[QGIS-Developer] Compiling QGIS with Debug: error with pdal_wrench and gdal_fwd.h
Jorge Gustavo Rocha jgr at di.uminho.pt
Wed Apr 2 08:36:03 PDT 2025
Hi devs,
I'm not able to compile QGIS with -DCMAKE_BUILD_TYPE=Debug. No problem
to build QGIS with -DCMAKE_BUILD_TYPE=Release.
I think this happens since the change in GDAL's gdal_fwd.h to support:
#if defined(GDAL_DEBUG)
/** Opaque type for a spatial reference system */
typedef struct OGRSpatialReferenceHS *OGRSpatialReferenceH;
/** Opaque type for a coordinate transformation object */
typedef struct OGRCoordinateTransformationHS *OGRCoordinateTransformationH;
#else
typedef void *OGRSpatialReferenceH;
typedef void *OGRCoordinateTransformationH;
#endif
The error I'm getting is:
FAILED:
src/providers/pdal/CMakeFiles/pdal_wrench.dir/__/__/__/external/pdal_wrench/main.cpp.o
ccache
sloppiness=pch_defines,time_macros,include_file_mtime,include_file_ctime
/usr/bin/c++ -DGDAL_DEBUG -DQT_NO_CAST_TO_ASCII
-DQT_NO_DEPRECATED_WARNINGS -DQT_USE_QSTRINGBUILDER
-DSIP_VERSION=0x060806
-I/home/jgr/dev/cpp/build-qgis-qt6/src/providers/pdal/pdal_wrench_autogen/include
-I/home/jgr/dev/cpp/QGIS/external/untwine/api
-I/home/jgr/dev/cpp/QGIS/external -Wall -Wextra -Wno-long-long
-Wformat-security -Wno-strict-aliasing -Wnon-virtual-dtor
-Wno-redundant-move -Wno-misleading-indentation -Wreturn-type-c-linkage
-Woverloaded-virtual -Wimplicit-fallthrough -Qunused-arguments -g
-std=gnu++17 -fvisibility=hidden -MD -MT
-MF
src/providers/pdal/CMakeFiles/pdal_wrench.dir/__/__/__/external/pdal_wrench/main.cpp.o.d
-o
-c /home/jgr/dev/cpp/QGIS/external/pdal_wrench/main.cpp
In file included from
/home/jgr/dev/cpp/QGIS/external/pdal_wrench/main.cpp:24:
/home/jgr/dev/cpp/QGIS/external/pdal_wrench/alg.hpp:18:
/home/jgr/dev/cpp/QGIS/external/pdal_wrench/utils.hpp:125:16: error:
static_cast from 'OGRSpatialReferenceH' (aka 'OGRSpatialReferenceHS *')
to 'OGRSpatialReference *', which are not related by inheritance, is not
allowed
   125 |     ptr.reset(
static_cast<OGRSpatialReference*>(OSRNewSpatialReference(s.size() ?
s.c_str() : nullptr)) );
/usr/local/include/gdal_fwd.h:187:16: note: 'OGRSpatialReferenceHS' is
incomplete
   187 | typedef struct OGRSpatialReferenceHS *OGRSpatialReferenceH;
/home/jgr/dev/cpp/QGIS/external/pdal_wrench/utils.hpp:170:11: error: no
matching function for call to 'OSRDestroySpatialReference'
   170 |           OSRDestroySpatialReference(o);
The options I'm using to build QGIS are:
cmake -G Ninja -DCMAKE_BUILD_TYPE=Debug -DENABLE_TESTS=On
-DENABLE_PGTEST=OFF -DWITH_SERVER=TRUE -DWITH_QSPATIALITE=TRUE
-DWITH_3D=TRUE -DGDAL_CONFIG=/usr/local/bin/gdal-config
-DPROJ_INCLUDE_DIR=/usr/local/include
-DPROJ_LIBRARY=/usr/local/lib/libproj.so -DWITH_PDAL=TRUE
-DWITH_EPT=TRUE -DBUILD_WITH_QT6=TRUE -DWITH_QTWEBKIT=FALSE
-DQWT_LIBRARY=/usr/local/qwt-6.2.0/lib/libqwt.so
-DQWT_INCLUDE_DIR=/usr/local/qwt-6.2.0/include/
-DWITH_CUSTOM_WIDGETS=TRUE ../QGIS
I'm using GDAL and PDAL built from master.
Any clues about the best way to avoid this error?
Thanks,
Jorge
More information about the QGIS-Developer mailing list
