[QGIS-Developer] Is there a recommended GDAL version for QGIS 3.34?
Even Rouault
even.rouault at spatialys.com
Tue Sep 3 11:32:13 PDT 2024
For operational uses, I would say the latter is the better. For
regression test purposes, some tests might perhaps need
tweaking/skipping depending on the GDAL version. CI uses GDAL 3.4.1 for
QT5 testing and 3.7.3 for QT6 testing.
> Background/motivation for asking: I have tried compiling different
versions of QGIS against different versions of GDAL, but some unit tests
keep causing segmentation faults. Could a segmentation fault be caused
by a mismatch of version of a dependent library like GDAL?
Nobody can guess that. You need to provide much more details: which
test(s), stack trace when it crashes, etc.
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20240903/bbcb5576/attachment.htm>
