[QGIS-Developer] HTTP 504 uploading new plugin version
Lova Andriarimalala lova at kartoza.com
Fri Dec 5 04:45:40 PST 2025
I have tried to upload a test plugin and got the error message as well. It
seems to be an issue on the website side (probably related to the previous
one).
We will try to investigate and fix that.
Thanks for reporting it.
Lova Andriarimalala
*QGIS Full Stack Developer   *
*T *: +27(0) 87 809 2702          *E *: lova at kartoza.com          *W* :
kartoza.com
*This email and any attachments are confidential and intended solely for
the use of the individual or entity to whom they are addressed. If you *
*have received this email in error, please notify the sender immediately
and delete it from your system. Unauthorised use, disclosure, or copying*
*of the contents is prohibited.*
On Fri, 5 Dec 2025 at 15:15, Nash, Edward <E.Nash at dvz-mv.de> wrote:
> Hi Lova,
> thanks for the fast response. The plugins are all small (< 100kB .zip), so
> the upload shouldn't be the problem. I'd also suspected a timeout could
> come if there is some problem with the links, but they're all
> https://github.com and all working for me. Could the server somehow be
> being blocked by GitHub - they seem to sometimes have some pretty
> aggressive rate-limiting and anti-crawler stuff in place?
> Cheers,
> Ed
> -----Ursprüngliche Nachricht-----
> Von: Lova Andriarimalala <lova at kartoza.com>
> Gesendet: Freitag, 5. Dezember 2025 13:10
> An: Nash, Edward <E.Nash at dvz-mv.de>
> Cc: qgis-developer at lists.osgeo.org
> Betreff: Re: [QGIS-Developer] HTTP 504 uploading new plugin version
> Hi Ed,
> There were some technical issues recently, but they have been fixed.
> It's a timeout that you get when uploading a plugin. I am thinking of two
> reasons: 1. Related to the plugin size, it's heavy and reaches the timeout
> before fully uploading (it should be possible to increase the timeout on
> the plugin server), or 2. The upload process checks the links provided in
> the metadata (homepage, issue tracker...), but they are inaccessible or
> return a timeout.
> Best regards,
> Lova Andriarimalala
> T : +27(0) 87 809 2702          E : lova at kartoza.com <mailto:
> lova at kartoza.com>           W : kartoza.com <http://kartoza.com>
>  <https://kartoza.com/files/KartozaEmailSignature.gif>
> the use of the individual or entity to whom they are addressed. If you have
> received this email in error, please notify the sender immediately and
> delete it from your system. Unauthorised use, disclosure, or copying of the
> On Fri, 5 Dec 2025 at 14:48, Nash, Edward via QGIS-Developer <
> qgis-developer at lists.osgeo.org <mailto:qgis-developer at lists.osgeo.org> >
> wrote:
>         Hi,
>         is the server for the plugin repository https://plugins.qgis.org/
> <https://plugins.qgis.org/>  currently experiencing some technical
> problems? I was able to upload a new version for one of my plugins this
> morning, but for two other plugins I repeatedly get a Cloudflare HTTP 504
> Gateway Timeout error and am unable to upload the new versions.
>         Thanks in advance for your help!
>         Ed
>         _______________________________________________
>         QGIS-Developer mailing list
>         QGIS-Developer at lists.osgeo.org <mailto:
> QGIS-Developer at lists.osgeo.org>
>         List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>         Unsubscribe:
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20251205/aad6913e/attachment.htm>
More information about the QGIS-Developer mailing list
