[QGIS-Developer] Information about the latest version of QGIS for MacOS - 3.44.5
Lorenzo Moretti lorenzomoretti24 at yahoo.it
Mon Dec 8 16:52:46 PST 2025
I downloaded the latest version of QGIS for MacOS and I have to thank you because it is finally a version with updated internal libraries and multi-architecture for Intel and Apple Silicon. Above all, with ARM processors, you can really notice the difference in speed both when opening and running the program. The leap in performance is truly remarkable.
In general, you have included many Python libraries within this application that are necessary to run most of the plugins, but some are missing. They can of course be installed with the command:
% /Applications/QGIS-final-3_44_5.app/Contents/MacOS/python -m pip install pythonlib
However, with each new version of QGIS, you have to do it all over again. Among those to be installed to make various plugins work are scipy, plotly, pandas, matplotlib, scikit-learn, astropy, netCDF4, and others.
The other missing libraries needed to run some plugins, including DataPlotly, are Python libraries for the Qt environment: PyQt5.QtWebKit and PyQt5.QtWebKitWidgets. They seem to be deprecated, but unfortunately they are necessary. I was unable to install them.
Non-functioning executables: the “qgis_process” program. You have inserted it into QGIS, but once executed from the terminal, everything freezes and several library connection errors appear.
Packages not present: “qgis_server”. In the old version, Intel only, the server part was there and worked. Here it is not present.
Anyway, thanks again for this fantastic version ahead of the future version 4.
Lorenzo
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20251209/ea34f9d9/attachment.htm>
More information about the QGIS-Developer mailing list
