origin" is your remote pointing to
https://github.com/qgis/qgis (if not "git remote add origin
https://github.com/qgis/qgis", or replace origin by the name of the
remote that points to https://github.com/qgis/qgis )
from your release-3_36 directory:
git fetch origin release-3_36
git reset --hard origin/release-3_36 # make sure you have no local
changes before doing that!
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20240521/54f267fc/attachment.htm>
