[QGIS-Developer] Experimental flag
Paolo Tormene paolo.tormene at globalquakemodel.org
Tue Apr 15 02:48:44 PDT 2025
Hi again. I see verson 3.24.0 is now correctly marked as experimental but
not yet approved, although unexpectedly there is 1 download for it, so
perhaps there is still something wrong with it.
Please, may you check?
Thanks again,
Paolo
On Fri, Apr 11, 2025 at 5:09 PM Paolo Tormene <
paolo.tormene at globalquakemodel.org> wrote:
> Thank you very much!
> I've just re-uploaded version 3.24.0 (experimental) and the interface
> shows correctly the flask icon, so the issue was in fact fixed.
> Best regards,
> Paolo
> On Fri, Apr 11, 2025 at 8:38 AM Lova Andriarimalala <lova at kartoza.com>
> wrote:
>> Dear Paolo,
>> Thank you very much for reporting this.
>> The experimental checkbox in the upload and new version form has been
>> removed, as discussed in the issue at
>> https://github.com/qgis/QGIS-Plugins-Website/issues/71. However, it
>> appeared that the new version form was not handling the experimental
>> attribute correctly. A new fix has been submitted to address this issue:
>> https://github.com/qgis/QGIS-Plugins-Website/pull/99.
>> Uploading a new version as experimental should now work correctly using
>> the same workflow.
>> Best regards,
>> Lova Andriarimalala
>> *QGIS Full Stack Developer   *
>> *T *: +27(0) 87 809 2702          *E *: lova at kartoza.com          *W* :
>> kartoza.com
>> *This email and any attachments are confidential and intended solely for
>> the use of the individual or entity to whom they are addressed. If you *
>> *have received this email in error, please notify the sender immediately
>> and delete it from your system. Unauthorised use, disclosure, or copying*
>> *of the contents is prohibited.*
>> On Thu, 10 Apr 2025 at 16:06, Paolo Tormene via QGIS-Developer <
>> qgis-developer at lists.osgeo.org> wrote:
>>> P.S.: I see version 3.24.0 has now been approved, without the
>>> experimental flag. I have to delete it, before any user accidentally
>>> downloads it believing it is "stable".
>>> Please let me know how to proceed in order to re-upload the same version
>>> as experimental.
>>> Thanks again,
>>> Paolo
>>> On Thu, Apr 10, 2025 at 2:57 PM Paolo Tormene <
>>>> Hello. I have a question about the management of the "experimental"
>>>> flag in a newly uploaded plugin version. In metadata.txt in this case I
>>>> have experimental=True. However, in
>>>> https://plugins.qgis.org/plugins/svir/#plugin-versions in the row
>>>> corresponding to the new version 3.24.0 I don't see the expected symbol of
>>>> the flask. I noticed that, with respect to the past, in the form used to
>>>> upload a new plugin version now there is no checkbox to specify if the
>>>> version is experimental or not. I supposed it would have been extracted
>>>> from the metadata, but it looks like that flag was ignored.
>>>> Please, may you check about this and possibly suggest to me how to
>>>> proceed in case the uploading workflow has changed?
>>>> Thanks in advance,
>>>> Paolo
>>>> *PAOLO TORMENE* senior software developer +39 0382 5169882
>>>> *GLOBAL EARTHQUAKE MODEL * working together to assess risk
>>>> *GEM -* globalquakemodel.org <http://www.globalquakemodel.org> *T -*
>>>> @GEMwrld <http://twitter.com/GEMwrld> *F -* GEMwrld
>>>> <http://www.facebook.com/GEMwrld>
>>> QGIS-Developer mailing list
>>> QGIS-Developer at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250415/6ea32640/attachment.htm>
More information about the QGIS-Developer mailing list
