[QGIS-Developer] Understanding errors while building QGIS master
    Hernán De Angelis
    variablestarlight at gmail.com
    Tue Apr 29 01:29:54 PDT 2025
Hi Jorge,
Thanks for the suggestion. I will give clang a try.
Hernán
Den 2025-04-29 kl. 10:15, skrev Jorge Gustavo Rocha via QGIS-Developer:
> Hi Hernán,
> I switched to clang 19 to compile QGIS with Qt6 on Ubuntu. There is a
> handy update-alternatives command to switch compiler versions, and I
> switch them all to clang before compiling QGIS.
> jgr at dragon:~/dev/cpp/build-qgis-qt6$ gcc --version
> Ubuntu clang version19.1.1(1ubuntu1)
> Target: x86_64-pc-linux-gnu
> Thread model: posix
> InstalledDir: /usr/lib/llvm-19/bin
> jgr at dragon:~/dev/cpp/build-qgis-qt6$ c++ --version
> Thread model: posix
> jgr at dragon:~/dev/cpp/build-qgis-qt6$ cc --version
> Thread model: posix
> I hope it helps,
> Jorge
> On 29/04/25 08:04, Hernán De Angelis via QGIS-Developer wrote:
>> Hi
>> I seek help in understanding errors (see excerpt below) I am
>> currently experiencing while building QGIS master in a fresh openSUSE
>> Tumbleweed install. These errors seem to originate in nlohmann json.
>> I am used to compile QGIS from source but never seen these errors
>> before and have trouble figuring out where they originate and what a
>> possible solution could be.
>> I am using Qt 6.9.0, and tried compiling using both GCC 14 and 15.
>> Passing the CXX flag "-std=c++17" does not seem to help. I tried
>> using NLOHMANN both internal and also using the latest version
>> compiled locally (3.12, as in error log below) but both fail in a
>> similar way.
>> I compiled QGIS master as late as 6 april without problems in a
>> previous openSUSE install. There is a very real the possibility that
>> recent changes in GCC14 and 15 regarding required standards are
>> playing a part here, as well as packaging changes in openSUSE
>> Tumbleweed. However, as I am unsure what the cause may be I would
>> like to ask the developers if these errors look familiar to you and
>> if they suggest something.
>> Thanks in advance
>> Hernán
>> [ 12%] Built target staged-plugins-on-build
>> In file included from
>> /usr/local/src/QGIS/external/nlohmann/detail/value_t.hpp:16,
>>                  from
>> /usr/local/src/QGIS/external/nlohmann/detail/exceptions.hpp:20,
>>                  from
>> /usr/local/src/QGIS/external/nlohmann/detail/conversions/from_json.hpp:23,
>>                  from
>> /usr/local/src/QGIS/external/nlohmann/adl_serializer.hpp:14,
>>                  from /usr/local/src/QGIS/external/nlohmann/json.hpp:34,
>>                  from
>> /usr/local/src/QGIS/external/pdal_wrench/vpc.cpp:26:
>> /usr/local/src/QGIS/external/nlohmann/detail/macro_scope.hpp:257:63:
>> error: wrong number of template arguments (11, should be at least 0)
>>   257 |     AllocatorType, JSONSerializer, BinaryType, CustomBaseClass>
>> /usr/local/src/QGIS/external/nlohmann/detail/meta/type_traits.hpp:53:22:
>> note: in expansion of macro ‘NLOHMANN_BASIC_JSON_TPL’
>>    53 | struct is_basic_json<NLOHMANN_BASIC_JSON_TPL> :
>> std::true_type {};
>> In file included from /usr/local/include/pdal/PDALUtils.hpp:39,
>>                  from /usr/local/include/pdal/PointRef.hpp:37,
>>                  from /usr/local/include/pdal/Geometry.hpp:37,
>>                  from
>> /usr/local/src/QGIS/external/pdal_wrench/vpc.hpp:18,
>>                  from
>> /usr/local/src/QGIS/external/pdal_wrench/vpc.cpp:19:
>> /usr/local/include/pdal/JsonFwd.hpp:40:7: note: provided for
>> ‘template<template<class U, class V, class ... Args> class
>> ObjectType, template<class U, class ... Args> class ArrayType, class
>> StringType, class BooleanType, class NumberIntegerType, class
>> NumberUnsignedType, class NumberFloatType, template<class U> class
>> AllocatorType, template<class T, class SFINAE> class JSONSerializer,
>> class BinaryType> class nlohmann::basic_json’
>>    40 | class basic_json;
>> /usr/local/src/QGIS/external/nlohmann/detail/exceptions.hpp:25:
>> /usr/local/src/QGIS/external/nlohmann/detail/meta/type_traits.hpp:53:45:
>> error: template argument 1 is invalid
>> std::true_type {};
>> /usr/local/src/QGIS/external/nlohmann/detail/json_pointer.hpp:51:28:
>>    51 |     struct string_t_helper<NLOHMANN_BASIC_JSON_TPL>
>> In file included from /usr/local/src/QGIS/external/nlohmann/json.hpp:50:
>> /usr/local/src/QGIS/external/nlohmann/detail/json_pointer.hpp:51:51:
>> /usr/local/src/QGIS/external/nlohmann/json.hpp:104:30: error:
>> reference to ‘json_pointer’ is ambiguous
>>   104 |     friend class ::nlohmann::json_pointer;
>> /usr/local/src/QGIS/external/nlohmann/detail/json_pointer.hpp:35:7:
>> note: candidates are: ‘template<class RefStringType> class
>> nlohmann::json_abi_v3_11_3::json_pointer’
>>    35 | class json_pointer
>> /usr/local/include/pdal/JsonFwd.hpp:45:7: note:
>> ‘template<class BasicJsonType> class nlohmann::json_pointer’
>>    45 | class json_pointer;
>> /usr/local/src/QGIS/external/nlohmann/json.hpp:166:26: error:
>>   166 |     using json_pointer = ::nlohmann::json_pointer<StringType>;
>> /usr/local/src/QGIS/external/nlohmann/json.hpp:2327:21: error:
>> missing template argument list after
>> ‘nlohmann::json_abi_v3_11_3::json_pointer’; template placeholder not
>> permitted in parameter
>>  2327 |     ValueType value(const json_pointer& ptr, const ValueType&
>> default_value) const
>> note: ‘template<class RefStringType> class
>> nlohmann::json_abi_v3_11_3::json_pointer’ declared here
>> /usr/local/src/QGIS/external/nlohmann/json.hpp:2352:22: error:
>>  2352 |     ReturnType value(const json_pointer& ptr, ValueType &&
>> /usr/local/src/QGIS/external/nlohmann/json.hpp:2376:27: error:
>>  2376 |     ValueType value(const
>> ::nlohmann::json_pointer<BasicJsonType>& ptr, const ValueType&
>> /usr/local/src/QGIS/external/nlohmann/json.hpp:2376:51: error:
>> expected ‘,’ or ‘...’ before ‘<’ token
>> /usr/local/src/QGIS/external/nlohmann/json.hpp:2387:28: error:
>>  2387 |     ReturnType value(const
>> ::nlohmann::json_pointer<BasicJsonType>& ptr, ValueType &&
>> /usr/local/src/QGIS/external/nlohmann/json.hpp:2387:52: error:
>> /usr/local/src/QGIS/external/nlohmann/json.hpp:2745:19: error:
>>  2745 |     bool contains(const json_pointer& ptr) const
>> /usr/local/src/QGIS/external/nlohmann/json.hpp:2752:46: error:
>>  2752 |     bool contains(const typename
>> ::nlohmann::json_pointer<BasicJsonType>& ptr) const
>> /usr/local/src/QGIS/external/nlohmann/json.hpp:2752:58: error:
>> /usr/local/src/QGIS/external/nlohmann/json.hpp:4618:26: error:
>>  4618 |     reference operator[](const json_pointer& ptr)
>> /usr/local/src/QGIS/external/nlohmann/json.hpp:4618:15: error:
>> ‘nlohmann::json_abi_v3_11_3::basic_json<ObjectType, ArrayType,
>> StringType, BooleanType, NumberIntegerType, NumberUnsignedType,
>> NumberFloatType, AllocatorType, JSONSerializer, BinaryType,
>> CustomBaseClass>::value_type&
>> CustomBaseClass>::operator[](...)’ must not have variable number of
>> arguments
>> /usr/local/src/QGIS/external/nlohmann/json.hpp:4625:32: error:
>>  4625 |     reference operator[](const
>> /usr/local/src/QGIS/external/nlohmann/json.hpp:4625:56: error:
>> /usr/local/src/QGIS/external/nlohmann/json.hpp:4632:32: error:
>>  4632 |     const_reference operator[](const json_pointer& ptr) const
>> /usr/local/src/QGIS/external/nlohmann/json.hpp:4632:21: error: ‘const
>> CustomBaseClass>::operator[](...) const’ must not have variable
>> number of arguments
>> /usr/local/src/QGIS/external/nlohmann/json.hpp:4639:38: error:
>>  4639 |     const_reference operator[](const
>> /usr/local/src/QGIS/external/nlohmann/json.hpp:4639:62: error:
>> /usr/local/src/QGIS/external/nlohmann/json.hpp:4646:18: error:
>>  4646 |     reference at(const json_pointer& ptr)
>> /usr/local/src/QGIS/external/nlohmann/json.hpp:4653:24: error:
>>  4653 |     reference at(const
>> /usr/local/src/QGIS/external/nlohmann/json.hpp:4653:48: error:
>> /usr/local/src/QGIS/external/nlohmann/json.hpp:4660:24: error:
>>  4660 |     const_reference at(const json_pointer& ptr) const
>> /usr/local/src/QGIS/external/nlohmann/json.hpp:4667:30: error:
>>  4667 |     const_reference at(const
>> /usr/local/src/QGIS/external/nlohmann/json.hpp:4667:54: error:
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250429/0edc099c/attachment-0001.htm>
