[QGIS-Developer] Understanding errors while building QGIS master
Hernán De Angelis variablestarlight at gmail.com
Mon Apr 28 03:22:26 PDT 2025
Hi
I seek help in understanding errors I am currently experiencing while
building QGIS master in a fresh openSUSE Tumbleweed install. These
errors seem to originate in nlohmann json. I am used to compile QGIS
from source but never seen these errors before and have trouble figuring
out where they originate and what a possible solution could be.
I am using Qt 6.9.0, and tried compiling using both GCC 14 and 15.
Passing the flag "-std=c++17" does not seem to help. I tried using
NLOHMANN both internal and also using the latest version compiled
locally (3.12, as in error log below) but both fail in a similar way.
I compiled QGIS master as late as 6 april without problems in a previous
openSUSE install. There is a very real the possibility that recent
changes in GCC14 and 15 regarding required standards are playing a part
here, as well as packaging changes in openSUSE Tumbleweed. However, as I
am unsure what the cause may be I would like to ask the developers if
these errors look familiar to you or if they suggest something.
Thanks in advance
Hernán
[ 12%] Built target staged-plugins-on-build
In file included from
/usr/local/src/QGIS/external/nlohmann/detail/value_t.hpp:16,
                  from
/usr/local/src/QGIS/external/nlohmann/detail/exceptions.hpp:20,
                  from
/usr/local/src/QGIS/external/nlohmann/detail/conversions/from_json.hpp:23,
                  from
/usr/local/src/QGIS/external/nlohmann/adl_serializer.hpp:14,
                  from /usr/local/src/QGIS/external/nlohmann/json.hpp:34,
                  from /usr/local/src/QGIS/external/pdal_wrench/vpc.cpp:26:
/usr/local/src/QGIS/external/nlohmann/detail/macro_scope.hpp:257:63:
error: wrong number of template arguments (11, should be at least 0)
   257 |     AllocatorType, JSONSerializer, BinaryType, CustomBaseClass>
/usr/local/src/QGIS/external/nlohmann/detail/meta/type_traits.hpp:53:22:
note: in expansion of macro ‘NLOHMANN_BASIC_JSON_TPL’
    53 | struct is_basic_json<NLOHMANN_BASIC_JSON_TPL> : std::true_type {};
In file included from /usr/local/include/pdal/PDALUtils.hpp:39,
                  from /usr/local/include/pdal/PointRef.hpp:37,
                  from /usr/local/include/pdal/Geometry.hpp:37,
                  from /usr/local/src/QGIS/external/pdal_wrench/vpc.hpp:18,
                  from /usr/local/src/QGIS/external/pdal_wrench/vpc.cpp:19:
/usr/local/include/pdal/JsonFwd.hpp:40:7: note: provided for
‘template<template<class U, class V, class ... Args> class ObjectType,
template<class U, class ... Args> class ArrayType, class StringType,
class BooleanType, class NumberIntegerType, class NumberUnsignedType,
class NumberFloatType, template<class U> class AllocatorType,
template<class T, class SFINAE> class JSONSerializer, class BinaryType>
class nlohmann::basic_json’
    40 | class basic_json;
/usr/local/src/QGIS/external/nlohmann/detail/exceptions.hpp:25:
/usr/local/src/QGIS/external/nlohmann/detail/meta/type_traits.hpp:53:45:
error: template argument 1 is invalid
/usr/local/src/QGIS/external/nlohmann/detail/json_pointer.hpp:51:28:
    51 |     struct string_t_helper<NLOHMANN_BASIC_JSON_TPL>
In file included from /usr/local/src/QGIS/external/nlohmann/json.hpp:50:
/usr/local/src/QGIS/external/nlohmann/detail/json_pointer.hpp:51:51:
/usr/local/src/QGIS/external/nlohmann/json.hpp:104:30: error: reference
to ‘json_pointer’ is ambiguous
   104 |     friend class ::nlohmann::json_pointer;
/usr/local/src/QGIS/external/nlohmann/detail/json_pointer.hpp:35:7:
note: candidates are: ‘template<class RefStringType> class
nlohmann::json_abi_v3_11_3::json_pointer’
    35 | class json_pointer
/usr/local/include/pdal/JsonFwd.hpp:45:7: note: ‘template<class
BasicJsonType> class nlohmann::json_pointer’
    45 | class json_pointer;
/usr/local/src/QGIS/external/nlohmann/json.hpp:166:26: error: reference
   166 |     using json_pointer = ::nlohmann::json_pointer<StringType>;
/usr/local/src/QGIS/external/nlohmann/json.hpp:2327:21: error: missing
template argument list after ‘nlohmann::json_abi_v3_11_3::json_pointer’;
template placeholder not permitted in parameter
  2327 |     ValueType value(const json_pointer& ptr, const ValueType&
default_value) const
note: ‘template<class RefStringType> class
nlohmann::json_abi_v3_11_3::json_pointer’ declared here
/usr/local/src/QGIS/external/nlohmann/json.hpp:2352:22: error: missing
  2352 |     ReturnType value(const json_pointer& ptr, ValueType &&
/usr/local/src/QGIS/external/nlohmann/json.hpp:2376:27: error: reference
  2376 |     ValueType value(const
::nlohmann::json_pointer<BasicJsonType>& ptr, const ValueType&
/usr/local/src/QGIS/external/nlohmann/json.hpp:2376:51: error: expected
‘,’ or ‘...’ before ‘<’ token
/usr/local/src/QGIS/external/nlohmann/json.hpp:2387:28: error: reference
  2387 |     ReturnType value(const
::nlohmann::json_pointer<BasicJsonType>& ptr, ValueType &&
/usr/local/src/QGIS/external/nlohmann/json.hpp:2387:52: error: expected
/usr/local/src/QGIS/external/nlohmann/json.hpp:2745:19: error: missing
  2745 |     bool contains(const json_pointer& ptr) const
/usr/local/src/QGIS/external/nlohmann/json.hpp:2752:46: error: reference
  2752 |     bool contains(const typename
::nlohmann::json_pointer<BasicJsonType>& ptr) const
/usr/local/src/QGIS/external/nlohmann/json.hpp:2752:58: error: expected
/usr/local/src/QGIS/external/nlohmann/json.hpp:4618:26: error: missing
  4618 |     reference operator[](const json_pointer& ptr)
/usr/local/src/QGIS/external/nlohmann/json.hpp:4618:15: error:
‘nlohmann::json_abi_v3_11_3::basic_json<ObjectType, ArrayType,
StringType, BooleanType, NumberIntegerType, NumberUnsignedType,
NumberFloatType, AllocatorType, JSONSerializer, BinaryType,
CustomBaseClass>::value_type&
CustomBaseClass>::operator[](...)’ must not have variable number of
arguments
/usr/local/src/QGIS/external/nlohmann/json.hpp:4625:32: error: reference
  4625 |     reference operator[](const
/usr/local/src/QGIS/external/nlohmann/json.hpp:4625:56: error: expected
/usr/local/src/QGIS/external/nlohmann/json.hpp:4632:32: error: missing
  4632 |     const_reference operator[](const json_pointer& ptr) const
/usr/local/src/QGIS/external/nlohmann/json.hpp:4632:21: error: ‘const
CustomBaseClass>::operator[](...) const’ must not have variable number
of arguments
/usr/local/src/QGIS/external/nlohmann/json.hpp:4639:38: error: reference
  4639 |     const_reference operator[](const
/usr/local/src/QGIS/external/nlohmann/json.hpp:4639:62: error: expected
/usr/local/src/QGIS/external/nlohmann/json.hpp:4646:18: error: missing
  4646 |     reference at(const json_pointer& ptr)
/usr/local/src/QGIS/external/nlohmann/json.hpp:4653:24: error: reference
  4653 |     reference at(const ::nlohmann::json_pointer<BasicJsonType>&
ptr)
/usr/local/src/QGIS/external/nlohmann/json.hpp:4653:48: error: expected
ptr)
/usr/local/src/QGIS/external/nlohmann/json.hpp:4660:24: error: missing
  4660 |     const_reference at(const json_pointer& ptr) const
/usr/local/src/QGIS/external/nlohmann/json.hpp:4667:30: error: reference
  4667 |     const_reference at(const
/usr/local/src/QGIS/external/nlohmann/json.hpp:4667:54: error: expected
/usr/local/src/QGIS/external/nlohmann/json.hpp: In member function
‘ValueType nlohmann::json_abi_v3_11_3::basic_json<ObjectType, ArrayType,
CustomBaseClass>::value(...) const’:
/usr/local/src/QGIS/external/nlohmann/json.hpp:2335:24: error: ‘ptr’ was
not declared in this scope
  2335 |                 return ptr.get_checked(this).template
get<ValueType>();
/usr/local/src/QGIS/external/nlohmann/json.hpp:2335:68: error: expected
primary-expression before ‘>’ token
get<ValueType>();
/usr/local/src/QGIS/external/nlohmann/json.hpp:2335:70: error: expected
primary-expression before ‘)’ token
get<ValueType>();
‘ReturnType nlohmann::json_abi_v3_11_3::basic_json<ObjectType,
ArrayType, StringType, BooleanType, NumberIntegerType,
NumberUnsignedType, NumberFloatType, AllocatorType, JSONSerializer,
BinaryType, CustomBaseClass>::value(...) const’:
/usr/local/src/QGIS/external/nlohmann/json.hpp:2360:24: error: ‘ptr’ was
  2360 |                 return ptr.get_checked(this).template
get<ReturnType>();
/usr/local/src/QGIS/external/nlohmann/json.hpp:2360:69: error: expected
get<ReturnType>();
/usr/local/src/QGIS/external/nlohmann/json.hpp:2360:71: error: expected
get<ReturnType>();
CustomBaseClass>::value(int) const’:
/usr/local/src/QGIS/external/nlohmann/json.hpp:2378:22: error: ‘ptr’ was
  2378 |         return value(ptr.convert(), default_value);
/usr/local/src/QGIS/external/nlohmann/json.hpp:2378:37: error:
‘default_value’ was not declared in this scope
BinaryType, CustomBaseClass>::value(int) const’:
/usr/local/src/QGIS/external/nlohmann/json.hpp:2389:22: error: ‘ptr’ was
  2389 |         return value(ptr.convert(),
std::forward<ValueType>(default_value));
/usr/local/src/QGIS/external/nlohmann/json.hpp:2389:61: error:
/usr/local/src/QGIS/external/nlohmann/json.hpp: In member function ‘bool
CustomBaseClass>::contains(...) const’:
/usr/local/src/QGIS/external/nlohmann/json.hpp:2747:16: error: ‘ptr’ was
  2747 |         return ptr.contains(this);
CustomBaseClass>::contains(int) const’:
/usr/local/src/QGIS/external/nlohmann/json.hpp:2754:16: error: ‘ptr’ was
  2754 |         return ptr.contains(this);
CustomBaseClass>::operator[](int)’:
/usr/local/src/QGIS/external/nlohmann/json.hpp:4627:16: error: ‘ptr’ was
  4627 |         return ptr.get_unchecked(this);
‘const nlohmann::json_abi_v3_11_3::basic_json<ObjectType, ArrayType,
CustomBaseClass>::operator[](int) const’:
/usr/local/src/QGIS/external/nlohmann/json.hpp:4641:16: error: ‘ptr’ was
  4641 |         return ptr.get_unchecked(this);
CustomBaseClass>::at(...)’:
/usr/local/src/QGIS/external/nlohmann/json.hpp:4648:16: error: ‘ptr’ was
  4648 |         return ptr.get_checked(this);
CustomBaseClass>::at(int)’:
/usr/local/src/QGIS/external/nlohmann/json.hpp:4655:16: error: ‘ptr’ was
  4655 |         return ptr.get_checked(this);
CustomBaseClass>::at(...) const’:
/usr/local/src/QGIS/external/nlohmann/json.hpp:4662:16: error: ‘ptr’ was
  4662 |         return ptr.get_checked(this);
CustomBaseClass>::at(int) const’:
/usr/local/src/QGIS/external/nlohmann/json.hpp:4669:16: error: ‘ptr’ was
  4669 |         return ptr.get_checked(this);
CustomBaseClass> nlohmann::json_abi_v3_11_3::basic_json<ObjectType,
BinaryType, CustomBaseClass>::flatten() const’:
/usr/local/src/QGIS/external/nlohmann/json.hpp:4677:30: error:
qualified-id in declaration before ‘(’ token
  4677 |         json_pointer::flatten("", *this, result);
BinaryType, CustomBaseClass>::unflatten() const’:
/usr/local/src/QGIS/external/nlohmann/json.hpp:4685:16: error:
nlohmann::json_abi_v3_11_3::json_pointer’ used without template arguments
  4685 |         return json_pointer::unflatten(*this);
/usr/local/src/QGIS/external/nlohmann/json.hpp: In member function ‘void
CustomBaseClass>::patch_inplace(const
CustomBaseClass>&)’:
/usr/local/src/QGIS/external/nlohmann/json.hpp:4736:46: error: missing
  4736 |         const auto operation_add = [&result](json_pointer &
ptr, basic_json val)
/usr/local/src/QGIS/external/nlohmann/json.hpp: In lambda function:
/usr/local/src/QGIS/external/nlohmann/json.hpp:4739:17: error: ‘ptr’ was
  4739 |             if (ptr.empty())
/usr/local/src/QGIS/external/nlohmann/json.hpp:4746:46: error: ‘ptr’ was
  4746 |             json_pointer const top_pointer = ptr.top();
/usr/local/src/QGIS/external/nlohmann/json.hpp:4777:42: error:
  4777 |                         const auto idx = json_pointer::template
array_index<basic_json_t>(last_path);
/usr/local/src/QGIS/external/nlohmann/json.hpp:4777:89: error: expected
/usr/local/src/QGIS/external/nlohmann/json.hpp:4804:56: error: missing
  4804 |         const auto operation_remove = [this, &
result](json_pointer & ptr)
/usr/local/src/QGIS/external/nlohmann/json.hpp:4807:36: error: ‘ptr’ was
  4807 |             const auto last_path = ptr.back();
/usr/local/src/QGIS/external/nlohmann/json.hpp:4828:30: error:
  4828 |                 parent.erase(json_pointer::template
array_index<basic_json_t>(last_path));
/usr/local/src/QGIS/external/nlohmann/json.hpp:4828:77: error: expected
/usr/local/src/QGIS/external/nlohmann/json.hpp: At global scope:
/usr/local/src/QGIS/external/nlohmann/json.hpp:5168:72: error: return
type ‘using nlohmann::json = class nlohmann::basic_json<>’ {aka ‘class
nlohmann::basic_json<>’} is incomplete
  5168 |     inline nlohmann::json operator ""_json(const char* s,
std::size_t n)
/usr/local/src/QGIS/external/nlohmann/json.hpp: In function ‘void
nlohmann::json_abi_v3_11_3::literals::json_literals::operator""_json(const
char*, std::size_t)’:
/usr/local/src/QGIS/external/nlohmann/json.hpp:5173:28: error:
incomplete type ‘nlohmann::json’ {aka ‘nlohmann::basic_json<>’} used in
nested name specifier
  5173 |     return nlohmann::json::parse(s, s + n);
/usr/local/src/QGIS/external/nlohmann/json.hpp:5180:28: error: invalid
use of incomplete type ‘using nlohmann::json = class
nlohmann::basic_json<>’ {aka ‘class nlohmann::basic_json<>’}
  5180 |     inline nlohmann::json::json_pointer operator
""_json_pointer(const char* s, std::size_t n)
/usr/local/include/pdal/JsonFwd.hpp:40:7: note: declaration of ‘using
/usr/local/src/QGIS/external/nlohmann/json.hpp:5202:46: error: template
  5202 | struct hash<nlohmann::NLOHMANN_BASIC_JSON_TPL> //
NOLINT(cert-dcl58-cpp)
/usr/local/src/QGIS/external/nlohmann/json.hpp:5235:13: error: variable
or field ‘swap’ declared void
  5235 | inline void swap(nlohmann::NLOHMANN_BASIC_JSON_TPL& j1,
nlohmann::NLOHMANN_BASIC_JSON_TPL& j2) noexcept(  //
NOLINT(readability-inconsistent-declaration-parameter-name, cert-dcl58-cpp)
/usr/local/src/QGIS/external/nlohmann/detail/macro_scope.hpp:255:5:
error: reference to ‘basic_json’ is ambiguous
   255 |     basic_json<ObjectType, ArrayType, StringType,
BooleanType,             \
/usr/local/src/QGIS/external/nlohmann/json.hpp:5235:28: note: in
/usr/local/src/QGIS/external/nlohmann/json.hpp:97:7: note: candidates
are: ‘template<template<class, class, class ...> class ObjectType,
template<class, class ...> class ArrayType, class StringType, class
BooleanType, class NumberIntegerType, class NumberUnsignedType, class
NumberFloatType, template<class> class AllocatorType, template<class,
class> class JSONSerializer, class BinaryType, class CustomBaseClass>
class nlohmann::json_abi_v3_11_3::basic_json’
    97 | class basic_json //
NOLINT(cppcoreguidelines-special-member-functions,hicpp-special-member-functions)
/usr/local/include/pdal/JsonFwd.hpp:40:7: note: ‘template<template<class
U, class V, class ... Args> class ObjectType, template<class U, class
... Args> class ArrayType, class StringType, class BooleanType, class
NumberIntegerType, class NumberUnsignedType, class NumberFloatType,
template<class U> class AllocatorType, template<class T, class SFINAE>
class JSONSerializer, class BinaryType> class nlohmann::basic_json’
/usr/local/src/QGIS/external/nlohmann/detail/macro_scope.hpp:255:26:
error: missing template arguments before ‘,’ token
BooleanType,             \
/usr/local/src/QGIS/external/nlohmann/detail/macro_scope.hpp:255:37:
BooleanType,             \
/usr/local/src/QGIS/external/nlohmann/detail/macro_scope.hpp:255:49:
error: expected primary-expression before ‘,’ token
BooleanType,             \
/usr/local/src/QGIS/external/nlohmann/detail/macro_scope.hpp:255:62:
BooleanType,             \
/usr/local/src/QGIS/external/nlohmann/detail/macro_scope.hpp:256:22:
   256 |     NumberIntegerType, NumberUnsignedType,
NumberFloatType,                \
/usr/local/src/QGIS/external/nlohmann/detail/macro_scope.hpp:256:42:
NumberFloatType,                \
/usr/local/src/QGIS/external/nlohmann/detail/macro_scope.hpp:256:59:
NumberFloatType,                \
/usr/local/src/QGIS/external/nlohmann/detail/macro_scope.hpp:257:18:
/usr/local/src/QGIS/external/nlohmann/detail/macro_scope.hpp:257:34:
/usr/local/src/QGIS/external/nlohmann/detail/macro_scope.hpp:257:46:
error: expected primary-expression before ‘>’ token
BooleanType,             \
/usr/local/src/QGIS/external/nlohmann/json.hpp:5235:67: note: in
BooleanType,             \
BooleanType,             \
BooleanType,             \
BooleanType,             \
NumberFloatType,                \
NumberFloatType,                \
NumberFloatType,                \
/usr/local/src/QGIS/external/nlohmann/json.hpp:5235:92: error: ‘j2’ was
not declared in this scope; did you mean ‘jn’?
| jn
/usr/local/src/QGIS/external/nlohmann/json.hpp:5249:59: error:
‘operator""_json_pointer’ has not been declared in
‘nlohmann::json_abi_v3_11_3::literals::json_literals’
  5249 |         using nlohmann::literals::json_literals::operator
""_json_pointer;
//NOLINT(misc-unused-using-decls,google-global-names-in-headers)
/usr/local/src/QGIS/external/pdal_wrench/vpc.cpp: In member function
‘bool VirtualPointCloud::read(std::string)’:
/usr/local/src/QGIS/external/pdal_wrench/vpc.cpp:66:10: error: aggregate
‘json data’ has incomplete type and cannot be defined
    66 |     json data;
/usr/local/src/QGIS/external/pdal_wrench/vpc.cpp:69:22: error:
incomplete type ‘json’ {aka ‘nlohmann::basic_json<>’} used in nested
name specifier
    69 |         data = json::parse(inputJson);
/usr/local/src/QGIS/external/pdal_wrench/vpc.cpp:107:24: error: variable
‘nlohmann::json firstAsset’ has initializer but incomplete type
   107 |         nlohmann::json firstAsset = *f["assets"].begin();
/usr/local/src/QGIS/external/pdal_wrench/vpc.cpp:116:24: error: variable
‘nlohmann::json nativeGeometry’ has initializer but incomplete type
   116 |         nlohmann::json nativeGeometry =
f["properties"]["proj:geometry"];
/usr/local/src/QGIS/external/pdal_wrench/vpc.cpp:123:24: error: variable
‘nlohmann::json nativeBbox’ has initializer but incomplete type
   123 |         nlohmann::json nativeBbox = f["properties"]["proj:bbox"];
/usr/local/src/QGIS/external/pdal_wrench/vpc.cpp:124:26: error: expected
primary-expression before ‘(’ token
   124 |         vpcf.bbox = BOX3D(
/usr/local/src/QGIS/external/pdal_wrench/vpc.cpp:125:31: error: expected
primary-expression before ‘double’
   125 |             nativeBbox[0].get<double>(),
nativeBbox[1].get<double>(), nativeBbox[2].get<double>(),
/usr/local/src/QGIS/external/pdal_wrench/vpc.cpp:125:60: error: expected
/usr/local/src/QGIS/external/pdal_wrench/vpc.cpp:125:89: error: expected
/usr/local/src/QGIS/external/pdal_wrench/vpc.cpp:126:31: error: expected
   126 |             nativeBbox[3].get<double>(),
nativeBbox[4].get<double>(), nativeBbox[5].get<double>() );
/usr/local/src/QGIS/external/pdal_wrench/vpc.cpp:126:60: error: expected
/usr/local/src/QGIS/external/pdal_wrench/vpc.cpp:126:89: error: expected
/usr/local/src/QGIS/external/pdal_wrench/vpc.cpp:136:64: error: expected
   136 |
vpcf.schema.push_back(VirtualPointCloud::SchemaItem(schemaItem["name"],
schemaItem["type"], schemaItem["size"].get<int>()));
/usr/local/src/QGIS/external/pdal_wrench/vpc.cpp:136:128: error:
expected primary-expression before ‘int’
   136 |
/usr/local/src/QGIS/external/pdal_wrench/vpc.cpp: In function ‘void
geometryToJson(const pdal::Geometry&, const pdal::BOX3D&,
nlohmann::json&, nlohmann::json&)’:
/usr/local/src/QGIS/external/pdal_wrench/vpc.cpp:184:5: error: invalid
   184 |     jsonBbox = { bbox.minx, bbox.miny, bbox.minz, bbox.maxx,
bbox.maxy, bbox.maxz };
/usr/local/src/QGIS/external/pdal_wrench/vpc.cpp:189:30: error:
name specifier
   189 |         jsonGeometry = json::parse(strGeom);
‘bool VirtualPointCloud::write(std::string)’:
/usr/local/src/QGIS/external/pdal_wrench/vpc.cpp:234:24: error:
aggregate ‘nlohmann::json jsonGeometry’ has incomplete type and cannot
be defined
   234 |         nlohmann::json jsonGeometry, jsonBbox;
/usr/local/src/QGIS/external/pdal_wrench/vpc.cpp:234:38: error:
aggregate ‘nlohmann::json jsonBbox’ has incomplete type and cannot be
defined
/usr/local/src/QGIS/external/pdal_wrench/vpc.cpp:238:24: error: variable
‘nlohmann::json jsonGeometryWgs84’ has initializer but incomplete type
   238 |         nlohmann::json jsonGeometryWgs84 = jsonGeometry,
jsonBboxWgs84 = jsonBbox;
/usr/local/src/QGIS/external/pdal_wrench/vpc.cpp:238:58: error: variable
‘nlohmann::json jsonBboxWgs84’ has initializer but incomplete type
/usr/local/src/QGIS/external/pdal_wrench/vpc.cpp:256:13: error: too many
initializers for ‘nlohmann::json’ {aka ‘nlohmann::basic_json<>’}
   256 |             });
/usr/local/src/QGIS/external/pdal_wrench/vpc.cpp:259:24: error: variable
‘nlohmann::json props’ has initializer but incomplete type
   259 |         nlohmann::json props = {
/usr/local/src/QGIS/external/pdal_wrench/vpc.cpp:280:28: error: variable
‘nlohmann::json statsArray’ has initializer but incomplete type
   280 |             nlohmann::json statsArray = json::array();
/usr/local/src/QGIS/external/pdal_wrench/vpc.cpp:280:47: error:
name specifier
/usr/local/src/QGIS/external/pdal_wrench/vpc.cpp:283:32: error: variable
‘nlohmann::json stat’ has initializer but incomplete type
   283 |                 nlohmann::json stat = {
/usr/local/src/QGIS/external/pdal_wrench/vpc.cpp:298:24: error: variable
‘nlohmann::json links’ has initializer but incomplete type
   298 |         nlohmann::json links = json::array();
/usr/local/src/QGIS/external/pdal_wrench/vpc.cpp:298:38: error:
name specifier
/usr/local/src/QGIS/external/pdal_wrench/vpc.cpp:300:24: error: variable
‘nlohmann::json dataAsset’ has initializer but incomplete type
   300 |         nlohmann::json dataAsset = {
/usr/local/src/QGIS/external/pdal_wrench/vpc.cpp:302:30: error:
name specifier
   302 |             { "roles", json::array({"data"}) },
/usr/local/src/QGIS/external/pdal_wrench/vpc.cpp:304:24: error: variable
‘nlohmann::json assets’ has initializer but incomplete type
   304 |         nlohmann::json assets = { { "data", dataAsset } };
/usr/local/src/QGIS/external/pdal_wrench/vpc.cpp:321:28: error: variable
‘nlohmann::json overviewAsset’ has initializer but incomplete type
   321 |             nlohmann::json overviewAsset = {
/usr/local/src/QGIS/external/pdal_wrench/vpc.cpp:323:34: error:
name specifier
   323 |                 { "roles", json::array({"overview"}) },
/usr/local/src/QGIS/external/pdal_wrench/vpc.cpp:328:25: error: no
matching function for call to
‘std::vector<nlohmann::basic_json<nlohmann::ordered_map>
 >::push_back(<brace-enclosed initializer list>)’
   328 |         jFiles.push_back(
   329 |         {
   330 |             { "type", "Feature" },
   331 |             { "stac_version", "1.0.0" },
   332 |             { "stac_extensions",
   333 |                 {
   334 | "https://stac-extensions.github.io/pointcloud/v1.0.0/schema.json",
   335 | "https://stac-extensions.github.io/projection/v1.1.0/schema.json"
   336 |                 }
   337 |             },
   338 |             { "id", fileId },
   339 |             { "geometry", jsonGeometryWgs84 },
   340 |             { "bbox", jsonBboxWgs84 },
   341 |             { "properties", props },
   342 |             { "links", links },
   343 |             { "assets", assets },
   344 |
   345 |         });
In file included from /usr/include/c++/14/vector:66,
                  from /usr/local/src/QGIS/external/pdal_wrench/vpc.hpp:15:
/usr/include/c++/14/bits/stl_vector.h:1283:7: note: candidate: ‘void
std::vector<_Tp, _Alloc>::push_back(const value_type&) [with _Tp =
nlohmann::basic_json<nlohmann::ordered_map>; _Alloc =
std::allocator<nlohmann::basic_json<nlohmann::ordered_map> >; value_type
= nlohmann::basic_json<nlohmann::ordered_map>]’
  1283 |       push_back(const value_type& __x)
/usr/include/c++/14/bits/stl_vector.h:1283:35: note:   no known
conversion for argument 1 from ‘<brace-enclosed initializer list>’ to
‘const std::vector<nlohmann::basic_json<nlohmann::ordered_map>
 >::value_type&’ {aka ‘const nlohmann::basic_json<nlohmann::ordered_map>&’}
/usr/include/c++/14/bits/stl_vector.h:1300:7: note: candidate: ‘void
std::vector<_Tp, _Alloc>::push_back(value_type&&) [with _Tp =
  1300 |       push_back(value_type&& __x)
/usr/include/c++/14/bits/stl_vector.h:1300:30: note:   no known
 >::value_type&&’ {aka ‘nlohmann::basic_json<nlohmann::ordered_map>&&’}
/usr/local/src/QGIS/external/pdal_wrench/vpc.cpp:349:28: error: variable
‘nlohmann::ordered_json j’ has initializer but incomplete type
   349 |     nlohmann::ordered_json j = { { "type", "FeatureCollection"
}, { "features", jFiles } };
/usr/include/c++/14/bits/stl_vector.h: In instantiation of
‘std::_Vector_base<_Tp, _Alloc>::~_Vector_base() [with _Tp =
std::allocator<nlohmann::basic_json<nlohmann::ordered_map> >]’:
/usr/include/c++/14/bits/stl_vector.h:531:7:   required from here
   531 |       vector() = default;
/usr/include/c++/14/bits/stl_vector.h:369:49: error: invalid use of
incomplete type ‘class nlohmann::basic_json<nlohmann::ordered_map>’
   369 |                       _M_impl._M_end_of_storage -
_M_impl._M_start);
/usr/local/include/pdal/JsonFwd.hpp:40:7: note: declaration of ‘class
nlohmann::basic_json<>; _Alloc = std::allocator<nlohmann::basic_json<> >]’:
incomplete type ‘class nlohmann::basic_json<>’
_M_impl._M_start);
In file included from /usr/include/c++/14/bits/move.h:37,
                  from /usr/include/c++/14/bits/exception_ptr.h:41,
                  from /usr/include/c++/14/exception:166,
                  from /usr/include/c++/14/ios:41,
                  from /usr/include/c++/14/ostream:40,
                  from /usr/include/c++/14/iostream:41,
                  from /usr/local/src/QGIS/external/pdal_wrench/vpc.cpp:13:
/usr/include/c++/14/type_traits: In instantiation of ‘struct
std::is_destructible<nlohmann::basic_json<nlohmann::ordered_map> >’:
/usr/include/c++/14/bits/stl_construct.h:188:51:   required from ‘void
std::_Destroy(_ForwardIterator, _ForwardIterator) [with _ForwardIterator
= nlohmann::basic_json<nlohmann::ordered_map>*]’
   188 | static_assert(is_destructible<_Value_type>::value,
/usr/include/c++/14/bits/alloc_traits.h:993:20:   required from ‘void
std::_Destroy(_ForwardIterator, _ForwardIterator, allocator<_T2>&) [with
_ForwardIterator = nlohmann::basic_json<nlohmann::ordered_map>*; _Tp =
   993 |       std::_Destroy(__first, __last);
/usr/include/c++/14/bits/stl_vector.h:735:15:   required from
‘std::vector<_Tp, _Alloc>::~vector() [with _Tp =
   735 |         std::_Destroy(this->_M_impl._M_start,
this->_M_impl._M_finish,
   736 |                       _M_get_Tp_allocator());
/usr/local/src/QGIS/external/pdal_wrench/vpc.cpp:214:41: required from here
   214 |     std::vector<nlohmann::ordered_json> jFiles;
/usr/include/c++/14/type_traits:1049:52: error: static assertion failed:
template argument must be a complete class or an unbounded array
  1049 |
static_assert(std::__is_complete_or_unbounded(__type_identity<_Tp>{}),
/usr/include/c++/14/type_traits:1049:52: note:
‘std::__is_complete_or_unbounded<__type_identity<nlohmann::basic_json<nlohmann::ordered_map>
 > >((std::__type_identity<nlohmann::basic_json<nlohmann::ordered_map>
 >(), std::__type_identity<nlohmann::basic_json<nlohmann::ordered_map>
 >()))’ evaluates to false
In file included from /usr/include/c++/14/bits/alloc_traits.h:33,
                  from /usr/include/c++/14/ext/alloc_traits.h:34,
                  from /usr/include/c++/14/bits/basic_string.h:39,
                  from /usr/include/c++/14/string:54,
                  from /usr/include/c++/14/bits/locale_classes.h:40,
                  from /usr/include/c++/14/bits/ios_base.h:41,
                  from /usr/include/c++/14/ios:44:
/usr/include/c++/14/bits/stl_construct.h: In instantiation of ‘void
= nlohmann::basic_json<nlohmann::ordered_map>*]’:
/usr/include/c++/14/bits/stl_construct.h:188:51: error: static assertion
failed: value type is destructible
/usr/include/c++/14/bits/stl_construct.h:188:51: note:
‘std::integral_constant<bool, false>::value’ evaluates to false
/usr/include/c++/14/bits/stl_construct.h:195:25: error: invalid use of
incomplete type
‘std::iterator_traits<nlohmann::basic_json<nlohmann::ordered_map>*>::value_type’
{aka ‘class nlohmann::basic_json<nlohmann::ordered_map>’}
   195 | std::_Destroy_aux<__has_trivial_destructor(_Value_type)>::
std::is_destructible<nlohmann::basic_json<> >’:
= nlohmann::basic_json<>*]’
_ForwardIterator = nlohmann::basic_json<>*; _Tp = nlohmann::basic_json<>]’
‘std::vector<_Tp, _Alloc>::~vector() [with _Tp = nlohmann::basic_json<>;
/usr/local/src/QGIS/external/pdal_wrench/vpc.cpp:249:37: required from here
   249 |         std::vector<nlohmann::json> schemas;
  1049 |
‘std::__is_complete_or_unbounded<__type_identity<nlohmann::basic_json<>
 > >((std::__type_identity<nlohmann::basic_json<> >(),
std::__type_identity<nlohmann::basic_json<> >()))’ evaluates to false
= nlohmann::basic_json<>*]’:
incomplete type
‘std::iterator_traits<nlohmann::basic_json<>*>::value_type’ {aka ‘class
[ 30%] Built target qgis_core
[ 30%] Built target provider_delimitedtext_a_autogen_timestamp_deps
[ 30%] Built target provider_wms_a_autogen_timestamp_deps
[ 30%] [FLEX][QgsRasterCalcLexer] Building scanner with flex 2.6.4
[ 30%] Built target provider_arcgismapserver_a_autogen_timestamp_deps
[ 30%] Built target qgis_gui_autogen_timestamp_deps
/usr/include/c++/14/x86_64-suse-linux/bits/c++allocator.h:33,
                  from /usr/include/c++/14/bits/allocator.h:46,
                  from /usr/include/c++/14/string:43:
/usr/include/c++/14/bits/new_allocator.h: In instantiation of ‘void
std::__new_allocator<_Tp>::deallocate(_Tp*, size_type) [with _Tp =
nlohmann::basic_json<nlohmann::ordered_map>; size_type = long unsigned
int]’:
/usr/include/c++/14/bits/alloc_traits.h:550:23:   required from ‘static
void std::allocator_traits<std::allocator<_CharT>
 >::deallocate(allocator_type&, pointer, size_type) [with _Tp =
nlohmann::basic_json<nlohmann::ordered_map>; allocator_type =
std::allocator<nlohmann::basic_json<nlohmann::ordered_map> >; pointer =
nlohmann::basic_json<nlohmann::ordered_map>*; size_type = long unsigned
int]’
   550 |       { __a.deallocate(__p, __n); }
/usr/include/c++/14/bits/stl_vector.h:389:19:   required from ‘void
std::_Vector_base<_Tp, _Alloc>::_M_deallocate(pointer, std::size_t)
[with _Tp = nlohmann::basic_json<nlohmann::ordered_map>; _Alloc =
nlohmann::basic_json<nlohmann::ordered_map>*; std::size_t = long
unsigned int]’
   389 |           _Tr::deallocate(_M_impl, __p, __n);
/usr/include/c++/14/bits/stl_vector.h:368:2:   required from
   368 |         _M_deallocate(_M_impl._M_start,
/usr/include/c++/14/bits/new_allocator.h:165:13: error: invalid
application of ‘__alignof__’ to incomplete type
‘nlohmann::basic_json<nlohmann::ordered_map>’
   165 |         if (alignof(_Tp) > __STDCPP_DEFAULT_NEW_ALIGNMENT__)
/usr/include/c++/14/bits/new_allocator.h:167:38: error: invalid
application of ‘sizeof’ to incomplete type
   167 | _GLIBCXX_OPERATOR_DELETE(_GLIBCXX_SIZED_DEALLOC(__p, __n),
/usr/include/c++/14/bits/new_allocator.h:168:55: error: invalid
   168 | std::align_val_t(alignof(_Tp)));
/usr/include/c++/14/bits/new_allocator.h:172:34: error: invalid
   172 | _GLIBCXX_OPERATOR_DELETE(_GLIBCXX_SIZED_DEALLOC(__p, __n));
nlohmann::basic_json<>; size_type = long unsigned int]’:
nlohmann::basic_json<>; allocator_type =
std::allocator<nlohmann::basic_json<> >; pointer =
nlohmann::basic_json<>*; size_type = long unsigned int]’
[with _Tp = nlohmann::basic_json<>; _Alloc =
nlohmann::basic_json<>*; std::size_t = long unsigned int]’
application of ‘__alignof__’ to incomplete type ‘nlohmann::basic_json<>’
application of ‘sizeof’ to incomplete type ‘nlohmann::basic_json<>’
[ 30%] [BISON][QgsRasterCalcParser] Building parser with bison 3.8.2
[ 30%] Built target provider_arcgismapserver_autogen_timestamp_deps
[ 30%] Built target provider_virtuallayer_a_autogen_timestamp_deps
[ 30%] Built target crssync_autogen_timestamp_deps
[ 30%] Built target provider_pdal_a_autogen_timestamp_deps
[ 30%] Built target qgispython_autogen_timestamp_deps
[ 30%] Generating core/build/_core/sip_corepart0.cpp,
core/build/_core/sip_corepart1.cpp, core/build/_core/sip_corepart2.cpp,
core/build/_core/sip_corepart3.cpp, core/build/_core/sip_corepart4.cpp,
core/build/_core/sip_corepart5.cpp, core/build/_core/sip_corepart6.cpp,
core/build/_core/sip_corepart7.cpp, core/build/_core/sip_corepart8.cpp,
core/build/_core/sip_corepart9.cpp, core/build/_core/sip_corepart10.cpp,
core/build/_core/sip_corepart11.cpp,
core/build/_core/sip_corepart12.cpp,
core/build/_core/sip_corepart13.cpp,
core/build/_core/sip_corepart14.cpp,
core/build/_core/sip_corepart15.cpp,
core/build/_core/sip_corepart16.cpp,
core/build/_core/sip_corepart17.cpp,
core/build/_core/sip_corepart18.cpp, core/build/_core/sip_corepart19.cpp
[ 30%] Built target qgis_test_autogen_timestamp_deps
[ 30%] Built target qgis_bench_autogen_timestamp_deps
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250428/a1ed796a/attachment-0001.htm>
More information about the QGIS-Developer mailing list
