[QGIS-Developer] Experimental flag
    Lova Andriarimalala
    lova at kartoza.com
    Tue Apr 15 08:42:26 PDT 2025
Hi Paolo,
Yes, the plugin is not approved yet, and it shouldn't be possible to
download it either from the website or QGIS as a normal user. However, the
plugin could be downloaded by a reviewer or someone with permission and
triggered the counter. But I guess it's part of the workflow.
Best regards,
Lova Andriarimalala
*QGIS Full Stack Developer   *
*T *: +27(0) 87 809 2702          *E *: lova at kartoza.com          *W* :
kartoza.com
*This email and any attachments are confidential and intended solely for
the use of the individual or entity to whom they are addressed. If you *
*have received this email in error, please notify the sender immediately
and delete it from your system. Unauthorised use, disclosure, or copying*
*of the contents is prohibited.*
On Tue, 15 Apr 2025 at 12:48, Paolo Tormene <
paolo.tormene at globalquakemodel.org> wrote:
> Hi again. I see verson 3.24.0 is now correctly marked as experimental but
> not yet approved, although unexpectedly there is 1 download for it, so
> perhaps there is still something wrong with it.
> Please, may you check?
> Thanks again,
> Paolo
> On Fri, Apr 11, 2025 at 5:09 PM Paolo Tormene <
>> Thank you very much!
>> I've just re-uploaded version 3.24.0 (experimental) and the interface
>> shows correctly the flask icon, so the issue was in fact fixed.
>> Best regards,
>> Paolo
>> On Fri, Apr 11, 2025 at 8:38 AM Lova Andriarimalala <lova at kartoza.com>
>> wrote:
>>> Dear Paolo,
>>> Thank you very much for reporting this.
>>> The experimental checkbox in the upload and new version form has been
>>> removed, as discussed in the issue at
>>> https://github.com/qgis/QGIS-Plugins-Website/issues/71. However, it
>>> appeared that the new version form was not handling the experimental
>>> attribute correctly. A new fix has been submitted to address this issue:
>>> https://github.com/qgis/QGIS-Plugins-Website/pull/99.
>>> Uploading a new version as experimental should now work correctly using
>>> the same workflow.
>>> Best regards,
>>> Lova Andriarimalala
>>> kartoza.com
>>> On Thu, 10 Apr 2025 at 16:06, Paolo Tormene via QGIS-Developer <
>>> qgis-developer at lists.osgeo.org> wrote:
>>>> P.S.: I see version 3.24.0 has now been approved, without the
>>>> experimental flag. I have to delete it, before any user accidentally
>>>> downloads it believing it is "stable".
>>>> Please let me know how to proceed in order to re-upload the same
>>>> version as experimental.
>>>> Thanks again,
>>>> Paolo
>>>> On Thu, Apr 10, 2025 at 2:57 PM Paolo Tormene <
>>>>> Hello. I have a question about the management of the "experimental"
>>>>> flag in a newly uploaded plugin version. In metadata.txt in this case I
>>>>> have experimental=True. However, in
>>>>> https://plugins.qgis.org/plugins/svir/#plugin-versions in the row
>>>>> corresponding to the new version 3.24.0 I don't see the expected symbol of
>>>>> the flask. I noticed that, with respect to the past, in the form used to
>>>>> upload a new plugin version now there is no checkbox to specify if the
>>>>> version is experimental or not. I supposed it would have been extracted
>>>>> from the metadata, but it looks like that flag was ignored.
>>>>> Please, may you check about this and possibly suggest to me how to
>>>>> proceed in case the uploading workflow has changed?
>>>>> Thanks in advance,
>>>>> Paolo
>>>>> *PAOLO TORMENE* senior software developer +39 0382 5169882
>>>>> *GLOBAL EARTHQUAKE MODEL * working together to assess risk
>>>>> *GEM -* globalquakemodel.org <http://www.globalquakemodel.org> *T -*
>>>>> @GEMwrld <http://twitter.com/GEMwrld> *F -* GEMwrld
>>>>> <http://www.facebook.com/GEMwrld>
>>>> _______________________________________________
>>>> QGIS-Developer mailing list
>>>> QGIS-Developer at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250415/459c9c91/attachment-0001.htm>
