[QGIS-Developer] Understanding errors while building QGIS master
Hernán De Angelis variablestarlight at gmail.com
Tue Apr 29 04:13:19 PDT 2025
I can now confirm that 3.42.1 and 3.42.2 compile well and trouble-free
in openSUSE Tumbleweed using GCC 14.2, Qt 6.9.0 and internal nlohmann
json. I have not tried GCC 15 nor clang yet.
My current belief is that something may not be completely right with the
current integration of nlohmann in QGIS master. I will report an issue
after more tests.
Thanks Jorge and Stefanos for help.
Hernán
Den 2025-04-29 kl. 10:34, skrev Hernán De Angelis:
> Hi Stefanos,
> Thanks for the suggestion, I will definitely try that. In any case it
> is baffling that build fails using both internal and external (3.12).
> I currently suspect deeper issues in gcc and how libstdc++ is linked
> in my system or the may be the OS. Up to two weeks ago I could compile
> QGIS painlessly.
> Hernán
> Den 2025-04-29 kl. 10:18, skrev Stefanos Natsis:
>> Hi Hernan,
>> Nlohmann json got updated to 3.11.3 in
>> https://github.com/qgis/QGIS/pull/61597 a few days ago, maybe you
>> could try building master before that?
>> Best
>> Stefanos
>> On Tue, Apr 29, 2025, 10:04 AM Hernán De Angelis via QGIS-Developer
>> <qgis-developer at lists.osgeo.org> wrote:
>>     Hi
>>     I seek help in understanding errors (see excerpt below) I am
>>     currently experiencing while building QGIS master in a fresh
>>     openSUSE Tumbleweed install. These errors seem to originate in
>>     nlohmann json. I am used to compile QGIS from source but never
>>     seen these errors before and have trouble figuring out where they
>>     originate and what a possible solution could be.
>>     I am using Qt 6.9.0, and tried compiling using both GCC 14 and
>>     15. Passing the CXX flag "-std=c++17" does not seem to help. I
>>     tried using NLOHMANN both internal and also using the latest
>>     version compiled locally (3.12, as in error log below) but both
>>     fail in a similar way.
>>     I compiled QGIS master as late as 6 april without problems in a
>>     previous openSUSE install. There is a very real the possibility
>>     that recent changes in GCC14 and 15 regarding required standards
>>     are playing a part here, as well as packaging changes in openSUSE
>>     Tumbleweed. However, as I am unsure what the cause may be I would
>>     like to ask the developers if these errors look familiar to you
>>     and if they suggest something.
>>     Thanks in advance
>>     Hernán
>>     [ 12%] Built target staged-plugins-on-build
>>     In file included from
>>     /usr/local/src/QGIS/external/nlohmann/detail/value_t.hpp:16,
>>                      from
>>     /usr/local/src/QGIS/external/nlohmann/detail/exceptions.hpp:20,
>>                      from
>>     /usr/local/src/QGIS/external/nlohmann/detail/conversions/from_json.hpp:23,
>>                      from
>>     /usr/local/src/QGIS/external/nlohmann/adl_serializer.hpp:14,
>>                      from
>>     /usr/local/src/QGIS/external/nlohmann/json.hpp:34,
>>                      from
>>     /usr/local/src/QGIS/external/pdal_wrench/vpc.cpp:26:
>>     /usr/local/src/QGIS/external/nlohmann/detail/macro_scope.hpp:257:63:
>>     error: wrong number of template arguments (11, should be at least 0)
>>       257 |     AllocatorType, JSONSerializer, BinaryType,
>>     CustomBaseClass>
>>     /usr/local/src/QGIS/external/nlohmann/detail/meta/type_traits.hpp:53:22:
>>     note: in expansion of macro ‘NLOHMANN_BASIC_JSON_TPL’
>>        53 | struct is_basic_json<NLOHMANN_BASIC_JSON_TPL> :
>>     std::true_type {};
>>     In file included from /usr/local/include/pdal/PDALUtils.hpp:39,
>>                      from /usr/local/include/pdal/PointRef.hpp:37,
>>                      from /usr/local/include/pdal/Geometry.hpp:37,
>>                      from
>>     /usr/local/src/QGIS/external/pdal_wrench/vpc.hpp:18,
>>                      from
>>     /usr/local/src/QGIS/external/pdal_wrench/vpc.cpp:19:
>>     /usr/local/include/pdal/JsonFwd.hpp:40:7: note: provided for
>>     ‘template<template<class U, class V, class ... Args> class
>>     ObjectType, template<class U, class ... Args> class ArrayType,
>>     class StringType, class BooleanType, class NumberIntegerType,
>>     class NumberUnsignedType, class NumberFloatType, template<class
>>     U> class AllocatorType, template<class T, class SFINAE> class
>>     JSONSerializer, class BinaryType> class nlohmann::basic_json’
>>        40 | class basic_json;
>>     /usr/local/src/QGIS/external/nlohmann/detail/exceptions.hpp:25:
>>     /usr/local/src/QGIS/external/nlohmann/detail/meta/type_traits.hpp:53:45:
>>     error: template argument 1 is invalid
>>     std::true_type {};
>>     CustomBaseClass>
>>     /usr/local/src/QGIS/external/nlohmann/detail/json_pointer.hpp:51:28:
>>        51 |     struct string_t_helper<NLOHMANN_BASIC_JSON_TPL>
>>     /usr/local/src/QGIS/external/nlohmann/json.hpp:50:
>>     /usr/local/src/QGIS/external/nlohmann/detail/json_pointer.hpp:51:51:
>>     /usr/local/src/QGIS/external/nlohmann/json.hpp:104:30: error:
>>     reference to ‘json_pointer’ is ambiguous
>>       104 |     friend class ::nlohmann::json_pointer;
>>     /usr/local/src/QGIS/external/nlohmann/detail/json_pointer.hpp:35:7:
>>     note: candidates are: ‘template<class RefStringType> class
>>     nlohmann::json_abi_v3_11_3::json_pointer’
>>        35 | class json_pointer
>>     /usr/local/include/pdal/JsonFwd.hpp:45:7: note:
>>     ‘template<class BasicJsonType> class nlohmann::json_pointer’
>>        45 | class json_pointer;
>>     /usr/local/src/QGIS/external/nlohmann/json.hpp:166:26: error:
>>       166 |     using json_pointer =
>>     ::nlohmann::json_pointer<StringType>;
>>     /usr/local/src/QGIS/external/nlohmann/json.hpp:2327:21: error:
>>     missing template argument list after
>>     ‘nlohmann::json_abi_v3_11_3::json_pointer’; template placeholder
>>     not permitted in parameter
>>      2327 |     ValueType value(const json_pointer& ptr, const
>>     ValueType& default_value) const
>>     note: ‘template<class RefStringType> class
>>     nlohmann::json_abi_v3_11_3::json_pointer’ declared here
>>     /usr/local/src/QGIS/external/nlohmann/json.hpp:2352:22: error:
>>      2352 |     ReturnType value(const json_pointer& ptr, ValueType
>>     && default_value) const
>>     /usr/local/src/QGIS/external/nlohmann/json.hpp:2376:27: error:
>>      2376 |     ValueType value(const
>>     ::nlohmann::json_pointer<BasicJsonType>& ptr, const ValueType&
>>     /usr/local/src/QGIS/external/nlohmann/json.hpp:2376:51: error:
>>     expected ‘,’ or ‘...’ before ‘<’ token
>>     /usr/local/src/QGIS/external/nlohmann/json.hpp:2387:28: error:
>>      2387 |     ReturnType value(const
>>     ::nlohmann::json_pointer<BasicJsonType>& ptr, ValueType &&
>>     /usr/local/src/QGIS/external/nlohmann/json.hpp:2387:52: error:
>>     /usr/local/src/QGIS/external/nlohmann/json.hpp:2745:19: error:
>>      2745 |     bool contains(const json_pointer& ptr) const
>>     /usr/local/src/QGIS/external/nlohmann/json.hpp:2752:46: error:
>>      2752 |     bool contains(const typename
>>     ::nlohmann::json_pointer<BasicJsonType>& ptr) const
>>     /usr/local/src/QGIS/external/nlohmann/json.hpp:2752:58: error:
>>     /usr/local/src/QGIS/external/nlohmann/json.hpp:4618:26: error:
>>      4618 |     reference operator[](const json_pointer& ptr)
>>     /usr/local/src/QGIS/external/nlohmann/json.hpp:4618:15: error:
>>     ‘nlohmann::json_abi_v3_11_3::basic_json<ObjectType, ArrayType,
>>     StringType, BooleanType, NumberIntegerType, NumberUnsignedType,
>>     NumberFloatType, AllocatorType, JSONSerializer, BinaryType,
>>     CustomBaseClass>::value_type&
>>     CustomBaseClass>::operator[](...)’ must not have variable number
>>     of arguments
>>     /usr/local/src/QGIS/external/nlohmann/json.hpp:4625:32: error:
>>      4625 |     reference operator[](const
>>     /usr/local/src/QGIS/external/nlohmann/json.hpp:4625:56: error:
>>     /usr/local/src/QGIS/external/nlohmann/json.hpp:4632:32: error:
>>      4632 |     const_reference operator[](const json_pointer& ptr) const
>>     /usr/local/src/QGIS/external/nlohmann/json.hpp:4632:21: error:
>>     ‘const nlohmann::json_abi_v3_11_3::basic_json<ObjectType,
>>     ArrayType, StringType, BooleanType, NumberIntegerType,
>>     NumberUnsignedType, NumberFloatType, AllocatorType,
>>     JSONSerializer, BinaryType, CustomBaseClass>::value_type&
>>     CustomBaseClass>::operator[](...) const’ must not have variable
>>     number of arguments
>>     /usr/local/src/QGIS/external/nlohmann/json.hpp:4639:38: error:
>>      4639 |     const_reference operator[](const
>>     /usr/local/src/QGIS/external/nlohmann/json.hpp:4639:62: error:
>>     /usr/local/src/QGIS/external/nlohmann/json.hpp:4646:18: error:
>>      4646 |     reference at(const json_pointer& ptr)
>>     /usr/local/src/QGIS/external/nlohmann/json.hpp:4653:24: error:
>>      4653 |     reference at(const
>>     /usr/local/src/QGIS/external/nlohmann/json.hpp:4653:48: error:
>>     /usr/local/src/QGIS/external/nlohmann/json.hpp:4660:24: error:
>>      4660 |     const_reference at(const json_pointer& ptr) const
>>     /usr/local/src/QGIS/external/nlohmann/json.hpp:4667:30: error:
>>      4667 |     const_reference at(const
>>     /usr/local/src/QGIS/external/nlohmann/json.hpp:4667:54: error:
>>     _______________________________________________
>>     QGIS-Developer mailing list
>>     QGIS-Developer at lists.osgeo.org
>>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250429/27cedd02/attachment-0001.htm>
More information about the QGIS-Developer mailing list
