[QGIS-Developer] Cannot add news feed item
Richard Duivenvoorde
rdmailings at duif.net
Sat Aug 9 02:06:08 PDT 2025
Based on Raymond's screendump I just created a new item.
It looks ok now?
One thing I noted is that I got a message that the max number of days for an item to show is 10 days (the default value for the date range is set to that), and on the Raymond's screenshot it is 21 days... Maybe this makes the item silently rejected?
Regards,
On 09-08-2025 08:40, Raymond Nijssen via QGIS-Developer wrote:
> Thanks for testing Lova.
> My process is:
> Opening:
> https://feed.qgis.org/manage/add/
> Filling out the form, using a geofence and not a language setting. (Check the attached screenshot.)
> First I tried a period of 10+ days and thought that could be the problem, so later I tried with the default 10 day period. Then I
> Submit and check the review and submit again in the next screen.
> It's a bit annoying repeating this because of the geofence, which needs to be be redrawn every attempt (in a very tiny window. Maybe a wkt parser would be nice here, but that's a feature request! ;)
> Btw, in the screenshot I forgot to add the image, but I did that later. Anyway, if information is missing I would expect some kind of error message, but I didn't get anything like that. If you want we can share screens and figure it out together.
> Kind regards,
> Raymond
> Terglobo
> Fahrenheitstraat 1
> 5223 BJ 's-Hertogenbosch
> The Netherlands
> +31 (0) 6 25 31 49 83
> On 8/8/25 20:50, Lova Andriarimalala wrote:
>> Hi Raymond,
>> Could you please share more details about the process to reproduce that? Is there any error message?
>> I have just checked adding a test feed, and it seems to be working fine.
>> Best regards,
>> Lova Andriarimalala
>> *QGIS Full Stack Developer
>> *T *: +27(0) 87 809 2702 *E *:**lova at kartoza.com <mailto:lova at kartoza.com> *W* : kartoza.com <http://kartoza.com>
>> /This email and any attachments are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you /
>> /have received this email in error, please notify the sender immediately and delete it from your system. Unauthorised use, disclosure, or copying/
>> /of the contents is prohibited./
>> On Fri, 8 Aug 2025 at 20:13, Raymond Nijssen via QGIS-Developer <qgis- developer at lists.osgeo.org <mailto:qgis-developer at lists.osgeo.org>> wrote:
>> I've tried 3x to add a news feed item but they don't seem to come
>> trough. Can anyone check if they are waiting somewhere? Or check to add
>> a new item?
>> Tnx!
>> Raymond
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
