[QGIS-Developer] Experimental flag
Lova Andriarimalala
lova at kartoza.com
Thu Apr 10 23:37:55 PDT 2025
Dear Paolo,
Thank you very much for reporting this.
The experimental checkbox in the upload and new version form has been
removed, as discussed in the issue at
https://github.com/qgis/QGIS-Plugins-Website/issues/71. However, it
appeared that the new version form was not handling the experimental
attribute correctly. A new fix has been submitted to address this issue:
https://github.com/qgis/QGIS-Plugins-Website/pull/99.
Uploading a new version as experimental should now work correctly using the
same workflow.
Best regards,
Lova Andriarimalala
*QGIS Full Stack Developer *
*T *: +27(0) 87 809 2702 *E *: lova at kartoza.com *W* :
kartoza.com
*This email and any attachments are confidential and intended solely for
the use of the individual or entity to whom they are addressed. If you *
*have received this email in error, please notify the sender immediately
and delete it from your system. Unauthorised use, disclosure, or copying*
*of the contents is prohibited.*
On Thu, 10 Apr 2025 at 16:06, Paolo Tormene via QGIS-Developer <
qgis-developer at lists.osgeo.org> wrote:
> P.S.: I see version 3.24.0 has now been approved, without the experimental
> flag. I have to delete it, before any user accidentally downloads it
> believing it is "stable".
> Please let me know how to proceed in order to re-upload the same version
> as experimental.
> Thanks again,
> Paolo
> On Thu, Apr 10, 2025 at 2:57 PM Paolo Tormene <
> paolo.tormene at globalquakemodel.org> wrote:
>> Hello. I have a question about the management of the "experimental" flag
>> in a newly uploaded plugin version. In metadata.txt in this case I have
>> experimental=True. However, in
>> https://plugins.qgis.org/plugins/svir/#plugin-versions in the row
>> corresponding to the new version 3.24.0 I don't see the expected symbol of
>> the flask. I noticed that, with respect to the past, in the form used to
>> upload a new plugin version now there is no checkbox to specify if the
>> version is experimental or not. I supposed it would have been extracted
>> from the metadata, but it looks like that flag was ignored.
>> Please, may you check about this and possibly suggest to me how to
>> proceed in case the uploading workflow has changed?
>> Thanks in advance,
>> Paolo
>> *PAOLO TORMENE* senior software developer +39 0382 5169882
>> *GLOBAL EARTHQUAKE MODEL * working together to assess risk
>> *GEM -* globalquakemodel.org <http://www.globalquakemodel.org> *T -*
>> @GEMwrld <http://twitter.com/GEMwrld> *F -* GEMwrld
>> <http://www.facebook.com/GEMwrld>
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250411/e0a5c2c1/attachment.htm>
