[QGIS-Developer] Understanding errors while building QGIS master
Jorge Gustavo Rocha
jgr at di.uminho.pt
Tue Apr 29 01:15:23 PDT 2025
Hi Hernán,
I switched to clang 19 to compile QGIS with Qt6 on Ubuntu. There is a
handy update-alternatives command to switch compiler versions, and I
switch them all to clang before compiling QGIS.
jgr at dragon:~/dev/cpp/build-qgis-qt6$ gcc --version
Ubuntu clang version19.1.1(1ubuntu1)
Target: x86_64-pc-linux-gnu
Thread model: posix
InstalledDir: /usr/lib/llvm-19/bin
jgr at dragon:~/dev/cpp/build-qgis-qt6$ c++ --version
Thread model: posix
jgr at dragon:~/dev/cpp/build-qgis-qt6$ cc --version
Thread model: posix
I hope it helps,
Jorge
On 29/04/25 08:04, Hernán De Angelis via QGIS-Developer wrote:
> Hi
> I seek help in understanding errors (see excerpt below) I am currently
> experiencing while building QGIS master in a fresh openSUSE Tumbleweed
> install. These errors seem to originate in nlohmann json. I am used to
> compile QGIS from source but never seen these errors before and have
> trouble figuring out where they originate and what a possible solution
> could be.
> I am using Qt 6.9.0, and tried compiling using both GCC 14 and 15.
> Passing the CXX flag "-std=c++17" does not seem to help. I tried using
> NLOHMANN both internal and also using the latest version compiled
> locally (3.12, as in error log below) but both fail in a similar way.
> I compiled QGIS master as late as 6 april without problems in a
> previous openSUSE install. There is a very real the possibility that
> recent changes in GCC14 and 15 regarding required standards are
> playing a part here, as well as packaging changes in openSUSE
> Tumbleweed. However, as I am unsure what the cause may be I would like
> to ask the developers if these errors look familiar to you and if they
> suggest something.
> Thanks in advance
> Hernán
> [ 12%] Built target staged-plugins-on-build
> In file included from
> /usr/local/src/QGIS/external/nlohmann/detail/value_t.hpp:16,
> from
> /usr/local/src/QGIS/external/nlohmann/detail/exceptions.hpp:20,
> from
> /usr/local/src/QGIS/external/nlohmann/detail/conversions/from_json.hpp:23,
> from
> /usr/local/src/QGIS/external/nlohmann/adl_serializer.hpp:14,
> from /usr/local/src/QGIS/external/nlohmann/json.hpp:34,
> from /usr/local/src/QGIS/external/pdal_wrench/vpc.cpp:26:
> /usr/local/src/QGIS/external/nlohmann/detail/macro_scope.hpp:257:63:
> error: wrong number of template arguments (11, should be at least 0)
> 257 | AllocatorType, JSONSerializer, BinaryType, CustomBaseClass>
> /usr/local/src/QGIS/external/nlohmann/detail/meta/type_traits.hpp:53:22:
> note: in expansion of macro ‘NLOHMANN_BASIC_JSON_TPL’
> 53 | struct is_basic_json<NLOHMANN_BASIC_JSON_TPL> : std::true_type {};
> In file included from /usr/local/include/pdal/PDALUtils.hpp:39,
> from /usr/local/include/pdal/PointRef.hpp:37,
> from /usr/local/include/pdal/Geometry.hpp:37,
> from /usr/local/src/QGIS/external/pdal_wrench/vpc.hpp:18,
> from /usr/local/src/QGIS/external/pdal_wrench/vpc.cpp:19:
> /usr/local/include/pdal/JsonFwd.hpp:40:7: note: provided for
> ‘template<template<class U, class V, class ... Args> class ObjectType,
> template<class U, class ... Args> class ArrayType, class StringType,
> class BooleanType, class NumberIntegerType, class NumberUnsignedType,
> class NumberFloatType, template<class U> class AllocatorType,
> template<class T, class SFINAE> class JSONSerializer, class
> BinaryType> class nlohmann::basic_json’
> 40 | class basic_json;
> /usr/local/src/QGIS/external/nlohmann/detail/exceptions.hpp:25:
> /usr/local/src/QGIS/external/nlohmann/detail/meta/type_traits.hpp:53:45:
> error: template argument 1 is invalid
> /usr/local/src/QGIS/external/nlohmann/detail/json_pointer.hpp:51:28:
> 51 | struct string_t_helper<NLOHMANN_BASIC_JSON_TPL>
> In file included from /usr/local/src/QGIS/external/nlohmann/json.hpp:50:
> /usr/local/src/QGIS/external/nlohmann/detail/json_pointer.hpp:51:51:
> /usr/local/src/QGIS/external/nlohmann/json.hpp:104:30: error:
> reference to ‘json_pointer’ is ambiguous
> 104 | friend class ::nlohmann::json_pointer;
> /usr/local/src/QGIS/external/nlohmann/detail/json_pointer.hpp:35:7:
> note: candidates are: ‘template<class RefStringType> class
> nlohmann::json_abi_v3_11_3::json_pointer’
> 35 | class json_pointer
> /usr/local/include/pdal/JsonFwd.hpp:45:7: note: ‘template<class
> BasicJsonType> class nlohmann::json_pointer’
> 45 | class json_pointer;
> /usr/local/src/QGIS/external/nlohmann/json.hpp:166:26: error:
> 166 | using json_pointer = ::nlohmann::json_pointer<StringType>;
> /usr/local/src/QGIS/external/nlohmann/json.hpp:2327:21: error: missing
> template argument list after
> ‘nlohmann::json_abi_v3_11_3::json_pointer’; template placeholder not
> permitted in parameter
> 2327 | ValueType value(const json_pointer& ptr, const ValueType&
> default_value) const
> note: ‘template<class RefStringType> class
> nlohmann::json_abi_v3_11_3::json_pointer’ declared here
> /usr/local/src/QGIS/external/nlohmann/json.hpp:2352:22: error: missing
> 2352 | ReturnType value(const json_pointer& ptr, ValueType &&
> /usr/local/src/QGIS/external/nlohmann/json.hpp:2376:27: error:
> 2376 | ValueType value(const
> ::nlohmann::json_pointer<BasicJsonType>& ptr, const ValueType&
> /usr/local/src/QGIS/external/nlohmann/json.hpp:2376:51: error:
> expected ‘,’ or ‘...’ before ‘<’ token
> /usr/local/src/QGIS/external/nlohmann/json.hpp:2387:28: error:
> 2387 | ReturnType value(const
> ::nlohmann::json_pointer<BasicJsonType>& ptr, ValueType &&
> /usr/local/src/QGIS/external/nlohmann/json.hpp:2387:52: error:
> /usr/local/src/QGIS/external/nlohmann/json.hpp:2745:19: error: missing
> 2745 | bool contains(const json_pointer& ptr) const
> /usr/local/src/QGIS/external/nlohmann/json.hpp:2752:46: error:
> 2752 | bool contains(const typename
> ::nlohmann::json_pointer<BasicJsonType>& ptr) const
> /usr/local/src/QGIS/external/nlohmann/json.hpp:2752:58: error:
> /usr/local/src/QGIS/external/nlohmann/json.hpp:4618:26: error: missing
> 4618 | reference operator[](const json_pointer& ptr)
> /usr/local/src/QGIS/external/nlohmann/json.hpp:4618:15: error:
> ‘nlohmann::json_abi_v3_11_3::basic_json<ObjectType, ArrayType,
> StringType, BooleanType, NumberIntegerType, NumberUnsignedType,
> NumberFloatType, AllocatorType, JSONSerializer, BinaryType,
> CustomBaseClass>::value_type&
> CustomBaseClass>::operator[](...)’ must not have variable number of
> arguments
> /usr/local/src/QGIS/external/nlohmann/json.hpp:4625:32: error:
> 4625 | reference operator[](const
> /usr/local/src/QGIS/external/nlohmann/json.hpp:4625:56: error:
> /usr/local/src/QGIS/external/nlohmann/json.hpp:4632:32: error: missing
> 4632 | const_reference operator[](const json_pointer& ptr) const
> /usr/local/src/QGIS/external/nlohmann/json.hpp:4632:21: error: ‘const
> CustomBaseClass>::operator[](...) const’ must not have variable number
> of arguments
> /usr/local/src/QGIS/external/nlohmann/json.hpp:4639:38: error:
> 4639 | const_reference operator[](const
> /usr/local/src/QGIS/external/nlohmann/json.hpp:4639:62: error:
> /usr/local/src/QGIS/external/nlohmann/json.hpp:4646:18: error: missing
> 4646 | reference at(const json_pointer& ptr)
> /usr/local/src/QGIS/external/nlohmann/json.hpp:4653:24: error:
> 4653 | reference at(const
> /usr/local/src/QGIS/external/nlohmann/json.hpp:4653:48: error:
> /usr/local/src/QGIS/external/nlohmann/json.hpp:4660:24: error: missing
> 4660 | const_reference at(const json_pointer& ptr) const
> /usr/local/src/QGIS/external/nlohmann/json.hpp:4667:30: error:
> 4667 | const_reference at(const
> /usr/local/src/QGIS/external/nlohmann/json.hpp:4667:54: error:
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250429/054726e0/attachment-0001.htm>
