[QGIS-Developer] Build problems using install instructions -building branches
    DelazJ
    delazj at gmail.com
    Wed May 22 00:40:26 PDT 2024
These instructions in the INSTALL.md lack a context and are quite
confusing there IMHO. They should probably go to the developers guide
(https://docs.qgis.org/testing/en/docs/developers_guide/git.html#development-in-branches).
It is more a git/development tip than a build instructions.
Regards,
Harrissou
Le 21/05/2024 à 01:43, Even Rouault via QGIS-Developer a écrit :
> Hi,
> The procedure at
> https://github.com/qgis/QGIS/blob/master/INSTALL.md#39-building-different-branches
> is more for developers to create feature branches and submit pull requests
> To just built the release-3_36 branch,
> Assuming that "origin" is your remote pointing to
> https://github.com/qgis/qgis (if not "git remote add origin
> https://github.com/qgis/qgis", or replace origin by the name of the
> remote that points to https://github.com/qgis/qgis )
> from your release-3_36 directory:
> git fetch origin release-3_36
> git reset --hard origin/release-3_36    # make sure you have no local
> changes before doing that!
> Even
> http://www.spatialys.com
> My software is free, but my time generally not.
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20240522/9871a987/attachment.htm>
