[QGIS-Developer] Cannot add news feed item
Lova Andriarimalala
lova at kartoza.com
Sun Aug 10 23:29:43 PDT 2025
Hi Raymond and Richard,
Thank you for the clarification, and thanks for reporting the issue.
I will try to work on the QGIS Feed for the next two weeks.
Best regards,
Lova Andriarimalala
*QGIS Full Stack Developer *
*T *: +27(0) 87 809 2702 *E *: lova at kartoza.com *W* :
kartoza.com
*This email and any attachments are confidential and intended solely for
the use of the individual or entity to whom they are addressed. If you *
*have received this email in error, please notify the sender immediately
and delete it from your system. Unauthorised use, disclosure, or copying*
*of the contents is prohibited.*
On Sat, 9 Aug 2025 at 13:38, Raymond Nijssen via QGIS-Developer <
qgis-developer at lists.osgeo.org> wrote:
> Hi Lova,
> Richard and me figured out what is the problem. The content of a news
> item cannot be pasted, but only typed. I have created an issue:
> https://github.com/qgis/qgis-feed/issues/137
> Kind regards,
> Raymond
> On 8/9/25 11:06, Richard Duivenvoorde via QGIS-Developer wrote:
> > Based on Raymond's screendump I just created a new item.
> > It looks ok now?
> > One thing I noted is that I got a message that the max number of days
> > for an item to show is 10 days (the default value for the date range is
> > set to that), and on the Raymond's screenshot it is 21 days... Maybe
> > this makes the item silently rejected?
> > Regards,
> > On 09-08-2025 08:40, Raymond Nijssen via QGIS-Developer wrote:
> >> Thanks for testing Lova.
> >> My process is:
> >> Opening:
> >> https://feed.qgis.org/manage/add/
> >> Filling out the form, using a geofence and not a language setting.
> >> (Check the attached screenshot.)
> >> First I tried a period of 10+ days and thought that could be the
> >> problem, so later I tried with the default 10 day period. Then I
> >> Submit and check the review and submit again in the next screen.
> >> It's a bit annoying repeating this because of the geofence, which
> >> needs to be be redrawn every attempt (in a very tiny window. Maybe a
> >> wkt parser would be nice here, but that's a feature request! ;)
> >> Btw, in the screenshot I forgot to add the image, but I did that
> >> later. Anyway, if information is missing I would expect some kind of
> >> error message, but I didn't get anything like that. If you want we can
> >> share screens and figure it out together.
> >> Kind regards,
> >> Raymond
> >> Terglobo
> >> Fahrenheitstraat 1
> >> 5223 BJ 's-Hertogenbosch
> >> The Netherlands
> >> +31 (0) 6 25 31 49 83
> >> On 8/8/25 20:50, Lova Andriarimalala wrote:
> >>> Hi Raymond,
> >>> Could you please share more details about the process to reproduce
> >>> that? Is there any error message?
> >>> I have just checked adding a test feed, and it seems to be working
> fine.
> >>> Best regards,
> >>> Lova Andriarimalala
> >>> *T *: +27(0) 87 809 2702 *E *:**lova at kartoza.com
> >>> <mailto:lova at kartoza.com> *W* : kartoza.com <http://kartoza.com>
> >>> /This email and any attachments are confidential and intended solely
> >>> for the use of the individual or entity to whom they are addressed.
> >>> If you /
> >>> /have received this email in error, please notify the sender
> >>> immediately and delete it from your system. Unauthorised use,
> >>> disclosure, or copying/
> >>> /of the contents is prohibited./
> >>> On Fri, 8 Aug 2025 at 20:13, Raymond Nijssen via QGIS-Developer
> >>> <qgis- developer at lists.osgeo.org <mailto:qgis-
> >>> developer at lists.osgeo.org>> wrote:
> >>> I've tried 3x to add a news feed item but they don't seem to come
> >>> trough. Can anyone check if they are waiting somewhere? Or check
> >>> to add
> >>> a new item?
> >>> Tnx!
> >>> Raymond
> >>> _______________________________________________
> >>> QGIS-Developer mailing list
> >>> QGIS-Developer at lists.osgeo.org <mailto:QGIS-
> >>> Developer at lists.osgeo.org>
> >>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> >>> <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
> >>> Unsubscribe:
> >> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250811/d93687d2/attachment-0001.htm>
