[QGIS-Developer] Understanding errors while building QGIS master
    Hernán De Angelis
    variablestarlight at gmail.com
    Tue Apr 29 01:34:07 PDT 2025
Hi Stefanos,
Thanks for the suggestion, I will definitely try that. In any case it is
baffling that build fails using both internal and external (3.12).
I currently suspect deeper issues in gcc and how libstdc++ is linked in
my system or the may be the OS. Up to two weeks ago I could compile QGIS
painlessly.
Hernán
Den 2025-04-29 kl. 10:18, skrev Stefanos Natsis:
> Hi Hernan,
> Nlohmann json got updated to 3.11.3 in
> https://github.com/qgis/QGIS/pull/61597 a few days ago, maybe you
> could try building master before that?
> Best
> Stefanos
> On Tue, Apr 29, 2025, 10:04 AM Hernán De Angelis via QGIS-Developer
> <qgis-developer at lists.osgeo.org> wrote:
>     Hi
>     I seek help in understanding errors (see excerpt below) I am
>     currently experiencing while building QGIS master in a fresh
>     openSUSE Tumbleweed install. These errors seem to originate in
>     nlohmann json. I am used to compile QGIS from source but never
>     seen these errors before and have trouble figuring out where they
>     originate and what a possible solution could be.
>     I am using Qt 6.9.0, and tried compiling using both GCC 14 and 15.
>     Passing the CXX flag "-std=c++17" does not seem to help. I tried
>     using NLOHMANN both internal and also using the latest version
>     compiled locally (3.12, as in error log below) but both fail in a
>     similar way.
>     I compiled QGIS master as late as 6 april without problems in a
>     previous openSUSE install. There is a very real the possibility
>     that recent changes in GCC14 and 15 regarding required standards
>     are playing a part here, as well as packaging changes in openSUSE
>     Tumbleweed. However, as I am unsure what the cause may be I would
>     like to ask the developers if these errors look familiar to you
>     and if they suggest something.
>     Thanks in advance
>     Hernán
>     [ 12%] Built target staged-plugins-on-build
>     In file included from
>     /usr/local/src/QGIS/external/nlohmann/detail/value_t.hpp:16,
>                      from
>     /usr/local/src/QGIS/external/nlohmann/detail/exceptions.hpp:20,
>                      from
>     /usr/local/src/QGIS/external/nlohmann/detail/conversions/from_json.hpp:23,
>                      from
>     /usr/local/src/QGIS/external/nlohmann/adl_serializer.hpp:14,
>                      from
>     /usr/local/src/QGIS/external/nlohmann/json.hpp:34,
>                      from
>     /usr/local/src/QGIS/external/pdal_wrench/vpc.cpp:26:
>     /usr/local/src/QGIS/external/nlohmann/detail/macro_scope.hpp:257:63:
>     error: wrong number of template arguments (11, should be at least 0)
>       257 |     AllocatorType, JSONSerializer, BinaryType,
>     CustomBaseClass>
>     /usr/local/src/QGIS/external/nlohmann/detail/meta/type_traits.hpp:53:22:
>     note: in expansion of macro ‘NLOHMANN_BASIC_JSON_TPL’
>        53 | struct is_basic_json<NLOHMANN_BASIC_JSON_TPL> :
>     std::true_type {};
>     In file included from /usr/local/include/pdal/PDALUtils.hpp:39,
>                      from /usr/local/include/pdal/PointRef.hpp:37,
>                      from /usr/local/include/pdal/Geometry.hpp:37,
>                      from
>     /usr/local/src/QGIS/external/pdal_wrench/vpc.hpp:18,
>                      from
>     /usr/local/src/QGIS/external/pdal_wrench/vpc.cpp:19:
>     /usr/local/include/pdal/JsonFwd.hpp:40:7: note: provided for
>     ‘template<template<class U, class V, class ... Args> class
>     ObjectType, template<class U, class ... Args> class ArrayType,
>     class StringType, class BooleanType, class NumberIntegerType,
>     class NumberUnsignedType, class NumberFloatType, template<class U>
>     class AllocatorType, template<class T, class SFINAE> class
>     JSONSerializer, class BinaryType> class nlohmann::basic_json’
>        40 | class basic_json;
>     /usr/local/src/QGIS/external/nlohmann/detail/exceptions.hpp:25:
>     /usr/local/src/QGIS/external/nlohmann/detail/meta/type_traits.hpp:53:45:
>     error: template argument 1 is invalid
>     std::true_type {};
>     CustomBaseClass>
>     /usr/local/src/QGIS/external/nlohmann/detail/json_pointer.hpp:51:28:
>        51 |     struct string_t_helper<NLOHMANN_BASIC_JSON_TPL>
>     /usr/local/src/QGIS/external/nlohmann/json.hpp:50:
>     /usr/local/src/QGIS/external/nlohmann/detail/json_pointer.hpp:51:51:
>     /usr/local/src/QGIS/external/nlohmann/json.hpp:104:30: error:
>     reference to ‘json_pointer’ is ambiguous
>       104 |     friend class ::nlohmann::json_pointer;
>     /usr/local/src/QGIS/external/nlohmann/detail/json_pointer.hpp:35:7:
>     note: candidates are: ‘template<class RefStringType> class
>     nlohmann::json_abi_v3_11_3::json_pointer’
>        35 | class json_pointer
>     /usr/local/include/pdal/JsonFwd.hpp:45:7: note:
>     ‘template<class BasicJsonType> class nlohmann::json_pointer’
>        45 | class json_pointer;
>     /usr/local/src/QGIS/external/nlohmann/json.hpp:166:26: error:
>       166 |     using json_pointer = ::nlohmann::json_pointer<StringType>;
>     /usr/local/src/QGIS/external/nlohmann/json.hpp:2327:21: error:
>     missing template argument list after
>     ‘nlohmann::json_abi_v3_11_3::json_pointer’; template placeholder
>     not permitted in parameter
>      2327 |     ValueType value(const json_pointer& ptr, const
>     ValueType& default_value) const
>     note: ‘template<class RefStringType> class
>     nlohmann::json_abi_v3_11_3::json_pointer’ declared here
>     /usr/local/src/QGIS/external/nlohmann/json.hpp:2352:22: error:
>      2352 |     ReturnType value(const json_pointer& ptr, ValueType &&
>     /usr/local/src/QGIS/external/nlohmann/json.hpp:2376:27: error:
>      2376 |     ValueType value(const
>     ::nlohmann::json_pointer<BasicJsonType>& ptr, const ValueType&
>     /usr/local/src/QGIS/external/nlohmann/json.hpp:2376:51: error:
>     expected ‘,’ or ‘...’ before ‘<’ token
>     /usr/local/src/QGIS/external/nlohmann/json.hpp:2387:28: error:
>      2387 |     ReturnType value(const
>     ::nlohmann::json_pointer<BasicJsonType>& ptr, ValueType &&
>     /usr/local/src/QGIS/external/nlohmann/json.hpp:2387:52: error:
>     /usr/local/src/QGIS/external/nlohmann/json.hpp:2745:19: error:
>      2745 |     bool contains(const json_pointer& ptr) const
>     /usr/local/src/QGIS/external/nlohmann/json.hpp:2752:46: error:
>      2752 |     bool contains(const typename
>     ::nlohmann::json_pointer<BasicJsonType>& ptr) const
>     /usr/local/src/QGIS/external/nlohmann/json.hpp:2752:58: error:
>     /usr/local/src/QGIS/external/nlohmann/json.hpp:4618:26: error:
>      4618 |     reference operator[](const json_pointer& ptr)
>     /usr/local/src/QGIS/external/nlohmann/json.hpp:4618:15: error:
>     ‘nlohmann::json_abi_v3_11_3::basic_json<ObjectType, ArrayType,
>     StringType, BooleanType, NumberIntegerType, NumberUnsignedType,
>     NumberFloatType, AllocatorType, JSONSerializer, BinaryType,
>     CustomBaseClass>::value_type&
>     CustomBaseClass>::operator[](...)’ must not have variable number
>     of arguments
>     /usr/local/src/QGIS/external/nlohmann/json.hpp:4625:32: error:
>      4625 |     reference operator[](const
>     /usr/local/src/QGIS/external/nlohmann/json.hpp:4625:56: error:
>     /usr/local/src/QGIS/external/nlohmann/json.hpp:4632:32: error:
>      4632 |     const_reference operator[](const json_pointer& ptr) const
>     /usr/local/src/QGIS/external/nlohmann/json.hpp:4632:21: error:
>     ‘const nlohmann::json_abi_v3_11_3::basic_json<ObjectType,
>     ArrayType, StringType, BooleanType, NumberIntegerType,
>     NumberUnsignedType, NumberFloatType, AllocatorType,
>     JSONSerializer, BinaryType, CustomBaseClass>::value_type&
>     CustomBaseClass>::operator[](...) const’ must not have variable
>     number of arguments
>     /usr/local/src/QGIS/external/nlohmann/json.hpp:4639:38: error:
>      4639 |     const_reference operator[](const
>     /usr/local/src/QGIS/external/nlohmann/json.hpp:4639:62: error:
>     /usr/local/src/QGIS/external/nlohmann/json.hpp:4646:18: error:
>      4646 |     reference at(const json_pointer& ptr)
>     /usr/local/src/QGIS/external/nlohmann/json.hpp:4653:24: error:
>      4653 |     reference at(const
>     /usr/local/src/QGIS/external/nlohmann/json.hpp:4653:48: error:
>     /usr/local/src/QGIS/external/nlohmann/json.hpp:4660:24: error:
>      4660 |     const_reference at(const json_pointer& ptr) const
>     /usr/local/src/QGIS/external/nlohmann/json.hpp:4667:30: error:
>      4667 |     const_reference at(const
>     /usr/local/src/QGIS/external/nlohmann/json.hpp:4667:54: error:
>     _______________________________________________
>     QGIS-Developer mailing list
>     QGIS-Developer at lists.osgeo.org
>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250429/d7449929/attachment-0001.htm>
