[QGIS-Developer] Experimental flag
    Paolo Tormene
    paolo.tormene at globalquakemodel.org
    Fri Apr 11 08:09:44 PDT 2025
Thank you very much!
I've just re-uploaded version 3.24.0 (experimental) and the interface shows
correctly the flask icon, so the issue was in fact fixed.
Best regards,
Paolo
On Fri, Apr 11, 2025 at 8:38 AM Lova Andriarimalala <lova at kartoza.com>
wrote:
> Dear Paolo,
> Thank you very much for reporting this.
> The experimental checkbox in the upload and new version form has been
> removed, as discussed in the issue at
> https://github.com/qgis/QGIS-Plugins-Website/issues/71. However, it
> appeared that the new version form was not handling the experimental
> attribute correctly. A new fix has been submitted to address this issue:
> https://github.com/qgis/QGIS-Plugins-Website/pull/99.
> Uploading a new version as experimental should now work correctly using
> the same workflow.
> Best regards,
> Lova Andriarimalala
> *QGIS Full Stack Developer   *
> *T *: +27(0) 87 809 2702          *E *: lova at kartoza.com          *W* :
> kartoza.com
> *This email and any attachments are confidential and intended solely for
> the use of the individual or entity to whom they are addressed. If you *
> *have received this email in error, please notify the sender immediately
> and delete it from your system. Unauthorised use, disclosure, or copying*
> *of the contents is prohibited.*
> On Thu, 10 Apr 2025 at 16:06, Paolo Tormene via QGIS-Developer <
> qgis-developer at lists.osgeo.org> wrote:
>> P.S.: I see version 3.24.0 has now been approved, without the
>> experimental flag. I have to delete it, before any user accidentally
>> downloads it believing it is "stable".
>> Please let me know how to proceed in order to re-upload the same version
>> as experimental.
>> Thanks again,
>> Paolo
>> On Thu, Apr 10, 2025 at 2:57 PM Paolo Tormene <
>> paolo.tormene at globalquakemodel.org> wrote:
>>> Hello. I have a question about the management of the "experimental" flag
>>> in a newly uploaded plugin version. In metadata.txt in this case I have
>>> experimental=True. However, in
>>> https://plugins.qgis.org/plugins/svir/#plugin-versions in the row
>>> corresponding to the new version 3.24.0 I don't see the expected symbol of
>>> the flask. I noticed that, with respect to the past, in the form used to
>>> upload a new plugin version now there is no checkbox to specify if the
>>> version is experimental or not. I supposed it would have been extracted
>>> from the metadata, but it looks like that flag was ignored.
>>> Please, may you check about this and possibly suggest to me how to
>>> proceed in case the uploading workflow has changed?
>>> Thanks in advance,
>>> Paolo
>>> *PAOLO TORMENE* senior software developer +39 0382 5169882
>>> *GLOBAL EARTHQUAKE MODEL * working together to assess risk
>>> *GEM -* globalquakemodel.org <http://www.globalquakemodel.org> *T -*
>>> @GEMwrld <http://twitter.com/GEMwrld> *F -* GEMwrld
>>> <http://www.facebook.com/GEMwrld>
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250411/6b17ffb8/attachment.htm>
