[QGIS-Developer] Broken doctest infrastructure for Cookbook
Richard Duivenvoorde
rdmailings at duif.net
Wed May 22 06:03:55 PDT 2024
Hi Harrissou,
Yes, looking at
https://github.com/qgis/pyqgis/actions/runs/8954239354/job/24593642123#step:3:106
It looks like you are right. Apparently the qgis/qgis container image has been upgraded to a version which does you not let install python packages via pip in the global Python.
Given we probably do want to use that container, we can do 2 things:
- I think/hope we can do that by using --break-system-packages as pip argument there..
- OR in the qgis/qgis container, remove the file /usr/lib/python3.11/EXTERNALLY-MANAGED
- either make sure that we do all the work in a virtual environment (meaning fix: https://github.com/qgis/pyqgis/blob/master/Dockerfile)
I started to add the first solution in the Docker file.
But to make this future proof, we need to go to the third solution...
Regards,
On 5/22/24 09:49, DelazJ via QGIS-Developer wrote:
> Hello devs,
> me again, for requesting a fix for the docs, but this time the issue also affects the pyQGIS documentation, broken for already two weeks (https://github.com/qgis/pyqgis/issues/139 and https://github.com/qgis/pyqgis/actions). I suspect the new qgis/QGIS docker recipe to be the root cause, maybe a new Python or OS version that applies PEP 668; unability to execute pip in a docker as we used do. I've tried a number of recipes I found in the Internet, but... I've never been comfortable with docker, so failed.
> A charitable person to help get fix the docs sites? Or one (I could still reproduce the fix on the other)? Thanks.
> Regards,
> Harrissou.
> PS: Thanks Nyall for helping on the previous issue.
> Le 19/04/2024 à 09:31, DelazJ a écrit :
>> Hi devs,
>> May I request some help on this issue (https://github.com/qgis/QGIS-Documentation/issues/9010), please? It happens for more than a week and makes every single commit fail. As noone on the docs side has touched the cookbook for a long time, I suspect the issue comes directly from master or its libraries (3.34 is just fine).
>> Thanks,
>> Harrissou
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
