[QGIS-Developer] Nightlies for debian/ubuntu now include qt6
Patrick Dunford enzedrailmaps at gmail.com
Fri Aug 8 10:37:31 PDT 2025
There is a repository labelled trixie (added recently), which however
_cannot be installed on Debian trixie_. This is an alias of the Ubuntu
testing repository.
It seems to be the practice that Ubuntu and Debian installs have shared
repositories for some years, but they are different distributions built
on different criteria and there is sufficient risk of incompatible
packages to make it difficult to share a build between them.
It is also impossible to install Qgis LTR from your provided trixie
repository, due to the same packaging issue with python3-sip.
On 29/07/2025 23:45, Jürgen E. Fischer via QGIS-Developer wrote:
> Hi Andrea,
> On Tue, 29. Jul 2025 at 09:22:39 +0200, Andrea Giudiceandrea via QGIS-Developer wrote:
>> Il 29/07/2025 02:01, Patrick Dunford via QGIS-Developer ha scritto:
>>> As Debian 13 is shortly to release are there builds for this edition yet?
>> Isn't Debian 13, which is currently in testing development state, named
>> "trixie"?
> Correct.  See alsohttps://www.debian.org/releases/testing/
> Jürgen
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250809/6926b50b/attachment.htm>
More information about the QGIS-Developer mailing list
