[QGIS-Developer] Qt WebEngine in QGIS 3.36
Enrico Ferreguti
enricofer at gmail.com
Mon May 27 12:09:50 PDT 2024
Update on this: The flatpak QGIS 3.36.3 with Qt 5.15.10 has no issues. I'll
go with this.
Thank you very much for the support.
Il giorno lun 27 mag 2024 alle ore 20:23 Nyall Dawson <
nyall.dawson at gmail.com> ha scritto:
> On Mon, 27 May 2024, 11:02 pm Enrico Ferreguti, <enricofer at gmail.com>
> wrote:
>> Hi Nyall
>> the installed qt webengine is the following:
>> $ apt list --installed | grep webengine
>> libqt5webengine-data/jammy,jammy,now 5.15.9+dfsg-1 all [installato,
>> automatico]
>> libqt5webengine5/jammy,now 5.15.9+dfsg-1 amd64 [installato]
>> libqt5webenginecore5/jammy,now 5.15.9+dfsg-1 amd64 [installato,
>> automatico]
>> libqt5webenginewidgets5/jammy,now 5.15.9+dfsg-1 amd64 [installato,
>> automatico]
>> python3-pyqt5.qtwebengine/jammy,now 5.15.5-1 amd64 [installato,
>> automatico]
>> qml-module-qtwebengine/jammy,now
> You need python qt webengine 5.15.6 for use in qgis. See
> https://www.riverbankcomputing.com/static/Downloads/PyQtWebEngine/ChangeLog-5.15.7.dev2405031852
> The required change is "Allow Qt.AA_ShareOpenGLContexts to be specified
> before a
> QCoreApplication is created to allow PyQtWebEngineWidgets to be
> imported.".
> I'd file a bug for your distro and request and update.
> Nyall
>> qtwebengine5-dev/jammy,now 5.15.9+dfsg-1 amd64 [installato]
>> qtwebengine5-doc/jammy,jammy,now 5.15.9+dfsg-1 all [installato,
>> automatico]
>> Thanks for the support.
>> Il giorno lun 27 mag 2024 alle ore 00:21 Nyall Dawson <
>>> On Sun, 26 May 2024 at 18:42, Enrico Ferreguti via QGIS-Developer
>>> <qgis-developer at lists.osgeo.org> wrote:
>>> > Dear QGIS developers, I would need your support to update my plugins.
>>> > I read that Qt WebEngine, from QGIS
>>> > 3.36.3-Maidenhead, QT 5.15.3, is available for plugins:
>>> https://changelog.qgis.org/en/entry/2607
>>> Which version of the python webengine library is installed? I suspect
>>> this package is out of date and needs an update.
>>> Nyall
>>> > But on Ubuntu Jammy LTS 22.04 and a fresh QGIS 3.36.3-Maidenhead with
>>> QT 5.15.3, when I try to import from QT5:
>>> > from PyQt5.QtWebEngineWidgets import QWebEngineView, QWebEnginePage,
>>> > I get an exception:
>>> > ImportError: QtWebEngineWidgets must be imported before a
>>> QCoreApplication instance is created
>>> > and when I do the same from python3 in bash I get no exceptions
>>> > Where Am I wrong? Is there something different to do for importing
>>> QtWebEngineWidgets ?
>>> > Can you point me to a running example?
>>> > Thank you very much.
>>> > Enrico Ferreguti
>>> > _______________________________________________
>>> > QGIS-Developer mailing list
>>> > QGIS-Developer at lists.osgeo.org
>>> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20240527/303a5ec1/attachment.htm>
