[QGIS-Developer] HTTP 504 uploading new plugin version
Lova Andriarimalala
lova at kartoza.com
Fri Dec 5 04:09:33 PST 2025
Hi Ed,
There were some technical issues recently, but they have been fixed.
It's a timeout that you get when uploading a plugin. I am thinking of two
reasons: 1. Related to the plugin size, it's heavy and reaches the timeout
before fully uploading (it should be possible to increase the timeout on
the plugin server), or 2. The upload process checks the links provided in
the metadata (homepage, issue tracker...), but they are inaccessible or
return a timeout.
Best regards,
Lova Andriarimalala
*QGIS Full Stack Developer *
*T *: +27(0) 87 809 2702 *E *: lova at kartoza.com *W* :
kartoza.com
*This email and any attachments are confidential and intended solely for
the use of the individual or entity to whom they are addressed. If you *
*have received this email in error, please notify the sender immediately
and delete it from your system. Unauthorised use, disclosure, or copying*
*of the contents is prohibited.*
On Fri, 5 Dec 2025 at 14:48, Nash, Edward via QGIS-Developer <
qgis-developer at lists.osgeo.org> wrote:
> Hi,
> is the server for the plugin repository https://plugins.qgis.org/
> currently experiencing some technical problems? I was able to upload a new
> version for one of my plugins this morning, but for two other plugins I
> repeatedly get a Cloudflare HTTP 504 Gateway Timeout error and am unable to
> upload the new versions.
> Thanks in advance for your help!
> Ed
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20251205/19e391b6/attachment.htm>
