[QGIS-Developer] HTTP 504 uploading new plugin version
Nash, Edward
E.Nash at dvz-mv.de
Fri Dec 5 04:15:40 PST 2025
Hi Lova,
thanks for the fast response. The plugins are all small (< 100kB .zip), so the upload shouldn't be the problem. I'd also suspected a timeout could come if there is some problem with the links, but they're all https://github.com and all working for me. Could the server somehow be being blocked by GitHub - they seem to sometimes have some pretty aggressive rate-limiting and anti-crawler stuff in place?
Cheers,
Ed
-----Ursprüngliche Nachricht-----
Von: Lova Andriarimalala <lova at kartoza.com>
Gesendet: Freitag, 5. Dezember 2025 13:10
An: Nash, Edward <E.Nash at dvz-mv.de>
Cc: qgis-developer at lists.osgeo.org
Betreff: Re: [QGIS-Developer] HTTP 504 uploading new plugin version
Hi Ed,
There were some technical issues recently, but they have been fixed.
It's a timeout that you get when uploading a plugin. I am thinking of two reasons: 1. Related to the plugin size, it's heavy and reaches the timeout before fully uploading (it should be possible to increase the timeout on the plugin server), or 2. The upload process checks the links provided in the metadata (homepage, issue tracker...), but they are inaccessible or return a timeout.
Best regards,
Lova Andriarimalala
QGIS Full Stack Developer
T : +27(0) 87 809 2702 E : lova at kartoza.com <mailto:lova at kartoza.com> W : kartoza.com <http://kartoza.com>
<https://kartoza.com/files/KartozaEmailSignature.gif>
This email and any attachments are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error, please notify the sender immediately and delete it from your system. Unauthorised use, disclosure, or copying of the contents is prohibited.
On Fri, 5 Dec 2025 at 14:48, Nash, Edward via QGIS-Developer <qgis-developer at lists.osgeo.org <mailto:qgis-developer at lists.osgeo.org> > wrote:
is the server for the plugin repository https://plugins.qgis.org/ <https://plugins.qgis.org/> currently experiencing some technical problems? I was able to upload a new version for one of my plugins this morning, but for two other plugins I repeatedly get a Cloudflare HTTP 504 Gateway Timeout error and am unable to upload the new versions.
Thanks in advance for your help!
Ed
QGIS-Developer mailing list
QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
