[QGIS-Developer] How to deal with QGIS plugins which install additional packages
Matthias Kuhn matthias at opengis.ch
Wed Oct 23 04:58:26 PDT 2024
This approach will work fine within limitations, as soon as multiple
plugins ship the same library things become risky as there is no isolation
between libraries.
For python libraries, this may be caused by singletons being used and for
native libraries (as in this example), it's easy to cause crashes by
multiple versions of the same library exporting the same symbols being
loaded in parallel.
That being said: it will work fine in many cases, but I wouldn't promote
this as "best practice". After all, python invented virtualenvs for good
reasons -- each process will always run one environment (potentially
composed of multiple cascading virtual envs, but never multiple "parallel"
envs).
Cheers
Matthias
On Wed, Oct 23, 2024 at 1:31 PM John Stevenson - BGS via QGIS-Developer <
qgis-developer at lists.osgeo.org> wrote:
> Hi,
> Mergin Maps plugin also packages the dependencies (including the geodiff
> binary) into the plugin itself.  I’m not sure how it handles cross-platform
> differences, though.
> Plugin:
> https://plugins.qgis.org/plugins/Mergin/#plugin-details
> GitHub Actions code:
> https://github.com/MerginMaps/qgis-plugin/blob/ef0b2502ddb4bcbc1670b0d82832e93b658c18b2/.github/workflows/packages.yml#L116
> Cheers,
> John
> *From:* QGIS-Developer <qgis-developer-bounces at lists.osgeo.org> *On
> Behalf Of *Joona Laine via QGIS-Developer
> *Sent:* 23 October 2024 10:58
> *To:* info at opengis.it
> *Cc:* qgis-developer <qgis-developer at lists.osgeo.org>
> *Subject:* Re: [QGIS-Developer] How to deal with QGIS plugins which
> One alternative way of managing the dependencies is to package the
> non-binary runtime dependencies (including licenses) with the plugin. This
> also tackles the problem with different versions of the same requirements
> between multiple plugins. There is a tool for that
> https://github.com/nlsfi/qgis-plugin-dev-tools which also has many more
> useful features for developing QGIS plugins.
> One example of plugins using this tool is pickLayer (
> https://plugins.qgis.org/plugins/pickLayer/) which bundles
> https://github.com/GispoCoding/qgis_plugin_tools with it.
> What do you think about this approach?
> Regards,
> Joona
> ke 23. lokak. 2024 klo 12.01 Info O.GIS via QGIS-Developer <
> qgis-developer at lists.osgeo.org> kirjoitti:
> I also did a similar thing in qgis2web plugin.
> I explained to the user that he can install qtwebengine to get the latest
> features and to do so he will have to click on a button that indicates that
> an installation will start.
> Here is the screen:
> Could it be okay?
> The code:
> *try:*
> *        if system == 'Windows':*
> *            pip_exec = os.path.join(sysconfig.get_path("scripts"),
> "pip3")*
> *            env = os.environ.copy()*
> *            if full_proxy_url:*
> *                env['http_proxy'] = full_proxy_url*
> *                env['https_proxy'] = full_proxy_url*
> *            subprocess.check_call([pip_exec, "install", "--upgrade",
> "PyQtWebEngine==5.15.6"], env=env)*
> *        elif system == 'Linux':*
> *            subprocess.check_call(["sudo", "apt-get", "install",
> "python3-pyqt5.qtwebengine"])*
> *        elif system == 'Darwin':  # macOS*
> *            subprocess.check_call(["brew", "install", "pyqt5"])*
> *Andrea Ordonselli*
> *O.GIS - opengis.it <http://opengis.it>*
> Da "QGIS-Developer" qgis-developer-bounces at lists.osgeo.org
> A "Matthias Kuhn" matthias at opengis.ch
> Cc "Thomas B via QGIS-Developer" qgis-developer at lists.osgeo.org
> Data Wed, 23 Oct 2024 16:16:43 +1000
> Oggetto Re: [QGIS-Developer] How to deal with QGIS plugins which install
> additional packages
> On Wed, 23 Oct 2024, 4:07 pm Matthias Kuhn, <matthias at opengis.ch> wrote:
> On Wed, Oct 23, 2024 at 2:49 AM Nyall Dawson via QGIS-Developer <
> On Wed, 23 Oct 2024, 9:20 am Greg Troxel via QGIS-Developer, <
> Thomas B via QGIS-Developer <qgis-developer at lists.osgeo.org> writes:
> > Dear QGIS-Developers,
> > Are there any guidelines from the QGIS project regarding whether a QGIS
> > plugin is allowed to autonomously install required packages using PIP or
> > similar tools without manual installation by the user?
> > While this might seem convenient, I see it as a potential security risk,
> > especially if the user is not explicitly informed about what is happening
> > in the background.
> Agreed this is not ok.  I think a plugin downloading anything to be
> executed or interpreted should be entirely prohibited.
> +1 . This practice should lead to a plugin being removed from the
> repositories.
> (Possibly we could do something on the code side too, eg by monkey
> patching over subprocess/etc and explicitly blocking execution of sip, with
> a developer-friendly exception stating this policy. It'd be easy for
> someone motivated to circumvent, but could at least be used to advise
> plugin developers that this is not acceptable practice...)
> We've tried to come up with a more transparent approach with support for
> requirements.txt (see https://github.com/opengisch/qpip). It is using pip
> but with a frontend which informs the user and lets him confirm an eventual
> installation.
> Is this approach generally acceptable?
> Well, I definitely trust yourself/OpenGIS significantly more then other
> random plugin developers 👍
> I would personally feel safest if this was something officially endorsed,
> with an explicit allow list of acceptable packages.
> Nyall
> Matthias
> Nyall
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> This email and any attachments are intended solely for the use of the
> named recipients. If you are not the intended recipient you must not use,
> disclose, copy or distribute this email or any of its attachments and
> should notify the sender immediately and delete this email from your
> system. UK Research and Innovation (UKRI) has taken every reasonable
> precaution to minimise risk of this email or any attachments containing
> viruses or malware but the recipient should carry out its own virus and
> malware checks before opening the attachments. UKRI does not accept any
> liability for any losses or damages which the recipient may sustain due to
> presence of any viruses.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20241023/e69d7edb/attachment-0001.htm>
More information about the QGIS-Developer mailing list
