[QGIS-Developer] Remove "Polygons must follow boundaries of layer ..." check in Geometry checker plugin?
DelazJ delazj at gmail.com
Tue Dec 16 00:36:50 PST 2025
Hi Régis (and devs),
Thanks for your input.
Just to clarify a point: it is not the algorithm the issue; it is the
original feature in the geometry checker that looks buggy (tm). The
algorithm (and this series of algorithms) "simply" ports the features in
the Geometry checker plugin to Processing, as is, allowing them to be part
of a workflow.
Anyway, according to git blame, the "Polygons must follow boundaries" check
was introduced 8 years ago in
https://github.com/qgis/QGIS/commit/13725362977087dc1fd818e04cb8b2b82a635b98#diff-533309df511fcadcebbb577daeb4098209b97c3a6f7cb8146b38159c59f48f80R593
by Mani Sandro. The PR doesn't add much details on the feature and there
was almost no code review... Maybe does he (if still around) remember what
he tried to implement?
Kind regards,
Harrissou
Le lun. 15 déc. 2025 à 21:39, Régis Haubourg via QGIS-Developer <
qgis-developer at lists.osgeo.org> a écrit :
> Hi Harrissou,
> I tried to understand the question and the history of the QEP and PR
> discussions.
> I think nobody can answer as long as such algorithm are so difficult to
> understand.
> They will indeed never be used in real life if users need to retro
> engineer the algorithm, just like you did with Hefni.
> Can I gently ask the developers originating this feature to make a
> pedagogic effort towards our users, and in this effort save our
> documentation team from such headaches?
> If there is a real use case, please also use real life data to illustrate
> it. Test samples with square and triangles are not helping that much.
> All the best
> Régis
> On 11/21/25 10:17, DelazJ via QGIS-Developer wrote:
> Hi devs,
> I didn't get any reply so I wonder if it is because nobody knows, nobody
> cares, or something else...
> Other than the concern of "adding/keeping a broken tool" in QGIS, we have
> a PR in the docs we don't really know how to finalize, so a feedback would
> be appreciated.
> Thanks.
> Regards,
> Harrissou (for the docs team)
> Le mar. 28 oct. 2025 à 10:38, DelazJ <delazj at gmail.com> a écrit :
>> Hi Devs,
>> In the "Geometry checker" core plugin, there is that option
>> called "Polygons must follow boundaries of layer ...", of which a
>> Processing alg "Polygons exceeding boundaries" was recently created.
>> While testing the algorithm in order to properly document it, we came
>> across weird results (also output by the geometry checker) that we are
>> unable to explain/understand their coherence.
>> Issues and discussion are availabel at
>> https://github.com/qgis/QGIS/issues/63454 and
>> https://github.com/qgis/QGIS-Documentation/pull/10314#issuecomment-3425649278
>> 1/ Does anyone *KNOW* how this option is really supposed to check? and
>> understand the logic behind the output?
>> 2/ If there is agreement that this tool does not adress any real use
>> case, is it something we want to keep in QGIS (in this state)?
>> Looking forward to your replies.
>> Regards,
>> Harrissou
> QGIS-Developer mailing listQGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20251216/8145399c/attachment-0001.htm>
More information about the QGIS-Developer mailing list
