[QGIS-Developer] Fwd: [SpatialTapestry/QGIS-Plugin---Vector-Themes-to-DB] Version number in QGIS plugin repository wrong (Issue #2)
Lova Andriarimalala lova at kartoza.com
Tue Jan 7 23:45:33 PST 2025
Dear Roger,
After checking the metadata.txt of the latest versions of VectorToDBLoader
and landXMLtoDB_Free, I noticed that the changelog field has defined values
but is still commented. For some reason, it confuses the workflow and the
last word `Plugin` becomes the version instead of `1.0`. I think this
should not be allowed (I will create an issue to add an additional check
for this case).
To fix the issue, I suggest uncommenting the changelog attribute like below
(or remove the values if you don't want them to show in the plugin details):
changelog=
> 1.0: After 1000+ downloads and nothing reported, I assume all is good with
> this plugin.
> 1.0: https://gismart.net/stores/spatialtapestry/ is the GoTo Store for
> more capable versions of this Plugin
Afterwards, you can upload the updated zip files for each plugin at
https://plugins.qgis.org/plugins/landXMLtoDB/version/Plugin/update/ and
https://plugins.qgis.org/plugins/vectortodbloader/version/Plugin/update/.
These processes should fix the version numbers and show the changelog on
the specific version details page.
PS: You can also find some notes about plugins publishing at
https://plugins.qgis.org/publish.
I hope this helps,
Best regards,
Lova Andriarimalala
*QGIS Full Stack Developer   *
*T *: +27(0) 87 809 2702          *E *: lova at kartoza.com          *W* :
kartoza.com
*This email and any attachments are confidential and intended solely for
the use of the individual or entity to whom they are addressed. If you *
*have received this email in error, please notify the sender immediately
and delete it from your system. Unauthorised use, disclosure, or copying*
*of the contents is prohibited.*
On Wed, 8 Jan 2025 at 10:05, Lova Andriarimalala <lova at kartoza.com> wrote:
> Dear Roger,
> I will review the plugin and provide you with an update.
> Best regards,
> Lova Andriarimalala
> kartoza.com
> On Wed, 8 Jan 2025 at 06:52, Roger Merritt via QGIS-Developer <
> qgis-developer at lists.osgeo.org> wrote:
>> Hi all, any ideas on this one?
>> ---------- Forwarded message ---------
>> From: Roger Merritt <spatialtapestry at gmail.com>
>> Date: Tue, Jan 7, 2025 at 11:10 AM
>> Subject: Re: [SpatialTapestry/QGIS-Plugin---Vector-Themes-to-DB] Version
>> To: SpatialTapestry/QGIS-Plugin---Vector-Themes-to-DB <
>> reply+BFQN5XUOZRLUKH74VUBX746FQ52VHEVBNHHKKHFQ7E at reply.github.com>, <
>> automation at qgis.org>
>> My metadata.txt file has version 1.0.
>> I cannot see anything "PLUGIN" anywhere in my files that would cause a
>> problem.
>> There is nothing on https://plugins.qgis.org/plugins/landXMLtoDB/update/
>> that allows me to edit the version.
>> I cannot find an email for zimbogisgeek to contact.
>> I do not know how ro progress to fix this issue, sorry.
>> If you have any ideas, please let me know.
>> Roger
>> On Mon, Jan 6, 2025 at 4:29 PM Michel Stuyts <notifications at github.com>
>> wrote:
>>> In the QGIS plugin repository the current version is called "PLUGIN" and
>>> in the metadata it says 1.0 as version number. Because of this difference
>>> there always seems to be an update available in QGIS, even after updating
>>> the plugin.
>>> Reply to this email directly, view it on GitHub
>>> <https://github.com/SpatialTapestry/QGIS-Plugin---Vector-Themes-to-DB/issues/2>,
>>> or unsubscribe
>>> <https://github.com/notifications/unsubscribe-auth/BFQN5XWW5J46EU2ZPMAPP3L2JI5FHAVCNFSM6AAAAABUVEJUDCVHI2DSMVQWIX3LMV43ASLTON2WKOZSG43TAMJSGA4TKMY>
>>> You are receiving this because you are subscribed to this thread.Message
>>> ID: <SpatialTapestry/QGIS-Plugin---Vector-Themes-to-DB/issues/2 at github.
>>> com>
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20250108/ee2a62b1/attachment-0001.htm>
More information about the QGIS-Developer mailing list
