[QGIS-Developer] Compiling QGIS with Debug: error with pdal_wrench and gdal_fwd.h
Even Rouault even.rouault at spatialys.com
Wed Apr 2 08:56:04 PDT 2025
Jorge,
can you give a try at https://github.com/qgis/QGIS/pull/61316 ?
Even
Le 02/04/2025 à 17:36, Jorge Gustavo Rocha via QGIS-Developer a écrit :
> Hi devs,
> I'm not able to compile QGIS with -DCMAKE_BUILD_TYPE=Debug. No problem
> to build QGIS with -DCMAKE_BUILD_TYPE=Release.
> I think this happens since the change in GDAL's gdal_fwd.h to support:
> #if defined(GDAL_DEBUG)
> /** Opaque type for a spatial reference system */
> typedef struct OGRSpatialReferenceHS *OGRSpatialReferenceH;
> /** Opaque type for a coordinate transformation object */
> typedef struct OGRCoordinateTransformationHS
> *OGRCoordinateTransformationH;
> #else
> typedef void *OGRSpatialReferenceH;
> typedef void *OGRCoordinateTransformationH;
> #endif
> The error I'm getting is:
> FAILED:
> src/providers/pdal/CMakeFiles/pdal_wrench.dir/__/__/__/external/pdal_wrench/main.cpp.o
> ccache
> sloppiness=pch_defines,time_macros,include_file_mtime,include_file_ctime
> /usr/bin/c++ -DGDAL_DEBUG -DQT_NO_CAST_TO_ASCII
> -DQT_NO_DEPRECATED_WARNINGS -DQT_USE_QSTRINGBUILDER
> -DSIP_VERSION=0x060806
> -I/home/jgr/dev/cpp/build-qgis-qt6/src/providers/pdal/pdal_wrench_autogen/include
> -I/home/jgr/dev/cpp/QGIS/external/untwine/api
> -I/home/jgr/dev/cpp/QGIS/external -Wall -Wextra -Wno-long-long
> -Wformat-security -Wno-strict-aliasing -Wnon-virtual-dtor
> -Wno-redundant-move -Wno-misleading-indentation
> -Wreturn-type-c-linkage -Woverloaded-virtual -Wimplicit-fallthrough
> -Qunused-arguments -g -std=gnu++17 -fvisibility=hidden -MD -MT
> -MF
> src/providers/pdal/CMakeFiles/pdal_wrench.dir/__/__/__/external/pdal_wrench/main.cpp.o.d
> -o
> -c /home/jgr/dev/cpp/QGIS/external/pdal_wrench/main.cpp
> In file included from
> /home/jgr/dev/cpp/QGIS/external/pdal_wrench/main.cpp:24:
> /home/jgr/dev/cpp/QGIS/external/pdal_wrench/alg.hpp:18:
> /home/jgr/dev/cpp/QGIS/external/pdal_wrench/utils.hpp:125:16: error:
> static_cast from 'OGRSpatialReferenceH' (aka 'OGRSpatialReferenceHS
> *') to 'OGRSpatialReference *', which are not related by inheritance,
> is not allowed
>   125 |     ptr.reset(
> static_cast<OGRSpatialReference*>(OSRNewSpatialReference(s.size() ?
> s.c_str() : nullptr)) );
> /usr/local/include/gdal_fwd.h:187:16: note: 'OGRSpatialReferenceHS' is
> incomplete
>   187 | typedef struct OGRSpatialReferenceHS *OGRSpatialReferenceH;
> /home/jgr/dev/cpp/QGIS/external/pdal_wrench/utils.hpp:170:11: error:
> no matching function for call to 'OSRDestroySpatialReference'
>   170 |           OSRDestroySpatialReference(o);
> The options I'm using to build QGIS are:
> cmake -G Ninja -DCMAKE_BUILD_TYPE=Debug -DENABLE_TESTS=On
> -DENABLE_PGTEST=OFF -DWITH_SERVER=TRUE -DWITH_QSPATIALITE=TRUE
> -DWITH_3D=TRUE -DGDAL_CONFIG=/usr/local/bin/gdal-config
> -DPROJ_INCLUDE_DIR=/usr/local/include
> -DPROJ_LIBRARY=/usr/local/lib/libproj.so -DWITH_PDAL=TRUE
> -DWITH_EPT=TRUE -DBUILD_WITH_QT6=TRUE -DWITH_QTWEBKIT=FALSE
> -DQWT_LIBRARY=/usr/local/qwt-6.2.0/lib/libqwt.so
> -DQWT_INCLUDE_DIR=/usr/local/qwt-6.2.0/include/
> -DWITH_CUSTOM_WIDGETS=TRUE ../QGIS
> I'm using GDAL and PDAL built from master.
> Any clues about the best way to avoid this error?
> Thanks,
> Jorge
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
http://www.spatialys.com
More information about the QGIS-Developer mailing list
