[QGIS-Developer] Cannot add news feed item
Raymond Nijssen r.nijssen at terglobo.nl
Sat Aug 9 03:38:41 PDT 2025
Hi Lova,
Richard and me figured out what is the problem. The content of a news
item cannot be pasted, but only typed. I have created an issue:
https://github.com/qgis/qgis-feed/issues/137
Kind regards,
Raymond
On 8/9/25 11:06, Richard Duivenvoorde via QGIS-Developer wrote:
> Based on Raymond's screendump I just created a new item.
> It looks ok now?
> One thing I noted is that I got a message that the max number of days
> for an item to show is 10 days (the default value for the date range is
> set to that), and on the Raymond's  screenshot it is 21 days... Maybe
> this makes the item silently rejected?
> Regards,
> On 09-08-2025 08:40, Raymond Nijssen via QGIS-Developer wrote:
>> Thanks for testing Lova.
>> My process is:
>> Opening:
>> https://feed.qgis.org/manage/add/
>> Filling out the form, using a geofence and not a language setting.
>> (Check the attached screenshot.)
>> First I tried a period of 10+ days and thought that could be the
>> problem, so later I tried with the default 10 day period. Then I
>> Submit and check the review and submit again in the next screen.
>> It's a bit annoying repeating this because of the geofence, which
>> needs to be be redrawn every attempt (in a very tiny window. Maybe a
>> wkt parser would be nice here, but that's a feature request! ;)
>> Btw, in the screenshot I forgot to add the image, but I did that
>> later. Anyway, if information is missing I would expect some kind of
>> error message, but I didn't get anything like that. If you want we can
>> share screens and figure it out together.
>> Kind regards,
>> Raymond
>> Terglobo
>> Fahrenheitstraat 1
>> 5223 BJ 's-Hertogenbosch
>> The Netherlands
>> +31 (0) 6 25 31 49 83
>> On 8/8/25 20:50, Lova Andriarimalala wrote:
>>> Hi Raymond,
>>> Could you please share more details about the process to reproduce
>>> that? Is there any error message?
>>> I have just checked adding a test feed, and it seems to be working fine.
>>> Best regards,
>>> Lova Andriarimalala
>>> *QGIS Full Stack Developer
>>> *T *: +27(0) 87 809 2702 *E *:**lova at kartoza.com
>>> <mailto:lova at kartoza.com> *W* : kartoza.com <http://kartoza.com>
>>> /This email and any attachments are confidential and intended solely
>>> for the use of the individual or entity to whom they are addressed.
>>> If you /
>>> /have received this email in error, please notify the sender
>>> immediately and delete it from your system. Unauthorised use,
>>> disclosure, or copying/
>>> /of the contents is prohibited./
>>> On Fri, 8 Aug 2025 at 20:13, Raymond Nijssen via QGIS-Developer
>>> <qgis- developer at lists.osgeo.org <mailto:qgis-
>>> developer at lists.osgeo.org>> wrote:
>>>     I've tried 3x to add a news feed item but they don't seem to come
>>>     trough. Can anyone check if they are waiting somewhere? Or check
>>> to add
>>>     a new item?
>>>     Tnx!
>>>     Raymond
>>>     _______________________________________________
>>>     QGIS-Developer mailing list
>>>     QGIS-Developer at lists.osgeo.org <mailto:QGIS-
>>> Developer at lists.osgeo.org>
>>>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>     <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
>>>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
