[QGIS-Developer] How to deal with QGIS plugins which install additional packages
Joona Laine
joona.p.laine at gmail.com
Wed Oct 23 05:09:58 PDT 2024
Qgis-plugin-dev-tools approach solves this problem by vendoring the
packages and rewriting
<https://github.com/nlsfi/qgis-plugin-dev-tools/blob/2df5c099c9c86700e0d323c67243902f1df46fce/src/qgis_plugin_dev_tools/build/rewrite_imports.py#L10>the
imports so that "import module.x.y" imports are rewritten in a vendored
format: "import something._vendor.module.x.y". Thus multiple plugins can
have different versions of packages since they all import their own
vendored versions.
Joona
ke 23. lokak. 2024 klo 14.58 Matthias Kuhn <matthias at opengis.ch> kirjoitti:
> Hi,
> This approach will work fine within limitations, as soon as multiple
> plugins ship the same library things become risky as there is no isolation
> between libraries.
> For python libraries, this may be caused by singletons being used and for
> native libraries (as in this example), it's easy to cause crashes by
> multiple versions of the same library exporting the same symbols being
> loaded in parallel.
> That being said: it will work fine in many cases, but I wouldn't promote
> this as "best practice". After all, python invented virtualenvs for good
> reasons -- each process will always run one environment (potentially
> composed of multiple cascading virtual envs, but never multiple "parallel"
> envs).
> Cheers
> Matthias
> On Wed, Oct 23, 2024 at 1:31 PM John Stevenson - BGS via QGIS-Developer <
> qgis-developer at lists.osgeo.org> wrote:
>> Hi,
>> Mergin Maps plugin also packages the dependencies (including the geodiff
>> binary) into the plugin itself. I’m not sure how it handles cross-platform
>> differences, though.
>> Plugin:
>> https://plugins.qgis.org/plugins/Mergin/#plugin-details
>> GitHub Actions code:
>> https://github.com/MerginMaps/qgis-plugin/blob/ef0b2502ddb4bcbc1670b0d82832e93b658c18b2/.github/workflows/packages.yml#L116
>> Cheers,
>> John
>> *From:* QGIS-Developer <qgis-developer-bounces at lists.osgeo.org> *On
>> Behalf Of *Joona Laine via QGIS-Developer
>> *Sent:* 23 October 2024 10:58
>> *To:* info at opengis.it
>> *Cc:* qgis-developer <qgis-developer at lists.osgeo.org>
>> *Subject:* Re: [QGIS-Developer] How to deal with QGIS plugins which
>> One alternative way of managing the dependencies is to package the
>> non-binary runtime dependencies (including licenses) with the plugin. This
>> also tackles the problem with different versions of the same requirements
>> between multiple plugins. There is a tool for that
>> https://github.com/nlsfi/qgis-plugin-dev-tools which also has many more
>> useful features for developing QGIS plugins.
>> One example of plugins using this tool is pickLayer (
>> https://plugins.qgis.org/plugins/pickLayer/) which bundles
>> https://github.com/GispoCoding/qgis_plugin_tools with it.
>> What do you think about this approach?
>> Regards,
>> Joona
>> ke 23. lokak. 2024 klo 12.01 Info O.GIS via QGIS-Developer <
>> qgis-developer at lists.osgeo.org> kirjoitti:
>> I also did a similar thing in qgis2web plugin.
>> I explained to the user that he can install qtwebengine to get the latest
>> features and to do so he will have to click on a button that indicates that
>> an installation will start.
>> Here is the screen:
>> Could it be okay?
>> The code:
>> *try:*
>> * if system == 'Windows':*
>> * pip_exec = os.path.join(sysconfig.get_path("scripts"),
>> "pip3")*
>> * env = os.environ.copy()*
>> * if full_proxy_url:*
>> * env['http_proxy'] = full_proxy_url*
>> * env['https_proxy'] = full_proxy_url*
>> * subprocess.check_call([pip_exec, "install", "--upgrade",
>> "PyQtWebEngine==5.15.6"], env=env)*
>> * elif system == 'Linux':*
>> * subprocess.check_call(["sudo", "apt-get", "install",
>> "python3-pyqt5.qtwebengine"])*
>> * elif system == 'Darwin': # macOS*
>> * subprocess.check_call(["brew", "install", "pyqt5"])*
>> *Andrea Ordonselli*
>> *O.GIS - opengis.it <http://opengis.it>*
>> Da "QGIS-Developer" qgis-developer-bounces at lists.osgeo.org
>> A "Matthias Kuhn" matthias at opengis.ch
>> Cc "Thomas B via QGIS-Developer" qgis-developer at lists.osgeo.org
>> Data Wed, 23 Oct 2024 16:16:43 +1000
>> Oggetto Re: [QGIS-Developer] How to deal with QGIS plugins which install
>> additional packages
>> On Wed, 23 Oct 2024, 4:07 pm Matthias Kuhn, <matthias at opengis.ch> wrote:
>> On Wed, Oct 23, 2024 at 2:49 AM Nyall Dawson via QGIS-Developer <
>> On Wed, 23 Oct 2024, 9:20 am Greg Troxel via QGIS-Developer, <
>> Thomas B via QGIS-Developer <qgis-developer at lists.osgeo.org> writes:
>> > Dear QGIS-Developers,
>> > Are there any guidelines from the QGIS project regarding whether a QGIS
>> > plugin is allowed to autonomously install required packages using PIP or
>> > similar tools without manual installation by the user?
>> > While this might seem convenient, I see it as a potential security risk,
>> > especially if the user is not explicitly informed about what is
>> happening
>> > in the background.
>> Agreed this is not ok. I think a plugin downloading anything to be
>> executed or interpreted should be entirely prohibited.
>> +1 . This practice should lead to a plugin being removed from the
>> repositories.
>> (Possibly we could do something on the code side too, eg by monkey
>> patching over subprocess/etc and explicitly blocking execution of sip, with
>> a developer-friendly exception stating this policy. It'd be easy for
>> someone motivated to circumvent, but could at least be used to advise
>> plugin developers that this is not acceptable practice...)
>> We've tried to come up with a more transparent approach with support for
>> requirements.txt (see https://github.com/opengisch/qpip). It is using
>> pip but with a frontend which informs the user and lets him confirm an
>> eventual installation.
>> Is this approach generally acceptable?
>> Well, I definitely trust yourself/OpenGIS significantly more then other
>> random plugin developers 👍
>> I would personally feel safest if this was something officially endorsed,
>> with an explicit allow list of acceptable packages.
>> Nyall
>> Matthias
>> Nyall
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> This email and any attachments are intended solely for the use of the
>> named recipients. If you are not the intended recipient you must not use,
>> disclose, copy or distribute this email or any of its attachments and
>> should notify the sender immediately and delete this email from your
>> system. UK Research and Innovation (UKRI) has taken every reasonable
>> precaution to minimise risk of this email or any attachments containing
>> viruses or malware but the recipient should carry out its own virus and
>> malware checks before opening the attachments. UKRI does not accept any
>> liability for any losses or damages which the recipient may sustain due to
>> presence of any viruses.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20241023/2a82264b/attachment-0001.htm>
